    [Info] Ambient Occlusion -> Simple Rays
    66 Posts 22 Posters 85.2k Views 22 Watching
    • tbdT
      tbd
      @qpik said:
      Has anyone tried it on a normal model which has more than 10 faces? How long does it take to render?
      tried on a selection of 47 faces (nothing complicated) - 8min 42sec on Quad Core 2.4ghz. a bit too slow πŸ˜‰
      render in Podium of the complete model (106 faces) was 31 sec.
      @qpik said:
      I still consider porting it to C++ (which I would have to learn πŸ˜„) but it seems pointless
      as you said that 90% is wasted in raytest I see no point in porting to another language except if you want to implement raytesting based on 3D data.
      http://plugins.ro
      • Q
        qpik
        How about doing the raytest in Javascript via Webdialog?
        Would that be faster than Ruby?
        Kuba
        • Q
          qpik
          Hello there.
          Since I need to calculate sun exposure time in my current project I've added this functionality to the plugin. Here you can see an example. Yellow corresponds to 10h exposure, blue is no exposure.
          It is based on peculiar polish building code (which requires an apartment to have at least 3 hours of direct sunlight on vernal equinox between 7am and 5pm) making this version useful in Poland. It can be easily adjusted though to fit any location and sun position.
          ps. My previous question is still actual - Would doing the raytest in Javascript via Webdialog be faster than Ruby?
            MartinRinehart
            To get this to happen at all in Ruby is heroic. I'm impressed.
            Neither Ruby nor JavaScript is a compiled language. C++ may be an order of magnitude better.
            • Q
              qpik
              Does anyone know if there is a way of creating a faster replacement for
              model.raytest
              method?
              I've found a Ruby PNG library. That's a step towards layering textures in Sketchup (using PNG alpha).
              Kuba
              ps. Would anybody like to cooperate on this plugin?
              • W
                Wacov
                This is really amazing. I mean, if you could do the raytesting separately with a faster language, it'd be really useful.
                  The .raytest method is running in SU's C. Not calculated using Ruby. Ruby just calls the C method.
                  • Q
                    qpik
                    Does that mean that model.raytest algorithm is inherently slow?
                    So I would need to write my own in C.
                      What I meant was that the .raytest is probably written in C already.
                        Jim
                        Yeah, to make it faster wouldn't you need to export the geometry so an external routine could both loop and perform the raytest?
                        • Q
                          qpik
                          But I would have to export geometry for that one external routine.
                          Is there other way?
                          I've got that, I just wonder what makes it slow then and how to write a faster one.
                          I guess I have to prepare myself for switching to C. Even for my simple use, which is lately sunlight exposure analysis, it's simply too slow, when run on part of the city centre model.
                          Kuba
                          ps. Many thanks for all the help so far.
                          • W
                            Wacov
                            Ok.
                            I guess I don't know what I'm talking about, but doesn't SU's raytest method extract more information than you need for your plugin? Maybe that's why it's so (comparatively) slow.
                              Possibly. I guess it depends on what you need it for.
                              • Q
                                qpik
                                I thought exactly the same, as it returns "the first thing that the ray hits". I suppose it means "the closest thing". For my purpose it's enough to get first-on-the-list hit end exit.
                                That might do the trick.
                                • Q
                                  qpik
                                  I quickly wrote this, but it worked MUCH slower than original method.
                                  def raytest2 ray
                                   hit = false
                                   entities = self.entities
                                   entities.each { |face|
                                     if face.kind_of?(Sketchup;;Face) and face.classify_point(ray[0]) > 4
                                      plane = [face.vertices[0].position, face.normal]
                                      intersection = Geom.intersect_line_plane(ray, plane)
                                      if intersection and face.classify_point(intersection) < 8
                                       hit = true
                                       break
                                   return hit
                                  This could be optimized by passing pre-sorted face array (based on results from previous tests) instead of browsing entities array, but I doubt it would speed it up much.
                                  What do you think?
                                    You can use face.plane instead
                                    What do you think?
                                    hmm... If you only iterate the entities collection once then it won't help to pre-process to filter out only faces. Infact, that would mean more iterations. But if you need to iterate the face multiple times, then you will save time on pre-filtering.
                                    Isn't that the same thing?
                                    You're writing a ruby method to be faster than a C method - that C method must be doing a lot of extra processing in order to be able to out-perform it in Ruby.
                                    • Q
                                      qpik
                                      Somehow I didn't notice that one in the API πŸ˜„
                                      I meant to sort the collection before proceeding to the next testing point. The faces that got hit before might as well be the first to get hit by rays cast from adjacent point.
                                      I suppose model.raytest doesn't break after first positive ray hit, but returns the closest one from an array of all.
                                      That is certainly true. That is why I managed to connect with a DLL using Win32api.call (BTW thanks to TBD for his SUDLL example).
                                      Now I'm on my way to moving everything to C. I hope this will finally give a speed boost.
                                      I'm looking into Ruby-OpenGL as well for another approach.
                                      Here is an example - http://forums.sketchucation.com/viewtopic.php?f=180&t=20893&p=209966#p209966
                                        that would be very odd. if it did produce a full array before returning I think it should return the full array.
                                        • Q
                                          qpik
                                          But then how would it find out the closest intersection?
                                          ps. I write all this out of my head, I'm not familiar with 3d algorithms.
                                          • T
                                            tomasz
                                            I think it does break after first positive hit. Make sure you check if the object is not hidden or on a hidden layer, otherwise your rays will stop too early when hidden layer present in a model.
                                            • 2 / 4
