    [Info] Ambient Occlusion -> Simple Rays
    66 Posts 22 Posters 81.0k Views 22 Watching
    • tbdT Offline
      tbd
      @qpik said:
      My biggest concern is model.raytest, it takes up to 90% of calculation time. Is there a way to replace model.raytest?
      unfortunately no 😞
      the only way is to take the 3d data and do the ray testing yourself, but definitely not in Ruby as it is too slow.
      http://plugins.ro
      • Q Offline
        qpik
        unfortunately no 😞
        That is to say that this plugin has very little usability. It's just to slow. 😞
        TBD: It's probably a trivial question, but how do I extract file name from path on both Windows and Mac?
        Anyway. I found that there is a strange thing with SketchUp resizing textures. Sometimes it's smother and sometimes it produces 'waves'. For example it gives nice result while using P:10, R:10 or P:25, R:10, but not with P:20, R:10 or P:50, R:10. (where P stands for Precision and R for Rays in AO settings)
        Kuba
        • tbdT Offline
          tbd
          File.basename(Sketchup.active_model.path)
          and if you want just the name, without the .skp extension:
          File.basename(Sketchup.active_model.path,".skp")
          @qpik said:
          That is to say that this plugin has very little usability. It's just too slow
          if you add overlaying on textures (adding support for .jpg/.png textures is enough) then it can be a free alternative to LightUp 😎
          http://plugins.ro
            DJMX1
            Hello, I'm french this is a google translation.
            This plugin is very promising, it interests me greatly, it will have on it manages colors, textures and shades diffuse projections in the future. But bravo, I am waiting for new version. πŸ‘
            • Q Offline
              qpik
              Thank you TBD. That saved me some time checking Ruby documentation πŸ˜„ I hope i fixed the bugs you pointed out in your first post. Let me know if it works on Mac.
              Also thanks to all for motivating posts. I cannot resist though to see dead end for this plugin.
              Has anyone tried it on a normal model which has more than 10 faces? How long does it take to render?
              I still consider porting it to C++ (which I would have to learn πŸ˜„) but it seems pointless, as it's much easier I think to add texture baking to Podium or Kerkythea (if it's not there yet).
              Kuba
              • tbdT Offline
                tbd
                tried on a selection of 47 faces (nothing complicated) - 8min 42sec on Quad Core 2.4ghz. a bit too slow πŸ˜‰
                render in Podium of the complete model (106 faces) was 31 sec.
                as you said that 90% is wasted in raytest I see no point in porting to another language except if you want to implement raytesting based on 3D data.
                http://plugins.ro
                • Q Offline
                  qpik
                  How about doing the raytest in Javascript via Webdialog?
                  Would that be faster than Ruby?
                  Kuba
                  • Q Offline
                    qpik
                    Hello there.
                    Since I need to calculate sun exposure time in my current project I've added this functionality to the plugin. Here you can see an example. Yellow corresponds to 10h exposure, blue is no exposure.
                    It is based on peculiar polish building code (which requires an apartment to have at least 3 hours of direct sunlight on vernal equinox between 7am and 5pm) making this version useful in Poland. It can be easily adjusted though to fit any location and sun position.
                    ps. My previous question is still actual - Would doing the raytest in Javascript via Webdialog be faster than Ruby?
                      MartinRinehart
                      To get this to happen at all in Ruby is heroic. I'm impressed.
                      Neither Ruby nor JavaScript is a compiled language. C++ may be an order of magnitude better.
                      • Q Offline
                        qpik
                        Does anyone know if there is a way of creating a faster replacement for
                        model.raytest
                        method?
                        I've found a Ruby PNG library. That's a step towards layering textures in Sketchup (using PNG alpha).
                        Kuba
                        ps. Would anybody like to cooperate on this plugin?
                        • W Offline
                          Wacov
                          This is really amazing. I mean, if you could do the raytesting separately with a faster language, it'd be really useful.
                            The .raytest method is running in SU's C. Not calculated using Ruby. Ruby just calls the C method.
                            • Q Offline
                              qpik
                              Does that mean that model.raytest algorithm is inherently slow?
                              So I would need to write my own in C.
                                What I meant was that the .raytest is probably written in C already.
                                  Jim
                                  Yeah, to make it faster wouldn't you need to export the geometry so an external routine could both loop and perform the raytest?
                                  • Q Offline
                                    qpik
                                    But I would have to export geometry for that one external routine.
                                    Is there other way?
                                    I've got that, I just wonder what makes it slow then and how to write a faster one.
                                    I guess I have to prepare myself for switching to C. Even for my simple use, which is lately sunlight exposure analysis, it's simply too slow, when run on part of the city centre model.
                                    Kuba
                                    ps. Many thanks for all the help so far.
                                    • W Offline
                                      Wacov
                                      Ok.
                                      I guess I don't know what I'm talking about, but doesn't SU's raytest method extract more information than you need for your plugin? Maybe that's why it's so (comparatively) slow.
                                        Possibly. I guess it depends on what you need it for.
                                        • Q Offline
                                          qpik
                                          I thought exactly the same, as it returns "the first thing that the ray hits". I suppose it means "the closest thing". For my purpose it's enough to get first-on-the-list hit end exit.
                                          That might do the trick.
                                          • Q Offline
                                            qpik
                                            I quickly wrote this, but it worked MUCH slower than original method.
                                            def raytest2 ray
                                             hit = false
                                             entities = self.entities
                                             entities.each { |face|
                                               if face.kind_of?(Sketchup;;Face) and face.classify_point(ray[0]) > 4
                                                plane = [face.vertices[0].position, face.normal]
                                                intersection = Geom.intersect_line_plane(ray, plane)
                                                if intersection and face.classify_point(intersection) < 8
                                                 hit = true
                                                 break
                                             return hit
                                            This could be optimized by passing pre-sorted face array (based on results from previous tests) instead of browsing entities array, but I doubt it would speed it up much.
                                            What do you think?
                                            • 2 / 4
