    Any SU render engines that renders distorted textures?
    97 Posts 17 Posters 26.4k Views 17 Watching
    • N
      notareal
      so what's irender doing so differently than the other renderers? or does it export a bunch of textures prior to rendering?
      My quess is that it does export predistorted textures (like kmz export). So for Thomas' scene you will get two different textures when rendered. Sorry, have no irender, so cannot test. Wonder if it saves temp textures on disk before rendering...
      • C
        Chris_at_Twilight
        I didn't see an actual answer in Al's post. Maybe I just didn't understand it?
        http://www.TwilightRender.com
          @chris_at_twilight said:
          @Jeff: Maybe because everything is already triangles, the UV coordinates that SU generates are 'compatible' with the traditional triangular UV techniques employed by other applications. So what you see in SU, is what you get in the render. Of course, it could just be how UVTools does the sphere mapping that makes it more compatible?
          @richcat said:
          IRendernxt straight render in sketchup, you'll have to ask Al how?
          You are more than welcome to ask. I won't be surprised if they use the same "pre-distorted" image technique that the SU exporters use.
          VfSU for instance, I snooped in the .rb files, uses the PolygonMesh of each face to sample the UV data. And the PolygonMesh consists on only triangular polygons - but it does not render correctly. Even if you make a triangle and apply a distorted textures, it'll render incorrectly.
          So it doesn't seem to be the case. Though, it is weird what Jeff describes - seems to do the trick for him in Indigo. ...maybe Whaat knows something on this...
            @al hart said:
            Here is a 3D Warehouse model where the house image was placed using Photo Match. Some renderers process it correctly and some renderers do not recognize and process the distorted texture.
            Any insight on how to process distorted textures correctly?
              An export to Collada for the entire scene produces 1 undistorted texture and 1 distorted texture.
              How are the unique texture created? No API methods AFIK that dose that.
              Something they generate themselves in some external C code? Outside the reach for us mere mortal that only uses Ruby?
              • W
                Whaat
                The texturewriter class will write pre-distorted textures. It is a lot of work to implement this in a rendering engine because you have to first determine which faces are distorted and create a unique material for each of them. As we have seen, this can result in LOTS of materials. I will probably add support to SkIndigo some day but I have not considered it a high priority. Very few users even mention it as a serious problem.
                It comes up most often when a user downloads a model from the 3DW that has been photomatched and then they try to render it.
                SkIndigo has had a workaround option for over a year (well before SketchUp added it as a standard feature). You can right-click on a face and go to 'Explode Distorted Texture'. It does the same thing as 'Make Unique Texture'
                • W
                  Whaat
                  Very interesting thread. Thanks Thomthom for starting this discussion. So far, it has confirmed most of my theories.
                  Unless the rendering engine can interpolate UV mapping using four anchor points, it can't be done without exporting a pre-distorted texture.
                  The method of triangulating the mesh for the spherical mapping probably has something to do with how UVTools works. I believe that for faces with greater than three vertices, I call the position_material method with four points (which probably results in a very slightly distorted texture, but enough to mess up the rendering engines). For faces with three vertices, I call the position_material method with only three points so the texture is not distorted (at least not enough to notice).
                  It is strange. Someone should test to see if the textures are distorted even for triangles after applying the spherical mapping. Maybe I'm wrong...
                    Is that possible? Is a distorted texture at all possible to define with three points?
                    And work out new UV data for the material you create.
                    But this method won't make new materials in the SU file, right?
                    Could that not be because people are avoiding them due to this problem?
                    Also - recently there's been more stir about UV mapping here on the forum. As you saw with your UVTools 0.2 thread.
                    I've got some UV plugins I'd like to make - I've been looking into it - but since I render in V-Ray I try to avoid distorting textures.
                      I've never been a fan of such workaround - makes the organisation of the model difficult.
                      • Al HartA
                        Al Hart
                        As I recall, we originally tried to figure out that the image was distorted, but in the end we would up having SketchUp save an image for everything, and having SketchUp give us the UVQ coordinates and it finally just worked.
                        I just looked through the code and couldn't find anything special that we are doing. (Except to let SketchUp save a texture for all textured materials, and to let SketchUp give us the UVQs)
                        Al Hart
                        IRender nXt from Render Plus
                          From observation it seems that a texture is distorted when the Q value isn't 1.0. The manual says that the UVHelper ignores the Q value - but that isn't the case in reality. Had an conversation with Jeff ("jeff99") about this: http://forums.sketchucation.com/viewtopic.php?f=180&t=21700&start=30#p191715
                          Which resulted in this summary which I wrote.
                          http://forums.sketchucation.com/viewtopic.php?f=180&t=22719
                          If you write out unique textures for every face, then don't you have to discard the UV data from SU? Because the unique texture would come out regular, but the one SU refers to with its UV data is distorted. Or am I misunderstanding something.
                          • Al HartA
                            Al Hart
                            I am pretty sure that SketchUp gives us the full image, and normal UV values for normal, rotated and skewed images, but gives us UV values of (0,0), (1,0), (1,1), and (0,1) (or something like that) for the distorted image, so that the full distorted image is placed on the face. (It may be because we are (or because we aren't - it is hard to remember just what we did to make it work) using UVhelper to get the UVQ values.
                            Al Hart
                              I got a plugin that let you inspect the UVQ values of the UVHelper: http://forums.sketchucation.com/viewtopic.php?f=180&t=21472
                              Using that, for all Normal, Scaled, Squashed and Skewed textures the Q values remains 1.0. But for distorted textures the Q values is not 1.0 - it has to be normalized to get flat UV values. The U and V values are also not 1 and 0's - but I'd think that you would have to override the UV values with 1 and 0's in order to fit the new unique texture over the face. That seem to make sense.
                              I'm still wondering if this is the only way though. Or maybe the SU way simply isn't compatible with the UV co-ordinates of most other apps. How does other 3D applications map textures? Generally.
                                Also - when an image is made unique - how will bump maps and other layers of the rendered material match up?
                                • C
                                  Chris_at_Twilight
                                  In my opinion, Whaat makes a pretty good explanation. The uv_helper / texture_writer combo is the key. The texture writer is used to produce the pre-distorted texture and the uv_helper returns UV coordinates that are specific to mapping that texture to the face. These are (potentially) different coordinates from the ones you receive directly from the PolygonMesh. I don't know the code off hand, but I do know that Tomasz has been doing this for quite some time; he may have been the first.
                                  As for detecting when textures are distorted... I agree that you will very often see 'z' or 'q' (UVQ) values that are not 1.0, but I think you can get false negatives that way. Meaning, you can have distorted textures where the Q is not any value but 1. (This is speculation only)
                                  I think you've got it dead on. The uv_helper and texture_writer work together; one produces the new uv, one produces the image. This doesn't effect the existing scene in any way. The uv_helper produces UV values that match the pre-distorted image, but they don't change the existing SU model. So the resulting image is unusable in the original model; the image no longer matches up with the original UV. You could replace the existing UV and the existing texture, but I think what you've basically done is recreate the "Make Unique" function.
                                  • C
                                    Chris_at_Twilight
                                    My suspicion is that it is the only way. I think most applications use the barycentric on triangle method because it's very fast. You can precalculate almost all the information, so for any point within the triangle, it's a simple and fast function to translate 3D point into a UV image coordinate. Is there an app out there that actually use UVQ instead of UV, potentially supporting distorted tex? No idea.
                                    • C
                                      Chris_at_Twilight
                                      thomthom, you asked about how unique textures are made. I don't havethe exact code, but here are a couple places to start:
                                      TextureWriter.write( face, filename, [true - front face / false - back face])
                                      Face.get_UVHelper( front_face_coords, back_face_coords, texture_writer)
                                      UVHelper.get_front_UVQ / get_back_UVQ
                                      I think you can actually use this on every single face, even non-distorted, but you'll likely overwrite the same texture over and over and over, which is slow to say the least. So you'll want some management to track when to write a new image.
                                      • Al HartA
                                        Al Hart
                                        why are these working?
                                        i was under the impression (and i'm almost positive i read this from whaat) that projected textures won't render properly..
                                        are these not distorted?
                                        there's only one texture in the model and no exporting of individual faces happened
                                        It is quite possible that these images are not actually "distorted". There are four handles which can be used to position textures. (These are explained at the beginning of this thread). Three of them move, stretch, rotate and skew the image. Most normal UV mappings consist of only these four things. Many strange looking mappings are only stretched and skewed. Only the upper right handle "distorts" the image. A distorted image cannot be easily defined by 4 UVQ values at the corners of the face. (Distort is a term we use to mean "even worse then skewed". So many images which seem distorted to us are only stretched and skewed.) (Remember normal UVQ mapping can be used to display most projections of images onto spheres and curved surfaces which we see in most modeling and rendering packages.)
                                        Instead, SketchUp performs a more complicated mapping of the image, saves an already distorted image for us on the disk, and we can them map the image to the face with default UVQ values.
                                        Al Hart
                                        • jeff hammondJ
                                          indigo
                                          indigo
                                          [i'm pretty sure i project these in the normal sense of projecting a SU texture..
                                          import file as an image.. line it up with the object.. explode the image.. with , hold the cmmd key (mac) and sample the imported texture.. paint on the object i want the image projected onto]
                                          [EDIT] nvm about what i thought whaat said.. i was thinking about this thread i read a while ago
                                          http://www.indigorenderer.com/forum/viewtopic.php?f=17&t=7036
                                          the dude called it a projected texture but i d/ld the model and it was in fact distorted (as dale said)
                                          [edit2] well, i dunno.. he did say skewed via projection in there 😉
                                          • FrederikF
                                            Frederik
                                            Al... I really don't get this or any of your explanations... 😐
                                            What I can see is that your application is also making the texture unique...
                                            Your application and also Hypershot does the same as everyone else...
                                            They just export the texture special for each distorted surface...
                                            Cheers
                                            Kim Frederik
                                            • 3 / 5
