    Any SU render engines that renders distorted textures?
    97 Posts 17 Posters 26.4k Views 17 Watching
    • C
      Chris_at_Twilight
      http://en.wikipedia.org/wiki/Barycentric_coordinates_%28mathematics%29
      Maybe some thoughts. Barycentric on a triangle is a very common application. But check out the Barycentric on a tetrahedra (barycentric in 3D). Maybe it's how SU uses it?
      http://www.TwilightRender.com
      • jeff hammondJ
        @chris_at_twilight said:
        Huh. The .3ds format only supports triangles (I think), so there is a way to represent the texture interpolation used by SU using only 3 UV coordinates (and the .3ds export knows it! )
        not sure if this will trigger any thoughts with you guys (and really, i don't understand much of what you're talking about) but..
        if everything is triangles in SU prior to messing with the UV mapping then it will render correctly..
        Sphere after using triangulatefaces.rb
        After importing a texture and applying it to the sphere
        use UVtools spherical option on the texture
        resulting render in indigo.. no exporting or unique textures
          richcat
          IRendernxt straight render in sketchup, you'll have to ask Al how?
          • C
            Chris_at_Twilight
            @Jeff: Maybe because everything is already triangles, the UV coordinates that SU generates are 'compatible' with the traditional triangular UV techniques employed by other applications. So what you see in SU, is what you get in the render. Of course, it could just be how UVTools does the sphere mapping that makes it more compatible?
            You are more than welcome to ask. I won't be surprised if they use the same "pre-distorted" image technique that the SU exporters use.
            • soloS
              Yup, can confirm Irender aim and renders it correctly.
                dedmin
                I tried the last version of the IrendernXT, but had a lot of problems - slow response of the interface, sometimes when adjusting textures all goes white, when tried to load a plant from the library SketchUP crashes and etc.
                • Al HartA
                  Al Hart
                  The Distorted texture is a nice feature of SketchUp - the ability to take a photo of a house for instance, from an angle, and then distort it onto the actual house so that it looks correct. SketchUp provides tools to get these distorted textures and UV coordinates properly, but it did take a lot of time and effort to figure it out and get it to work properly.
                  SketchUp made this distortion even easier to use (without knowing that you are doing it) with their Photo Match techniques.
                  Here is a 3D Warehouse model where the house image was placed using Photo Match. Some renderers process it correctly and some renderers do not recognize and process the distorted texture.
                  http://sketchup.google.com/3dwarehouse/download?mid=9e0b93c387cad06c93a794ea4e64d35b&rtyp=lt&ctyp=other&ts=1251394213000
                  3D Warehouse model
                  Al Hart
                  IRender nXt from Render Plus
                  • jeff hammondJ
                    it looks ok, right? 😄
                    so what's irender doing so differently than the other renderers? or does it export a bunch of textures prior to rendering?
                    • N
                      notareal
                      My quess is that it does export predistorted textures (like kmz export). So for Thomas' scene you will get two different textures when rendered. Sorry, have no irender, so cannot test. Wonder if it saves temp textures on disk before rendering...
                      • C
                        Chris_at_Twilight
                        I didn't see an actual answer in Al's post. Maybe I just didn't understand it?
                          VfSU for instance, I snooped in the .rb files, uses the PolygonMesh of each face to sample the UV data. And the PolygonMesh consists on only triangular polygons - but it does not render correctly. Even if you make a triangle and apply a distorted textures, it'll render incorrectly.
                          So it doesn't seem to be the case. Though, it is weird what Jeff describes - seems to do the trick for him in Indigo. ...maybe Whaat knows something on this...
                            Any insight on how to process distorted textures correctly?
                              An export to Collada for the entire scene produces 1 undistorted texture and 1 distorted texture.
                              How are the unique texture created? No API methods AFIK that dose that.
                              Something they generate themselves in some external C code? Outside the reach for us mere mortal that only uses Ruby?
                              • W
                                Whaat
                                The texturewriter class will write pre-distorted textures. It is a lot of work to implement this in a rendering engine because you have to first determine which faces are distorted and create a unique material for each of them. As we have seen, this can result in LOTS of materials. I will probably add support to SkIndigo some day but I have not considered it a high priority. Very few users even mention it as a serious problem.
                                It comes up most often when a user downloads a model from the 3DW that has been photomatched and then they try to render it.
                                SkIndigo has had a workaround option for over a year (well before SketchUp added it as a standard feature). You can right-click on a face and go to 'Explode Distorted Texture'. It does the same thing as 'Make Unique Texture'
                                • W
                                  Whaat
                                  Very interesting thread. Thanks Thomthom for starting this discussion. So far, it has confirmed most of my theories.
                                  Unless the rendering engine can interpolate UV mapping using four anchor points, it can't be done without exporting a pre-distorted texture.
                                  The method of triangulating the mesh for the spherical mapping probably has something to do with how UVTools works. I believe that for faces with greater than three vertices, I call the position_material method with four points (which probably results in a very slightly distorted texture, but enough to mess up the rendering engines). For faces with three vertices, I call the position_material method with only three points so the texture is not distorted (at least not enough to notice).
                                  It is strange. Someone should test to see if the textures are distorted even for triangles after applying the spherical mapping. Maybe I'm wrong...
                                    Is that possible? Is a distorted texture at all possible to define with three points?
                                    And work out new UV data for the material you create.
                                    But this method won't make new materials in the SU file, right?
                                    Could that not be because people are avoiding them due to this problem?
                                    Also - recently there's been more stir about UV mapping here on the forum. As you saw with your UVTools 0.2 thread.
                                    I've got some UV plugins I'd like to make - I've been looking into it - but since I render in V-Ray I try to avoid distorting textures.
                                      I've never been a fan of such workaround - makes the organisation of the model difficult.
                                      • Al HartA
                                        Al Hart
                                        As I recall, we originally tried to figure out that the image was distorted, but in the end we would up having SketchUp save an image for everything, and having SketchUp give us the UVQ coordinates and it finally just worked.
                                        I just looked through the code and couldn't find anything special that we are doing. (Except to let SketchUp save a texture for all textured materials, and to let SketchUp give us the UVQs)
                                        Al Hart
                                          From observation it seems that a texture is distorted when the Q value isn't 1.0. The manual says that the UVHelper ignores the Q value - but that isn't the case in reality. Had an conversation with Jeff ("jeff99") about this: http://forums.sketchucation.com/viewtopic.php?f=180&t=21700&start=30#p191715
                                          Which resulted in this summary which I wrote.
                                          http://forums.sketchucation.com/viewtopic.php?f=180&t=22719
                                          If you write out unique textures for every face, then don't you have to discard the UV data from SU? Because the unique texture would come out regular, but the one SU refers to with its UV data is distorted. Or am I misunderstanding something.
                                          • Al HartA
                                            Al Hart
                                            I am pretty sure that SketchUp gives us the full image, and normal UV values for normal, rotated and skewed images, but gives us UV values of (0,0), (1,0), (1,1), and (0,1) (or something like that) for the distorted image, so that the full distorted image is placed on the face. (It may be because we are (or because we aren't - it is hard to remember just what we did to make it work) using UVhelper to get the UVQ values.
                                            Al Hart
                                            • 3 / 5
