    Google SketchUp 7.1.6087
    36 Posts 22 Posters 7.1k Views 22 Watching
    • GaieusG
      @drewpoeppel said:
      Does anybody know if this breaks the .dwg import enabler for GSU, or if you can just run the enabler patch again if it does. I'm afraid to upgrade. They said it wouldn't be supported in later versions. Thanks
      No,this is just a maintenance release and it should not affect the importer.
        My understanding was that "later versions" meant later major versions. Like SU8.
          rv1974
          Yes it's fixed now:
          When editing a component and selecting a component within it, instances of that component were incorrectly highlighted if the "hide similar components" setting was checked. Instances are no longer highlighted in this case.
          Thank you a lot!
            drewpoeppel
            Upgraded and indeed, no problems with the importer. Thanks.
            • T
              tfdesign
              I'm curious to know what you other Mac Leopard users think of the latest SU build. I've had to go back to v7.1.4870 because I was getting slower performance. I even had a crash- the first one in fact, and oddly enough, no crash log screen popped up either ๐Ÿ˜• (yes, I could have opened Console).
              Updating to Snow Leopard this evening, after I've backed up my hard drive.
              • AndrewSA
                AndrewS
                I use Leopard still and I have found build 5803 to be more stable than 4870.
                Did this remedy the performance issue? There's only one reason I can think of why performance may have been compromised with the upgrade, but it wouldn't have gone away with the downgrade.
                I even had a crash- the first one in fact, and oddly enough, no crash log screen popped up either.
                That's not too weird. As hard as we try, we can't always capture the crash with our reporting software; neither can the Apple crash reporter.
                I can't imagine any reason that this would solve your problem aside from the fact that if you do a clean install, the settings/configuration across your entire machine and in SketchUp will be replaced with defaults, possibly correcting any damage that was caused by misconfiguration. That's a good enough reason to try a clean install, I suppose! I don't know whether it will make a difference if you just do an upgrade installation of Snow Leopard, however.
                Let us know how it goes.
                Andrew S.
                SketchUp Release Engineer
                • T
                  tfdesign
                  Cheers Andrew. I will indeed tell you what happens. I've got to do a 'live performance' in front of over 120 church members this coming Sunday morning, showing the model I have made for modifications to the interior. The vicar has already been 'blown away' by the results from the pre-review!
                  Next week I will do a clean installation of Snow Leopard, and wiping the whole hard drive. I'll then reload 5803, and give it another whirl. The only reason I haven't bought Pro yet is because of your licensing issue when it comes to platform choice. I don't want to be locked into a Windows version, if I choose to buy another Mac, or vice versa.
                  regards,
                  Tom
                  • daleD
                    dale
                    I'm still using Tiger on the mac, but on my Imac yesterday, performance was fine, but I had to re-boot twice because of complete lock up. This has never happened before.
                    I am still not completely sure that it is the SketchUp upgrade that is causing my problem, as I was working from a dfx/dwg import from Vectorworks. I had simply imported the floor plans into SketchUp, and placed them on another Layer in order to trace on layer 0. I have always had strange anomalies when I bring in dfx/dwg files from either Acad or VW, and have ranted about this before.
                    When I was done my trace, I copied and pasted the model into a new skp. file, and have had no problems since. But I'm not done yet.
                      dspringer
                      Do you have the software renderer turned on? You can check this via Preferences, click on the OpenGL tab. There is an issue in Apple's software renderer that gets triggered by SketchUp which can cause crashes. Enabling the hardware renderer resolves this.
                      • daleD
                        dale
                        Thanks, yes up and running, and all drivers current.
                        With me I'm pretty sure this is a translation issue with dxf/dwg, as seems like the only time I have issues is with these files.
                        • T
                          tomot
                          All this SU maintenance and updating is starting to interfere with the weekly vacuuming my wife has left me to do ๐Ÿ˜„
                          Would it not be simpler to create a patch.exe for D/L, to fix these bugs: Instead everyone is downloading and installing yet another copy of GoogleSketchUpProWEN.exe
                          It would also make more sense to rename each new GoogleSketchUpProWEN.exe by including the revision number in the title ie. GoogleSketchUpProWEN.v7.1.4871.exe It would make it easier to distinguish the latest from all the other turkeys?
                          happy gobble gobble!
                          my plugins
                          tomot
                          • AnssiA
                            Anssi
                            I didn't notice it mentioned in the release notes, but is the Shadow bug gone? I couldn't make it happen in a file that recently was displaying it very consistently. Have to go on testing.
                            Anssi
                            • AndrewSA
                              AndrewS
                              I recognize that it may seem inconvenient to have to download such big files every time we make an update, but in the grand scheme of things, it's not too frequent. Creating patches is actually an extraordinary amount of work in comparison to using our existing (automated) process for creating full product installers. I've seen an awful lot of complaints around the forums in general from folks who seem to think we have a team of thousands working on SketchUp and wanting to know why we haven't fixed every pet peeve bug. The truth is, we're a pretty small team and every minute we spend fixing problem "A" is a minute lost to problem "B". I think the amount of work it will take to create reliable patch files and the tech support effort it would require to make sure everyone installs and manages them in the proper sequence and manner would easily dwarf any benefit that such a scheme would provide.
                              You can also thank the good folks at Apple for never creating a fundamentally solid install/uninstall technology, which also contributes greatly to the problem on Mac. While we use a good MSI technology on Windows that makes managing installation a much easier affair, it still would be quite a bit of work to make such customizations. I'll also point out that if you were to perform a binary diff on all of the files in each release, you would find that the overwhelming majority of files were all changed, which is a byproduct of our product architecture. Fixing the underlying architecture to actually make patch distribution an efficient endeavor would be an enormous job which would go 100% unnoticed, unfortunately.
                              We keep the filename the same for a few very good reasons. 1) We don't have to change all of our back-end code for serving files from the online store, etc. 2) It ensures that when people post links here on the forums, they continue to be up-to-date at all points in the future, which is an entirely worry-free endeavor.
                              When I post SketchUp for download, I actually do provide it under a specific link including the version number, in addition to the generic one, but it's not something that is well publicized.
                              For instance, http://dl.google.com/sketchup/gsu7/PW-2-1-6087-EN.exe
                              I think you have to admit though that it's a lot easier to just go into SketchUp and use the "check for update" mechanism to find out if a new version is available, instead of having to remember and mess with version numbers.
                              And the same to you and yours!
                              Cheers!
                              Andrew S.
                              • P
                                Panga
                                Anssi
                                I made a small test at work, and I'm asking myself the same thing. I'll have to make another test with an old model at home.
                                EDIT : I made another simple animation with some tree components with which i had always the shadow bug, but the bug is gone.
                                Is this a hidden bux fig ?
                                • GaieusG
                                  Guys, I also made a test the other day (with an interior where the sun was shining through the windows) and it is still there. Was flickering like a disco ball.
                                  • P
                                    Panga
                                    Ok, thanks Gaieus. But the bug seems to be less present, because it disappears in some of my models. Maybe the last optimisations of the 7.1 release are responsible for this, don't know...
                                    • F
                                      frv
                                      Hi Andrew,
                                      looking at your post where you write that SU at Google represents a rather small team. I wonder if that small team is in relation to the userbase of SU. I can't think of an architectural office that does not use SU. It might be even bigger than autoCAD. Is there not a bit too much presure on too few people at Google Skechup ?.
                                      Maybe Google has underestimated the potential of Sketchup in the construction and architectural industry ?
                                      Francois
                                      • L
                                        LindsayGT
                                        Is there an MSI version that I can use to push out via Group Policy?
                                        Thanks,
                                        Lindsay
                                        • 2 / 2
