A little Problem...
Updated
That is more interresting
You can win 2 millions $ for make a "little" puzzle
But now make speedy answer : 31 12 2009 end first step of the game!
can i just answer 'it's going to take forever' ?
that is a huge huge number that i don't really know how to write
i did find a method to obtain the answer though
basically,
2disc = 3 moves
3disc = 7
4disc = 15
5disc = 31
6disc = 63
etc..following that sequence, 7discs = 127 then 8 = 255
i'll try to get it better than that though. -
Good start jeff
Youve got what we in the business call a recursive solution i.e. you can find n+1 if you know n.The general solution should be fairly easy to find from there.
Your a factor of 100 out, you can make 10 moves a minute whereas i guess you took a move takes 10 minutes. Otherwise correct though
well, here's the answer i'm going to go with but this stuff is over my head.. i like the practical everyday logic puzzles much better
184,467,440,737,095,516,150 minutes
[edit] hmm.. maybe that's 10 minutes too long? i guess you don't have to wait 10 minutes before making the very first move.
[edit2] oops agian.. i figured it as if you make one move every 10 minutes instead of 10 per minute..
so maybe it's more like
1,844,674,407,370,955,161 minutes...and 30seconds -
right.. i update my post as you were posting yours.
ok, i'm gonna go eat ice cream now
Very sensible
204 minutes
howd you get that?
is it not the famous HanoΓ― tower?
fwiw, the way i figured it out was by physically doing the puzzle in sketchup with 2,3,4 & 5 discs then looking for a pattern..
my results were
3
7
15
31which i realized was the same a 4,8,16,32,64,etc minus 1..
then i had to find a big enough calculator to figure out the rest..i'm sure there's a way to do this using formulas but i'm more of a hands on type
similar math is applied to this question:
would you rather I give you $5000 right now -or- give you a penny right now, 2 pennies tomorrow, 4 pennies the next day etc.. for an entire month?
Only Bill Gates and a few other chaps have enough spare change to pay the amount you would owe me, Jeff ($10,737,418.23), so I prefer you give me the $5,000 today.
EDIT: I mistook pennies for dollars and 5000 for 500, so I updated my post.
Pilou, it is indeed the towers of hanoi problem.
In a similar vein there is the wheat and chessboard story: http://en.wikipedia.org/wiki/Wheat_and_chessboard_problem
haha, okay Miguel.. the check is in the mail!
@remus said:
Well done people, its not a trick question: 2 is the correct answer as ecuadorian said (and the scales are the 1st type you posted jeff.)
edit: doh, put 3 instead of 2. Corrected.
Wait, thought it was 2.
