    [Plugin] Extrude Edges by Rails
    381 Posts 71 Posters 376.7k Views 71 Watching
      Some nurbs tools arrive in Su! โ˜€ ๐Ÿ˜Ž
      Bravo! ๐Ÿ‘
        Click Draw
        Yes....this script will be a very good ASSet to my collection! ๐Ÿ˜„
        Have I mentioned how much of a laugh I get out of some of the Signatures on here!
        • mitcorbM Offline
          mitcorb
          Congratulations, TIG!!!
          I am anxious to try this out!!!
          I can only imagine the level of difficulty you may have encountered.
          • utilerU Offline
            utiler
            Awesome TIG!!!!!!
            Just Curious...
              Seems that works like a charm ๐Ÿ˜„
              Crashed if Rail1 is clicked first ๐Ÿ˜ฎ
              I think that's because the profile (now rail1) would need to be infinitely small where the two rails (profile+rail2) meet... I think it's trying to make tiny faces in the 'corner'... I know of this glitch and I am looking at ways of trapping it - it's not 'foolproof' yet ! ๐Ÿ˜‰
              Meanwhile use logically... ๐Ÿ˜
                  pav_3j
                  really beautiful, thank you so much.
                  i used it with the BZ toolbar, and you can set the segment amout for the line at the start which is a real time saver!
                  thank you again
                  pav
                  Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
                    Next will be Coon'Surface? โ˜€
                    (just add the oposite profile as Rail 3 ๐Ÿ˜„
                      Pilou ! ๐Ÿ˜
                      One step at a ๐Ÿ˜‰ time...
                      • E Offline
                        Ecuadorian
                        Pilou, you want SketchUp to become MoI. Each one has its own. ๐Ÿ˜„
                        -Miguel Lescano
                          Now there are distant cousins ๐Ÿ˜„
                          If you take the previus 3 curves without connection between them you will obtain these flying fishes ๐Ÿ˜„
                          (click image if scrollbar)
                            tomot
                            Looks like it has a lot of potential, ๐ŸŽ‰ I have not had time to try it yet.
                            I was wondering if you had included, "Triangulate" or "Quad" face options?
                            cheers!
                            my plugins
                            tomot
                            • N Offline
                              notareal
                                kostas_designer
                                A force of SU nature!!
                                Really cool!
                                Great job, Tig! ๐Ÿ‘
                                Here is some first trying:
                                  Humhum ๐Ÿ˜‰
                                  Seems we must have possibility to reverse rails before apply the plug! ๐Ÿ˜ฎ
                                  [attachment=0:1pr20x36]<!-- ia0 -->falsebug.png<!-- ia0 -->[/attachment:1pr20x36]
                                  I am looking how to fix this within the script - to fix it manually for now use scale -1 on the profile about the profile's centre...
                                    Humhum ๐Ÿ˜‰
                                    false_bug.skp
                                      The curious thing is that the Rail2 is a "straight line"
                                      So must be divided , then welded
                                      But result seems no reproductible and gives some nusty result ๐Ÿ˜ฎ
                                      PS A multi-profils along Rail1 rail2 will be sweet too โ˜€
                                      • mitcorbM Offline
                                        mitcorb
                                        Pilou:
                                        I had similar results with the construction points on several attempts. Once, with rails made by Freehand tool and once with profile and rails made by Welded segments for profile and rails and once by smoothing out the profile with added arcs and Welding.
                                        Since TIG said the script was mostly stable, I figured that there would be some of this to happen.
                                          @mitcorb said:
                                          Pilou:
                                          Can you all give as much info about the failures as possible [PM me small skps if appropriate] Ruby Console messages etc - I want to debug this glitch ๐Ÿ˜’
                                          • mitcorbM Offline
                                            mitcorb
                                            TIG:
                                            Thanks for the Example skp.
                                            I will try to provide you with examples as time permits. And I have been observing the Ruby console.
                                            My last experiment was with Polyline Divider as the profile and rails from Fredo's Bezier collection. I got the mesh ok, but of course, the math complexity reversed and crisscrossed the beginning and ending copies of the profile causing an oblate spheroid bulge(same shape as an American football) and wings like Pilou's harlequin flying fish. However, there was no comment in the console.
                                            Unfortunately the file is saved on my home machine. I will have to send it later.
                                            • 19
                                            • 20
                                            • 1 / 20
