    [Plugin] Extrude Edges by Rails
    381 Posts 71 Posters 383.6k Views 71 Watching
      I hadn't foreseen the potential for softcore pornography ! ๐Ÿคฃ
        Some nurbs tools arrive in Su! โ˜€ ๐Ÿ˜Ž
        Bravo! ๐Ÿ‘
          Click Draw
          Yes....this script will be a very good ASSet to my collection! ๐Ÿ˜„
          Have I mentioned how much of a laugh I get out of some of the Signatures on here!
          • mitcorbM Offline
            mitcorb
            Congratulations, TIG!!!
            I am anxious to try this out!!!
            I can only imagine the level of difficulty you may have encountered.
            • utilerU Offline
              utiler
              Awesome TIG!!!!!!
              Just Curious...
                Seems that works like a charm ๐Ÿ˜„
                Crashed if Rail1 is clicked first ๐Ÿ˜ฎ
                I think that's because the profile (now rail1) would need to be infinitely small where the two rails (profile+rail2) meet... I think it's trying to make tiny faces in the 'corner'... I know of this glitch and I am looking at ways of trapping it - it's not 'foolproof' yet ! ๐Ÿ˜‰
                Meanwhile use logically... ๐Ÿ˜
                    pav_3j
                    really beautiful, thank you so much.
                    i used it with the BZ toolbar, and you can set the segment amout for the line at the start which is a real time saver!
                    thank you again
                    pav
                    Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
                      Next will be Coon'Surface? โ˜€
                      (just add the oposite profile as Rail 3 ๐Ÿ˜„
                        Pilou ! ๐Ÿ˜
                        One step at a ๐Ÿ˜‰ time...
                        • E Offline
                          Ecuadorian
                          Pilou, you want SketchUp to become MoI. Each one has its own. ๐Ÿ˜„
                          -Miguel Lescano
                            Now there are distant cousins ๐Ÿ˜„
                            If you take the previus 3 curves without connection between them you will obtain these flying fishes ๐Ÿ˜„
                            (click image if scrollbar)
                              tomot
                              Looks like it has a lot of potential, ๐ŸŽ‰ I have not had time to try it yet.
                              I was wondering if you had included, "Triangulate" or "Quad" face options?
                              cheers!
                              [my plugins](http://thingsvirtual.blogspot.ca/)
                              tomot
                              • N Offline
                                notareal
                                Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                                  kostas_designer
                                  A force of SU nature!!
                                  Really cool!
                                  Great job, Tig! ๐Ÿ‘
                                  Here is some first trying:
                                    Humhum ๐Ÿ˜‰
                                    Seems we must have possibility to reverse rails before apply the plug! ๐Ÿ˜ฎ
                                    [attachment=0:1pr20x36]<!-- ia0 -->falsebug.png<!-- ia0 -->[/attachment:1pr20x36]
                                    I am looking how to fix this within the script - to fix it manually for now use scale -1 on the profile about the profile's centre...
                                      Humhum ๐Ÿ˜‰
                                      false_bug.skp
                                        The curious thing is that the Rail2 is a "straight line"
                                        So must be divided , then welded
                                        But result seems no reproductible and gives some nusty result ๐Ÿ˜ฎ
                                        PS A multi-profils along Rail1 rail2 will be sweet too โ˜€
                                        • mitcorbM Offline
                                          mitcorb
                                          Pilou:
                                          I had similar results with the construction points on several attempts. Once, with rails made by Freehand tool and once with profile and rails made by Welded segments for profile and rails and once by smoothing out the profile with added arcs and Welding.
                                          Since TIG said the script was mostly stable, I figured that there would be some of this to happen.
                                            @mitcorb said:
                                            Pilou:
                                            Can you all give as much info about the failures as possible [PM me small skps if appropriate] Ruby Console messages etc - I want to debug this glitch ๐Ÿ˜’
                                            • 19
                                            • 20
                                            • 1 / 20
