    [Plugin] Extrude Edges by Rails
    381 Posts 71 Posters 424.7k Views 71 Watching
      It doesresolve the issue of unequal segments in the rails (== the profiles used in 'Loft'), however, then you do need to set the 'profile' curve (which is the unchangeable 'bezier-path' pre-set in 'loft'!)...
      AND if the rail segments are not equal or at least simple multiples the facets made might multiply unreasonably !!!
      Feedback please... it's still a little buggy...
      • jeff hammondJ
        wow ๐Ÿ˜ฒ looks awesome!
        after a quick test, it appears to work very well.. i'll have more time to check it out tonight.
        click pic for larger
        • C
          Click Draw
          Yup...same here. Not sure what's on my mind right now ๐Ÿ˜‰. Ahhh, who needs to work!
          Have I mentioned how much of a laugh I get out of some of the Signatures on here!
            I hadn't foreseen the potential for softcore pornography ! ๐Ÿคฃ
              Some nurbs tools arrive in Su! โ˜€ ๐Ÿ˜Ž
              Bravo! ๐Ÿ‘
              • C
                Click Draw
                Yes....this script will be a very good ASSet to my collection! ๐Ÿ˜„
                • mitcorbM
                  mitcorb
                  Congratulations, TIG!!!
                  I am anxious to try this out!!!
                  I can only imagine the level of difficulty you may have encountered.
                  • utilerU
                    utiler
                    Awesome TIG!!!!!!
                    Just Curious...
                      Seems that works like a charm ๐Ÿ˜„
                      Crashed if Rail1 is clicked first ๐Ÿ˜ฎ
                      I think that's because the profile (now rail1) would need to be infinitely small where the two rails (profile+rail2) meet... I think it's trying to make tiny faces in the 'corner'... I know of this glitch and I am looking at ways of trapping it - it's not 'foolproof' yet ! ๐Ÿ˜‰
                      Meanwhile use logically... ๐Ÿ˜
                        • P
                          pav_3j
                          really beautiful, thank you so much.
                          i used it with the BZ toolbar, and you can set the segment amout for the line at the start which is a real time saver!
                          thank you again
                          pav
                          Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
                            Next will be Coon'Surface? โ˜€
                            (just add the oposite profile as Rail 3 ๐Ÿ˜„
                              Pilou ! ๐Ÿ˜
                              One step at a ๐Ÿ˜‰ time...
                              • E
                                Ecuadorian
                                Pilou, you want SketchUp to become MoI. Each one has its own. ๐Ÿ˜„
                                -Miguel Lescano
                                  Now there are distant cousins ๐Ÿ˜„
                                  If you take the previus 3 curves without connection between them you will obtain these flying fishes ๐Ÿ˜„
                                  (click image if scrollbar)
                                  • T
                                    tomot
                                    Looks like it has a lot of potential, ๐ŸŽ‰ I have not had time to try it yet.
                                    I was wondering if you had included, "Triangulate" or "Quad" face options?
                                    cheers!
                                    my plugins
                                    tomot
                                    • N
                                      notareal
                                      • K
                                        kostas_designer
                                        A force of SU nature!!
                                        Really cool!
                                        Great job, Tig! ๐Ÿ‘
                                        Here is some first trying:
                                          Humhum ๐Ÿ˜‰
                                          Seems we must have possibility to reverse rails before apply the plug! ๐Ÿ˜ฎ
                                          [attachment=0:1pr20x36]<!-- ia0 -->falsebug.png<!-- ia0 -->[/attachment:1pr20x36]
                                          I am looking how to fix this within the script - to fix it manually for now use scale -1 on the profile about the profile's centre...
                                            Humhum ๐Ÿ˜‰
                                            false_bug.skp
                                            • 19
                                            • 20
                                            • 1 / 20
