    Copy Array Along Path tool...have a look.
    46 Posts 15 Posters 123.7k Views 15 Watching
      Should try that with Remus' catenary curve...
      • Bob JamesB
        Bob James
        Thank you Simon: I can really understand the process now.
        However, you and I have a different definition of "fast and easy". 😆
        • simon le bonS
          simon le bon
          [plugin]Simple Catenary Curve
          ../ this is done.
          (I will explain latter-- 'm tired)
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray018th.jpg
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray019th.jpg
          Have a good night SCF fellows *s
          • C
            Click Draw
            Anyone care to figure out what I am doing wrong. Not quite sure the proper setting for the axis on the component...See attached.
            Thanks,
            Jeff
            segment_component.skp
            Have I mentioned how much of a laugh I get out of some of the Signatures on here!
            • C
              Click Draw
              That is great! I believe I understand. Basically, position the axis in the center so that the front and back end pivot at the same angle. I assume you just have the adjust the first and last component so they line up properly? Thanks again. I'll try it again. Merci Simon!
              Cheers,
              Jeff
              • Chris FullmerC
                And drawing inspiration from this thread, I just wrote a quick little script called component stringer. You can download it here:
                404 Not Found
                (forums.sketchucation.com)
                It does essentially what Simon is showing.
                • simon le bonS
                  simon le bon
                  Hi Jeff (big work had taken me out of reply)
                  Thank you for trying. It is interesting because it shows me what I have to explain further (but it's a "WorkInProgress" also to me! 😆 ).
                  The very basic theory to understand is that our components are not aligned to segments of the curve but are drop on faces (perpendicularly ).
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray021th.jpg
                  You have focused an important point: the first and last faces are perpendicular to first and last segment of the curve. So they represent a particular case. If we want a very precise result, we have to realign them with the same angle of the others 😉
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray022th.jpg
                  Second thing important to understand in doing this way: The process remain aproximativ . Not depending of the variations of the curve, the welding is "à peu près"!!
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray023th.jpg
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray024th.jpg
                  Your component was empty from axes and significant Construction Points. I have added them.
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray025th.jpg
                  Your are right. The position of component's axes is absolutely fundamental. the good origin is pointed to be positioned on the apex of the triangles(?english~~)
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray026th.jpg
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray027th-1.jpg
                  Your curve, your component, your chain!
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray028th.jpg
                  😉 simon.
                  • E
                    Ecuadorian
                    Thank you, Chris! 👍
                    -Miguel Lescano
                    • simon le bonS
                      simon le bon
                      Hi Chris,
                      It's a great pleasure to discover that you were looking apart silently and suddenly come to drop a top cool tool! Component Stringer
                      You have decided to make the components follows the lines rather than faces.
                      @chris fullmer said:
                      Was TIG working on something that would replace a single line with a component and use the line scale and orientation to determine the scale and orientation of the component? Something about that sounds familiar...
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer001th.jpg
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer002th.jpg
                      The result is that this tool is wonderful for necklaces
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer008th.jpg
                      And we have not to use it for imbricated components
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer006th.jpg
                      One more time, many thanks to you dear Chris,
                      *simon
                      • E
                        Ecuadorian
                        So, Jeff, how is that SketchUp model of Doc Ock coming along? 😄
                        -Miguel Lescano
                        • C
                          Click Draw
                          Hey Miguel,
                          I might be able to do the arms now but I'll still suck at modeling Doc Oc. I need to put way more hours in to organic shape modeling!!! 😞
                          Hope everyones weekend is going well....
                          Cheers,
                          Jeff
                          • E
                            Ecuadorian
                            Have you tried importing a Make Human model into Wings 3D or Silo and tweaking there? Then you can import the Wings 3D model to SU and add the robotic arms.
                            -Miguel Lescano
                            • C
                              Click Draw
                              I'll for sure check those out, thank you. I would still like to get decent at organic in Sketchup though. Here is a quick try at Chris's new ruby. I love it! Nice to be able to edit the component and see it update instantly. Thanks again Chris!
                              Jeff
                              • simon le bonS
                                simon le bon
                                I pursue the study of my proceeding despite Chris's "Component Stringer" because for the moment(But Chris is working to the speed of the iron horse!!), I think I can master better -the welding of components imbricated, -the mix of various components along the path, _the mix of components following the path with components invariant in orientation.
                                Here is a realtime video (no editing) to show how fast is the process.
                                We start with a curve and a component.
                                http://i274.photobucket.com/albums/jj245/Spendauballet/videos/copyarrayalongpath04.gif
                                *simon
                                • simon le bonS
                                  simon le bon
                                  Some help to produce the component to copy along a path.
                                  I)Put the good axes:
                                  If it is for you like for me 😳 , positionning axes of the component I want to copy along a path is not so evident.
                                  So, make a cube, make it as a component, and......
                                  [flash=500,405:284ps2pd]http://www.youtube.com/v/z81CNzCE4V0[/flash:284ps2pd]
                                  II)How to conceive a chain link:
                                  Using one or other method to produce a chain, necklace and many others fences and so on, you will need to think about the shape of the links.
                                  Here is my tip. Just think to draw a portion of curve with the smallest radius you think you are going to use for your path...
                                  [flash=500,405:284ps2pd]http://www.youtube.com/v/PG8aK7fC2LA[/flash:284ps2pd]
                                   :wink: simon
                                  • Y
                                    yiannosh
                                    Can anyone help me how to download the ruby. It's my first visit to the forum ...
                                    Thanks,
                                    YiannosH
                                    • simon le bonS
                                      simon le bon
                                      Hi YiannosH
                                      A Fresh Welcome to you in our SketchUp Community.
                                      Chris Fullmer's "Component Stringer"
                                      And here all Chris's Plugins:
                                      ++simon
                                      • simon le bonS
                                        simon le bon
                                        The "How To" of my suspension bridge.
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_CopyArray019.jpg
                                        Three Components and One curve.
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray031th.jpg
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray032th.jpg
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray033th.jpg
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray034th.jpg
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray035th.jpg
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray036th.jpg
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray037th.jpg
                                        Et Voila! 😆
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray038th.jpg
                                        Remus_Simple Catenary Curve
                                        ChrisFullmer Plugins
                                        Weld.rb v:3.0
                                        Jim_Construction Line Tool
                                        DBur_Lines to tubes
                                        Kirill _ 2 Faces + Path ver. 1.4
                                        Fredo_BezierSpline v1.21
                                        [url=http://forums.sketchucation.com/viewtopic.php?f=180&t=19457:2hagrkqi]TIG_TrueTangents v1.9[/url:2hagrkqi]
                                        • N
                                          notareal
                                          Great tutorial. Worth to copy for safe keeping!
                                          • simon le bonS
                                            simon le bon
                                            Hi NotaReal!
                                            You are greatly helping me for my first feet steps with Kerkythea.
                                            Here are some renders dedicated to you 😉 😉
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/KerkyThea/clay_tstD003_th.jpg
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/KerkyThea/clay_tstD004_th.jpg
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/KerkyThea/clay_tstD005_th.jpg
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/KerkyThea/clay_tstD006_th.jpg
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/KerkyThea/clay_tstD007_th.jpg
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/KerkyThea/SuspBridge003_th.jpg
                                            ++simon
                                            • 2 / 3
