    Copy Array Along Path tool...have a look.
    46 Posts 15 Posters 123.7k Views 15 Watching
    • simon le bonS
      simon le bon
      Hi Rocky
      Please take it and make it at your convenience 😉
      (click the pic for Skp)
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_CopyArray013th.jpg
      ../sim
      • simon le bonS
        simon le bon
        Playing with the process..
        (easy and fast)
        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray014th.jpg
        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray015th-1.jpg
        (two components made with the same 60° rotated)
        *s
        • Bob JamesB
          Bob James
          @simon le bon said:
          (easy and fast)
          Is your "easy and fast" the same eight-step process in your previous post or have you come up with a real "easy and fast"?
          • P
            pav_3j
            simon you are a master of getting the best results using methods most don't think of!
            i'm still a little confused by the process, but i'll get there!
            pav
            Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
            • P
              pav_3j
              ah i get it now simon, thank you very much for the written explaination.
              i think one thing you may have missed out (as i understand it) is that the amount of steps you have to take with the 2 faces and a path tool, must equal the amount you have segmented the curve by, or the faces will not end up on the end point of each line.
              correct?
              thank you again.
              pav
              • C
                Click Draw
                Very clever Simon....I'll be trying this for sure!
                Thanks,
                Jeff
                PS: I wonder if it would be possible to have a ruby called "Replace segment with Component"...nah....I doubt that could be written 😉
                Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                • Chris FullmerC
                  Was TIG working on something that would replace a single line with a component and use the line scale and orientation to determine the scale and orientation of the component? Something about that sounds familiar...
                  • C
                    Click Draw
                    I sure hope someone is working on something like that. That would be an awesome ruby. What you could model and the time saved would be great! My eyes will be glued to this thread...
                    Cheers....
                    • simon le bonS
                      simon le bon
                      Hi Bob and Pav,
                      I'm confused because in following my own idea I was sure to have described the process in its simplicity!! Your two comments tell enough I was wrong.
                      I am going to try to explain better , "pardon pour mon anglais".
                      I)My main idea is that we need to prepare the curve we intend to be the path along which we want to copy our elements. Because what we need is a curve made of
                      -a)an exact number of segments
                      or
                      -b)a curve divided by segments of a precise length.
                      1)If we make our "path" using arc tool or/and line tool or/and bezier spline we need to make it first a "clean curve". This is made by the help of "Weld".
                      2)Once this is accomplish, we are going to convert this curve as a well wanted segmented polyline. this is made with underknown features which go with "BezierSpline" . When you select the curve, you can choose by right-clic context menu 😆 Convert to: Polyline Divider (if you wish to divide your curve by segments of exact length) or Polyline Segmentor (if you want to divide this curve by a specific number of equals segments.)
                      II)My second idea is to use "2Faces + Path" plugin in an unusual way. This plug is first intending to drive a transformation from a face to another one. My idea is to use it with no transformation! the first and the last face are the same! So this face is going to be dispatched in one clic all along the path in between the segments.
                      Re: to simplify the process I use "Perpendicular Face tools" to put in place with a clic those first and last faces, but we can do without it. (in particular when we want to use a complex face)
                      III)My third idea is to use "Components onto Faces" to replace those faces by the component I want. One more time in just a clic and, as the faces remain selected, I can delete them with one push on "Del" .
                      Re: if I want to dispatch various components like in the case of my chain, I copy the same number of the path+faces and I delete by hand the faces I don't want to follow the component. And I assemble them at the end.
                      Re: the main tip is to play foxy with "modify axes" inside components.
                      In summary:
                      1)drawing the curve
                      2)make it clean (weld)
                      3)make it a divided polyline (BezierSpline: Polyline Divider or Segmentor)
                      4)put the first an last face (Perpendicular face tools)
                      5)put a face at each segment intersection (2Faces + Path)
                      6)replace faces by components.
                      (I have some others ideas to develop the process, I shall tell latter 😉 )
                      simon.
                        Hi Chris,
                        This "Replace with Component" idea is extremely exciting. Do you think Fredo's 'GhostComp' could hold some clues on implementing this? I know zero about Ruby Scripting but use Fredo's alot to help keep things running smoothly.
                        I realise it needs a component to create various versions of that component and hide the original. But could this be reversed to reference a component from a simple line?
                          If your segment is a component you don't need a ruby 😉
                          I believe exist a ruby that transform a selection of elements in Components 😉
                          So select your elements (here segments)
                          transform them in components
                          Replace your component by any other component you want
                          Et voila 😎
                          • simon le bonS
                            simon le bon
                            some few more details of explanation:
                            When I need
                            . For I have to dispatch elements with a definite length along the path, it is going to remain an under sized segment from "Polyline Division". I delete this extra one before go further.
                            When I use "Perpendicular Face Tools" to put a face at each end of the curve, those faces are grouped. I ungroupe them in order to make them as available faces with "2Faces + Path".
                            pav
                            thank you pav)
                            correct?
                            "2Faces + Path" dispatch automatically the faces at each intersection in one pass. This is the very good point!!
                            It dispatches exactly (n+1) faces: a face at each intersection + a face at two endpoints of the curve.
                            So we have to delete the two previous faces we have put to initialize "2Faces + Path" process.
                            important remark: "Perpendicular Face Tools" and "2Faces + Path" doing the same, are dispatching the faces oriented at the mid angle between each two segments, and in a perpendicular angle for end lines..
                            another very interesting feature is the ability of this plug to dispatch faces as they are aligned to path or not aligned to path. I will show in another post how it can be interesting to mix invariant oriented elements with elements following the path like in a barrier, a suspension bridge...
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray016th.jpg
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray017th.jpg
                            thank you man! 😉 )
                            In this case I think that orienting a face is an easiest way than orienting a line !?
                            *simon
                              Should try that with Remus' catenary curve...
                              • Bob JamesB
                                Bob James
                                Thank you Simon: I can really understand the process now.
                                However, you and I have a different definition of "fast and easy". 😆
                                • simon le bonS
                                  simon le bon
                                  [plugin]Simple Catenary Curve
                                  ../ this is done.
                                  (I will explain latter-- 'm tired)
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray018th.jpg
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray019th.jpg
                                  Have a good night SCF fellows *s
                                  • C
                                    Click Draw
                                    Anyone care to figure out what I am doing wrong. Not quite sure the proper setting for the axis on the component...See attached.
                                    Thanks,
                                    Jeff
                                    segment_component.skp
                                    • C
                                      Click Draw
                                      That is great! I believe I understand. Basically, position the axis in the center so that the front and back end pivot at the same angle. I assume you just have the adjust the first and last component so they line up properly? Thanks again. I'll try it again. Merci Simon!
                                      Cheers,
                                      Jeff
                                      • Chris FullmerC
                                        And drawing inspiration from this thread, I just wrote a quick little script called component stringer. You can download it here:
                                        404 Not Found
                                        (forums.sketchucation.com)
                                        It does essentially what Simon is showing.
                                        • simon le bonS
                                          simon le bon
                                          Hi Jeff (big work had taken me out of reply)
                                          Thank you for trying. It is interesting because it shows me what I have to explain further (but it's a "WorkInProgress" also to me! 😆 ).
                                          The very basic theory to understand is that our components are not aligned to segments of the curve but are drop on faces (perpendicularly ).
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray021th.jpg
                                          You have focused an important point: the first and last faces are perpendicular to first and last segment of the curve. So they represent a particular case. If we want a very precise result, we have to realign them with the same angle of the others 😉
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray022th.jpg
                                          Second thing important to understand in doing this way: The process remain aproximativ . Not depending of the variations of the curve, the welding is "à peu près"!!
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray023th.jpg
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray024th.jpg
                                          Your component was empty from axes and significant Construction Points. I have added them.
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray025th.jpg
                                          Your are right. The position of component's axes is absolutely fundamental. the good origin is pointed to be positioned on the apex of the triangles(?english~~)
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray026th.jpg
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray027th-1.jpg
                                          Your curve, your component, your chain!
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray028th.jpg
                                          😉 simon.
                                          • E
                                            Ecuadorian
                                            Thank you, Chris! 👍
                                            -Miguel Lescano
                                            • 2 / 3
