    Copy Array Along Path tool...have a look.
    46 Posts 15 Posters 121.6k Views 15 Watching
    • simon le bonS Offline
      simon le bon
      @thomthom said:
      Should try that with Remus' catenary curve...
      [plugin]Simple Catenary Curve
      ../ this is done.
      (I will explain latter-- 'm tired)
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray018th.jpg
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray019th.jpg
      Have a good night SCF fellows *s
        Click Draw
        Anyone care to figure out what I am doing wrong. Not quite sure the proper setting for the axis on the component...See attached.
        Thanks,
        Jeff
        segment_component.skp
        Have I mentioned how much of a laugh I get out of some of the Signatures on here!
          Click Draw
          That is great! I believe I understand. Basically, position the axis in the center so that the front and back end pivot at the same angle. I assume you just have the adjust the first and last component so they line up properly? Thanks again. I'll try it again. Merci Simon!
          Cheers,
          Jeff
          • Chris FullmerC Offline
            And drawing inspiration from this thread, I just wrote a quick little script called component stringer. You can download it here:
            http://forums.sketchucation.com/viewtopic.php?f=180&t=23616
            It does essentially what Simon is showing.
              simon le bon
              Hi Jeff (big work had taken me out of reply)
              Thank you for trying. It is interesting because it shows me what I have to explain further (but it's a "WorkInProgress" also to me! 😆 ).
              The very basic theory to understand is that our components are not aligned to segments of the curve but are drop on faces (perpendicularly ).
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray021th.jpg
              You have focused an important point: the first and last faces are perpendicular to first and last segment of the curve. So they represent a particular case. If we want a very precise result, we have to realign them with the same angle of the others 😉
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray022th.jpg
              Second thing important to understand in doing this way: The process remain aproximativ . Not depending of the variations of the curve, the welding is "à peu près"!!
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray023th.jpg
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray024th.jpg
              Your component was empty from axes and significant Construction Points. I have added them.
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray025th.jpg
              Your are right. The position of component's axes is absolutely fundamental. the good origin is pointed to be positioned on the apex of the triangles(?english~~)
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray026th.jpg
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray027th-1.jpg
              Your curve, your component, your chain!
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray028th.jpg
              😉 simon.
              • E Offline
                Ecuadorian
                Thank you, Chris! 👍
                -Miguel Lescano
                  simon le bon
                  Hi Chris,
                  It's a great pleasure to discover that you were looking apart silently and suddenly come to drop a top cool tool! Component Stringer
                  You have decided to make the components follows the lines rather than faces.
                  @chris fullmer said:
                  Was TIG working on something that would replace a single line with a component and use the line scale and orientation to determine the scale and orientation of the component? Something about that sounds familiar...
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer001th.jpg
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer002th.jpg
                  The result is that this tool is wonderful for necklaces
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer008th.jpg
                  And we have not to use it for imbricated components
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer006th.jpg
                  One more time, many thanks to you dear Chris,
                  *simon
                  • E Offline
                    Ecuadorian
                    So, Jeff, how is that SketchUp model of Doc Ock coming along? 😄
                    -Miguel Lescano
                      Click Draw
                      Hey Miguel,
                      I might be able to do the arms now but I'll still suck at modeling Doc Oc. I need to put way more hours in to organic shape modeling!!! 😞
                      Hope everyones weekend is going well....
                      Cheers,
                      Jeff
                      • E Offline
                        Ecuadorian
                        Have you tried importing a Make Human model into Wings 3D or Silo and tweaking there? Then you can import the Wings 3D model to SU and add the robotic arms.
                        -Miguel Lescano
                          Click Draw
                          I'll for sure check those out, thank you. I would still like to get decent at organic in Sketchup though. Here is a quick try at Chris's new ruby. I love it! Nice to be able to edit the component and see it update instantly. Thanks again Chris!
                          Jeff
                            simon le bon
                            I pursue the study of my proceeding despite Chris's "Component Stringer" because for the moment(But Chris is working to the speed of the iron horse!!), I think I can master better -the welding of components imbricated, -the mix of various components along the path, _the mix of components following the path with components invariant in orientation.
                            @bob james said:
                            However, you and I have a different definition of "fast and easy". 😆
                            Here is a realtime video (no editing) to show how fast is the process.
                            We start with a curve and a component.
                            http://i274.photobucket.com/albums/jj245/Spendauballet/videos/copyarrayalongpath04.gif
                            *simon
                              simon le bon
                              Some help to produce the component to copy along a path.
                              I)Put the good axes:
                              If it is for you like for me 😳 , positionning axes of the component I want to copy along a path is not so evident.
                              So, make a cube, make it as a component, and......
                              [flash=500,405:284ps2pd]http://www.youtube.com/v/z81CNzCE4V0[/flash:284ps2pd]
                              II)How to conceive a chain link:
                              Using one or other method to produce a chain, necklace and many others fences and so on, you will need to think about the shape of the links.
                              Here is my tip. Just think to draw a portion of curve with the smallest radius you think you are going to use for your path...
                              [flash=500,405:284ps2pd]http://www.youtube.com/v/PG8aK7fC2LA[/flash:284ps2pd]
                               :wink: simon
                              • Y Offline
                                yiannosh
                                Can anyone help me how to download the ruby. It's my first visit to the forum ...
                                Thanks,
                                YiannosH
                                  simon le bon
                                  Hi YiannosH
                                  A Fresh Welcome to you in our SketchUp Community.
                                  Chris Fullmer's "Component Stringer"
                                  And here all Chris's Plugins:
                                  ++simon
                                    simon le bon
                                    The "How To" of my suspension bridge.
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_CopyArray019.jpg
                                    Three Components and One curve.
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray031th.jpg
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray032th.jpg
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray033th.jpg
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray034th.jpg
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray035th.jpg
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray036th.jpg
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray037th.jpg
                                    Et Voila! 😆
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray038th.jpg
                                    Remus_Simple Catenary Curve
                                    ChrisFullmer Plugins
                                    Weld.rb v:3.0
                                    Jim_Construction Line Tool
                                    DBur_Lines to tubes
                                    Kirill _ 2 Faces + Path ver. 1.4
                                    Fredo_BezierSpline v1.21
                                    [url=http://forums.sketchucation.com/viewtopic.php?f=180&t=19457:2hagrkqi]TIG_TrueTangents v1.9[/url:2hagrkqi]
                                    • N Offline
                                      notareal
                                      Great tutorial. Worth to copy for safe keeping!
                                      Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                                        simon le bon
                                        Hi NotaReal!
                                        You are greatly helping me for my first feet steps with Kerkythea.
                                        Here are some renders dedicated to you 😉 😉
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/KerkyThea/clay_tstD003_th.jpg
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/KerkyThea/clay_tstD004_th.jpg
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/KerkyThea/clay_tstD005_th.jpg
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/KerkyThea/clay_tstD006_th.jpg
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/KerkyThea/clay_tstD007_th.jpg
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/KerkyThea/SuspBridge003_th.jpg
                                        ++simon
                                        • 2 / 3
