    ๐Ÿ›ฃ๏ธ Road Profile Builder | Generate roads, curbs and pavements easily Download
    [Preview] UVTools 0.2
    74 Posts 23 Posters 12.3k Views 23 Watching
    • W Offline
      Whaat
      So a long time ago (probably close to a year now) I was trying to come up with a solution to the lack of UV mapping tools in SketchUp. Sure, I could probably create a plugin that did the basics (cylindrical, spherical, planar, cubic, and some simple transformations) but it wasn't a complete solution. Complex organic shapes would still be impossible to map without implementing seam selection and a complex unwrapping algorithm.
      So instead, I started experimenting with exporting/importing to external UV mapping software. I tried a few (Roadkill, Blender, Lithunwrap, and Ultimate Unwrap3D) and the one that was the easiest to implement, and had the most features was Ultimate Unwrap3D (U3D).
      My plugin will export the selected faces to OBJ which is then imported into U3D to do the mapping. After you are done mapping, you just import the OBJ back into SketchUp using the plugin. However, only the UVs will be imported so the geometry in your scene will not be affected. (It also allows the import process to be quite fast)
      The amount of tools in U3D is just awesome! It is a complete UV mapping package and the best one I have found. I'm afraid it does come with a price but it's not too steep. My plugin will most certainly be free, though.
      This plugin has been sitting unfinished for a very long time. It is still not quite to the level that I would like but after reading over and over again about the complaints about the lack of UV mapping tools in SketchUP, I thought that I would spend a bit of time cleaning up the plugin and release it anyway. So, you can expect it to be released very soon, probably less than two weeks. (I hope ๐Ÿ˜‰ )
      [flash=425,344:7ryf9b18]http://www.youtube.com/v/oMVh-KSOHsw&hl=en&fs=1[/flash:7ryf9b18]
        Khai
        oh my.
        WANT
        โ˜€
        • jeff hammondJ Offline
          whaat the?!
            remus
            That looks like fun ๐Ÿ˜„ so many questions!
              Ah, you made a bridge to Ultimate Unwrap Pro? http://www.unwrap3d.com/u3d/index.aspx
                Ultra Violet ๐Ÿ˜Ž
                  tomasz
                  It looks nice. When I saw a preview I thought you have split the SU window in half ๐Ÿ˜„
                  I presume this should work also with other software, say Blender, which allows to save the UV-mapped OBJ model, am I right?
                  Tomasz
                  Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
                  • FrederikF Offline
                    Frederik
                    Whaat the... ๐Ÿ˜ฎ ๐Ÿ˜ฒ
                    This sure looks AWESOME...!!
                    Can you "spill some beans" and let us know anything about an expected date of release...??
                    Also... I assume that you already have an idea about the price for this... ๐Ÿ˜•
                    Cheers
                    Kim Frederik
                    • N Offline
                      notareal
                      Would be great to have this functionality inside the SU without a external program.
                      Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                        @kwistenbiebel said:
                        It looks to be inside Sketchup or am I missing something here?
                        You start out in SU, then it exports the geomtry to an external UVunwrap mapper, and then back to SU again.
                          kwistenbiebel
                          Great work whaat! Looks very good.
                          Is it going to be free?
                          • N Offline
                            notareal
                            With a quick look the unwrap3d do have a skp importer, but this is far better work flow.
                              kwistenbiebel
                              That's good enough for me ๐Ÿ˜„
                              In the video the whole process seems to be working seamlessly.
                              • FrederikF Offline
                                Frederik
                                Like Stinkie, I assume it won't be a "freebie"...
                                If it's really based on the UVunwrap mapper like Thomas is saying I'm certain it won't be free...
                                Unwrap 3D is in the 50-60 USD range, and although this might be a special SDK, I assume the price for the plug-in will be close to that price range...
                                Only Whaat knows... ๐Ÿ˜‰
                                Cheers
                                Kim Frederik
                                  remus
                                  If ever a plugin was worth forking out for this would be it.
                                    I don't think it's a special SDK. Nor is it even "based" on Ultimate UVwrap. It is Ultimate UVwrap. The user would need Ultimate UVwrap - then this plugin acts as a bridge to transfer geometry back and forth. That's what it looked like from the video.
                                    ...so anyone in for a bet until Whaat gets here? ๐Ÿ˜„
                                    • soloS Offline
                                      Sweet!!
                                      If it's a bridge, and free then I would hope Dale has a link for us users to purchase U3D where he can get some sort of commission. It would be only fair for both him and the company as this bridge opens up a huge market for them.
                                        If Whaat could also pay a visit to Asgvis, Next Limit and Glare Technology, we would finally see some decent Sketchup bridges appear for the mainstream render engines. ๐Ÿ˜„
                                        Easier said than done. They all have to deal with that Sketchup exposes in the API - which isn't always ideal.
                                          Khai
                                          hold on.
                                          won't this also mean you could create your model, UVmap it.. then instead of bring it back into SU, export it to another format right off?
                                          Unrwap's got an impressive list of formats it'll export to...
                                          • StinkieS Offline
                                            Stinkie
                                            I'm guessing 'no'. I wouldn't just give this one away. ๐Ÿ˜„
                                            • 1 / 4
