    [Plugin] Camera Recorder v1.7.2 UPDATED May 23, 2013
    136 Posts 32 Posters 262.5k Views 32 Watching
    • plot-parisP Offline
      plot-paris
      great little tool. now at last I can put my space navigator to some real use πŸ˜„
      I especially like the fact, that the plugin only saves the camera position and orientation, but ignores layer visibility, shadow settings etc. thus one can switch off everything that slows down the model, record the camera motoin, then switch on all the fancy stuff and export the animation.
      I have got two ideas to make this tool truely powerful (kwistenbiebel would love it):
      • option to export the camera motion as a path - camera path and target path, either with a vertex for every frame or as a 'smoothed' version via splines...
      • a replay button to review the camera motion, ideally with the option to take changes to the camera path into account
      like that one could create an animation (e.g. with space navigator) intuitively and then refine it manually by accessing the camera path...
      • Chris FullmerC Offline
        Great Modelhead, thanks! I'll include those in the next release.
        As for exporting the path, etc. Yes, that would be cool. I can export the path easy enough. Its just creating an intuitive, useful way to edit it, and then have the plugin recognize it to update the recording. So I'll keep thinking about it.
        And a replay button is in order here I think. I'll see if I can get that included in the next release also.
        Thanks for the comments and encouragement folks.
        Also, a big thanks to Jim for a bit of help with the folders and paths!
          Here's some button pngs - they'll need renaming...Recorder Icons.zip
            Metro Goldwyn Maeyer πŸ˜‰
              Well its coming along pretty well so far. I've got the filename improvements implemented - thanks for the code TIG!
              I've got it so it can replay the animation in SU. I fixed the pause at the beginning of the animation. I even made it export a series of construction points for the location and target of each frame.
              But I still don't have a great way to make it so that you can alter the animation by moving the construction points. I have some ideas, but most seem like overkill so far.
              Anyhow, we'll see if I come up with something that works before bedtime. Hopefully I'll have a new version posted, with a video within 6 or 7 hours.
              • soloS Offline
                Dang!!
                Thanks a bunch, this is why SU still rocks.
                  plot-paris
                  wow, that sounds brilliant, Chris. can't wait for the update! πŸŽ‰ (would you mind posting the date of the update in the title of this thread? that makes it easier to check).
                  about the path editing thing: it probably doesn't make too much sense to edit the position points one by one (if you've got 24 fps, that would mean a lot of work).
                  one solution might be to employ fredo's cubic bezier curve (with the necessity of installing that plugin though) and place control vertexes at a chosen interval (like once per second, setting the precision of the curve to fill in 24 edges between the control points).
                  that would of course result in a smoothing of the path and might lead to unwanted results, when the camera motion changed speed quickly at some point (because then the bezier curve will create weird loops).
                  maybe there could be different options (the smoothed path output via cubic bezier curve or a true path output with every vertex unchanged (e.g. polyline)).
                  would definitely be interesting to see the influence of the smoothing process on the final output. might make the whole animation a bit nicer (like steady shot with physical camera). on the other hand one might lose the particular feeling of the 'handmade' animation...
                  I have to say I am really excited about this plugin! thank you so much Chris, for doing this πŸ‘
                    Yeah, all those thoughts about path smoothing are going through my head too. How to smooth it, but not too much, but a little.....etc.
                    Well for now I've added an option to show construction points at each frame and target. Its interesting to see for sure.
                    I don't know how to make the recorded path editable in a useful way...I'll keep thinking though.
                      UPDATED Nov 11, 2009
                      UPDATES v 1.5
                      • Fixed the lag bug that occured in the beginning of each recording
                      • Added more user feedback when buttons are pressed in the wrong order
                      • Added the abilty to control image output height, width and anti-aliasing
                      • Added better file names so that more software will correctly order the image frames
                      • Added a recording playback button, so that recordings can be played back before exporting.
                      • Added a tool to place constructions points at the location of each frame, with another construction point where the camera is pointing.
                      • Added some new icons, but they still need help.
                      As promised, I got a chance to update this script tonight. The icons are silly. I added more icons to the toolbar since Modelhead and TIG provided some icons, so their packs didn't quite work entirely. So its a mish-mash of icons for now.
                        Wow. You're steaming! πŸ‘ πŸ‘
                        (p.s. maybe update the thread title to reflect 1**.5**?)
                          Thanks Thom, Title updated! I've had a little down time at work and free time at night, so I've been able to spend some time on this. Its been fun to write.
                          I also made a video right now, but it is still processing on youtube. So in the morning I'll try to get it posted to the first post in the thread. Or it might be up in an hour or so if anyone wants to see it beofre I post it:
                            plot-paris
                            hey Chris. I am afraid, the buttons of the toolbar end up blank.
                            the zip file, you posted contains a ruby file called 'clf_center_on_origin.rb' and a folder with the Camera Recorder files.
                            within this folder there is the camera recorder ruby, several images and an empty folder called 'images'.
                            but no matter, where I placed the images (within the images folder. or the images folder directly in the plugins folder) it doesn't seem to be working 😞
                            • PixeroP Offline
                              Pixero
                              Brilliant. Thanks! You know I've been ranting about the lack of animation tools in SU. What a great start.
                              Create curves looks very interesting. A lot of potential there.
                              Could you add a w,a,s,d key flying/walking camera tool since the walk tool is so bad? πŸ˜‰
                              Also adjustable playing speed to watch it in slowmotion for finding problems or quirks.
                              Another way of getting precise camera movement would be to be able to position the camera for "key" frames and then have the script to add the inbetweens based on a given speed (meter/second). As I said LOTS of possibilities there...
                              • E Offline
                                Ecuadorian
                                I like where this is going. πŸ˜„ πŸ‘
                                Pixero, I don't think this plugin is about new navigation controls, just recording what you see, at least for now.
                                But if you do implement new navigation controls, Chris, perhaps C. Philips could contribute some game controller code from SketchyPhysics. πŸ˜›
                                -Miguel Lescano
                                  Hey, thats great Modelhead!
                                    It motoring... 😍
                                    What next ?
                                      Next will be to save, export and import animations from one model to the next. I'm planning on writing simple csv files that can be easily written and read.
                                      I'd love to improve the file save dialog window.
                                      @Equadorian - Sketchyphysics has game controller code? If you install SP, you can control SU with a game controller? If so, then I would'nt need to include it in the script. You can start recording and then navigate with his controller and my plugin will still record it.
                                      • Mike LuceyM Offline
                                        Mike Lucey
                                        Thanks for the video Chris. Hey you have quite a talent for voice overs, very natural with a nice flow and easy to follow πŸ‘
                                        Its looks like you have excellent colaborators coming on board for CR that will make it a super easy to use animation output tool.
                                        Mike
                                        • ely862meE Offline
                                          ely862me
                                          Impressive!! Well done!
                                          Thank you!
                                          Elisei
                                          Elisei (sketchupper)
                                          Come and See EliseiDesign
                                          • E Offline
                                            Ecuadorian
                                            Chris, the game controller code is there but the user must implement it. There are entire videogames made using SketchyPhysics.
                                            Now I regret having sold my XBOX 360 wired controller. Oh, well.
                                            -Miguel Lescano
                                            • 6 / 7
