    [Plugin] importDXFtext
    165 Posts 18 Posters 105.8k Views 18 Watching
    • CadFatherC Offline
      CadFather
      Thanks TIG, if it works is one of those musts
        if it works ! Of course it works ! Of course it could be improved.... but this is its first release ! πŸ˜‰
        Comments and feed back please... So far 27 down-loaders - 1 comment ?
          CadFather
          πŸ˜„
          TIG i think a menu would be a nice addition.. ..might make testing simpler
          first try:
          Making 0 TEXT Entities...
          Making 144 MTEXT Entities...
          Error; #<TypeError; C;/Program Files/Google/Google SketchUp 7/Plugins/_importDXFtext.rb;909;in `bounds'; reference to deleted DrawingElement>
          true
          must be something i missed
          • Mike LuceyM Offline
            Mike Lucey
            Thanks TIG,
            I haven't had a need to import DXF text of late but have have (a lot) in the past, so this will be bloody useful and a big time saver when I need it again πŸ‘
            I have no doubts that it will work perfectly πŸ˜‰
            Mike
              @cadfather said:
              πŸ™‚
              first try:
              > true
              The next version will have a menu item.
              The error you report seems to be caused by having a piece of Mtext that's only a <space> and no actual characters to make into a group - I'll trap for that so the error is ignored - watch out for an update later today...
                Panga
                Thanks a lot for this one...long time wanted !!
                  Here's v1.1 that has a menu item and the empty string glitch fixed...
                  http://forums.sketchucation.com/viewtopic.php?p=194488#p194488
                    CadFather
                    Thanks TIG - i get this error.. but i will try other files as well
                    Error; #<TypeError; C;/Program Files/Google/Google SketchUp 7/Plugins/_importDXFtext.rb;923;in `bounds'; reference to deleted DrawingElement>
                      I reproduced the error occur by having a piece of Mtext with only a space or carriage-return in it. That's trapped - must be something similar although I thought I'd trapped all calls for bounds etc if the group wasn't valid? Please see if you can find what's causing the problem and report back - it can't be that hard to trap for if we know what it is ! πŸ’­
                        Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=194488#p194488
                        It should stop some of those errors - please try and feed back...
                        Empty strings are now show with a Cpoint, the grouped text does not cast or receive shadows and the VCB now shows progress as well as the Console if preferred...
                          redsteel
                          Thank you very much for this, for once i was getting really pissed with SU but your work it's a life saver, thanks again.
                          ...btw, is there a menu version? πŸ˜„
                            Alex
                            You didn't specify the DXF's units...
                            I downloaded your file anyway
                            I got a Bugsplat importing it using 'mm'!
                            Importing it using 'm' I did get some rapid output in the Ruby Console... then an error after some importing...
                            This is everything imported Capture.PNG This is an extract of a part of it Capture1.PNG
                            The Ruby Console output failed on a layer name 'T' not being defined.
                            That layer name is used for Lines, but as far as I can see not for 'Text' ?
                            BUT then there are almost 150,000 lines of code in the DXF file [it's 'NOT BIG' 😲 ] !
                            The DXF won't load into AutoCAD at all !!! ... so I suspect it is corrupt in some way ??
                            The error is "Unknown value "AC1024" encountered in drawing version" - I only have ACAD2008 so perhaps it's made in an NEWER version? DWG convert might work if it were a DWG file... BUT it's a DXF file πŸ˜•
                            I also made a layer named 'T' before trying 'meters' for the import units and got this result - after a looooong wait - with no errors...Capture2.PNG detail Capture3.PNG I can't believe you want ALL of this text importing - try to reduce the content of the DWG>>DXF and save in an older version like r2004, as it will import cleaner and quicker... πŸ˜’
                            Could you edit the CAD file so it only contains 'text' and retry...
                              alexdobras
                              i tried to import a dxf and SU is crashing. It is not a big file.
                              you can check it out: http://dl.transfer.ro/transfer_ro-23mar-7b7d941ec2f2cc8f.zip (it expires in 10 days)
                                alexdobras
                                yeah, for some reason the file cannot import into Acad. I had a dwg, which i saved into dxf in order to work with the file in SU andBlender. Now, Blender 2.49 imports the file perfectly, i mean flawlessly with text and everything like i see it on CAD software i use: DraftSight. When i open the file in SU, the same file as in Blender, the model comes with a lot of deformations and with the text missing- I mean through SU 8 PRO native dwg/dxf importerthat comes with the pro version. No matter is dwg or dxf the file will import bad.
                                So i am using this plugin in http://forums.sketchucation.com/viewtopic.php?f=323&t=31186&start=75, which actually doesn't deform the model, but takes more time to import the file. The only problem is it doesn't import the text, and the model need to have everything exploded, so no blocks.
                                I hope you did understand about what i am talking about
                                  Sketchup doesn't import dwf/dxf text that's why I wrote the script...
                                  It is a good idea to reduce the dxf down to just the text items- it speeds the import and aaoids errors. It's easy to make a copy of the file in your CAD app and then filter to leave just the dtext/mtext etc, then purge and audit the dwg, then finally save as a ~r2004 DXF...
                                    alexdobras
                                    i have done what you said, and still SU crashes right before imports the text 😐
                                    here is the 2004 ASCII drawing.DXF , only with text (just text)
                                    btw, i have intel i5 750, 2gb ddram3, video Geforce GTS250, win7 64 bit, and SU8
                                      You have NOT trimmed down the file to include just 'Text' !!
                                      You have simply switched other layers 'off' - these are still there and so Sketchup WILL try to import them !!!
                                      Here's a properly reduced version of the DXF...TESTTEXT2004.dxf And the resultant SKP.TESTTEXT2004.skp
                                        alexdobras
                                        i tryed what you have sent me
                                        still, it crashes
                                        now see for yourself:click on TΓ©lΓ©charger ce fichier
                                        http://dl.free.fr/getfile.pl?file=/r36AYYVu
                                          BUT you tried to import it in 'mm'... I did it in 'm' - as I explained before.......
                                          I worked fine for me...
                                          WHAT are the units you are working in ... 😲
                                            alexdobras
                                            sorry TIG, i knew i forgot to change something.
                                            when putting to m , it works,
                                            but i don't understand why is crashing at mm, though.
                                            and a second one, why the file needs to be saved as 2004 ascii dxf, could;nt you make it up-to-date to ascii 2010 drawing?
                                            thanks anyways for this wonderful plugin!
                                            • 1 / 9
