    Looking ahead to SU 8.
    140 Posts 52 Posters 42.4k Views 52 Watching
    • jeff hammondJ
      @remus said:
      actually, i think this might be solvable via ruby.. can ruby do trig functions and/or aΒ²+bΒ²=cΒ² type of stuff?
      Yep, ruby can do trig functions. What did you have in mind?
      Something along these lines.... [that's just the way i think it could happen πŸ˜„... but it does kill two birds with one stone.. in SU, it's also a lot harder than it should be to draw a set length in between two other (non-parallel πŸ˜„ ) lines...
      http://homepage.mac.com/jeffhammond/.Public/scf/lineAB.jpg
        remus
        I think you need to get your calculator out jeff πŸ˜„
          remus
          Hmm, i wonder if a rotate tool could be written that could infer on lines. Perhaps put a [req] in the ruby forum?
          • jeff hammondJ
            haha.. i don't want to think of it in terms of the above but i think that's how it breaks down mathematically.. really, i just want a cpoint dropped at the intersection (point B in the drawings).. maybe there's another way to obtain this?
            here's my current workaround.. [but damn, can't google just make inferencing work here 😐 ]
            http://homepage.mac.com/jeffhammond/.Public/scf/lineAB2.jpg
            • Bob JamesB
              Bob James
              @plot-paris said:
              • Layer Grouping. you select a couple of layers, click right mouse button and choose the option 'group layers' (or use the same keybord shortcut you use for grouping geometry). now you can still switch on or off the layers within the group separately. but if you switch off the whole layer-group, all the layers within will be turned off at once. when you unhide the group again, only those layers will be made visible again, that were switched on before...
                oh, and you can expand/collapse layer-groups in the layer window to make some space...
              Along this same line, how about the ability to created sub-layers. By that I mean layers that would appear indented under the "Master" layer and be able to collapse to the Master Layer. Unchecking the Master layer would also uncheck the sub-layers.
              Structure 1
              ....Structure 1 - Beams
              ....Structure 1 - Windows
              ....Structure 1 - Walls
              Structure 2
              ....Structure 2 - Beams
              ....Structure 2 - Windows
              ....Structure 2 - Walls
              etc.
                MartinRinehart
                Re features in free/Pro.
                Just want to point out that there are lots of price points. Design Workshop priced at $0, $100 and $500.
                Photoshop costs either an arm and a leg, or $100 for Elements.
                AutoCAD wants your firstborn. You pay shipping (private jet only).
                How are they doing? http://www.google.com/finance?chdnp=1&chdd=1&chds=1&chdv=1&chvs=maximized&chdeh=0&chdet=1256156135801&chddm=495397&chls=IntervalBasedLine&cmpto=NASDAQ:MSFT;NASDAQ:GOOG;NASDAQ:ADSK;NASDAQ:ORCL&cmptdms=0;0;0;0&q=NASDAQ:ADBE&ntsp=0
                • plot-parisP
                  plot-paris
                  you know, what would be really helpful? if SketchUp supported import of dwg/dxf drawings with lineweights and colours, faces and text.
                  I fight with understanding an imported drawing almost every day. because every dotted line, no matter whether very thin and in a light gray or thick and red... everything is reduced to a black mess of lines.
                  I always have to print out the drawing in order to understand what I see in SketchUp. so even from an environmental point of view it would be a good idea πŸ˜‰
                  I know this is asking for a lot, because linewheigt isn't supported in SU yet and different text sizes, and styles aren't a strengh of it either.
                  but it would make architects life so much easier...
                    Turn on Colour by layer and Edge colours.
                    • K
                      kwistenbiebel
                      Sometimes the solution is so simple πŸ˜„
                      • plot-parisP
                        plot-paris
                        thats true. still doesn't solve the line weight problem though. and dotted lines don't work either. and import of fillings would be nice as well (you know, a face with a standart hatch texture instead of importing hundrets and hundrets of hatch-lines... stuff like that.
                        basically, I want to be able to look at an imported drawing, as if I were looking on it in the CAD application itself...
                        (and of course thats more a dread than a request. for the changes to SketchUp, however useful they might be, are quite large)
                        • plot-parisP
                          plot-paris
                          two really useful things (I will write them again, even though I think both were mentioned before - but they would be so easy to implement and so useful):
                          the ability to change axes for groups as well. at the moment you can define component axes. that affects the bounding box as well.
                          for rectangular object even an option such as 'align axes to geometry' could be useful.
                          the second thing is an option to switch between 'world axes' and 'object axes' orientation.
                          imagine you draw a group or component, then rotate it at an odd angle. if you now enter this group and start drawing, and want to stay at a right angle to the geometry, you have to refer to inferencing, because the red/green/blue axes point another way. if you now switched to 'object based' axes orientation, it would be a lot easier to draw in this particular context. and creating groups/components would result in their bounding boxes being aligned to the actual geometry (as opposed to today, where they are aligned to the world axes...)
                          what do you think?
                          oh, and another thing just popped into my mind:
                          introduce the option to right click buttons to define specific tool parameters. that keeps the UI simple whilst giving us a whole new world of options.
                          in addition to that holding down your left mouse on a button could expand a 'sub-button-bar'. that would be very useful for a lot of rubies (half my toolbars are fredo's at the moment. imagine you could collapes all tools on surface to one button...)
                            what do you think?
                            πŸ‘
                            • GaieusG
                              Yes, this axis thing is definitely a good one. Particularly that components (at least) work perfectly as embedded mini models and when you save them as..., youi can work on them in a separate file and the axis system of that file respects the original component axes.
                              So why not be able to do it "In model" as well?
                              (Although this should be something like "hide rest of model" and "hide similar" - i.e. toggle-able as sometimes you may need to work in other ways)
                              • plot-parisP
                                plot-paris
                                I've already got my keyboard shortcut reserved for that πŸ˜„
                                (F2 = show/hide hidden geometry
                                F3 = perspective/parallel projection
                                F4 = show/hide rest of model
                                F5 = world axes/component axes 😍 )
                                • GaieusG
                                  I use Ctrl+H to hide rest of model and Shift+Ctrl+H to hide similar components. Sgift+H could be the one to switch between axes. πŸ˜‰
                                  • plot-parisP
                                    plot-paris
                                    damn, my hand is to small for Ctrl + Shift + H
                                    πŸ˜„
                                      davide.skp
                                      a powerfullllllll camera match
                                      πŸ˜„
                                      • Bob JamesB
                                        Bob James
                                        Maybe someone else has mentioned this, but how about being able to keep the View/Toolbars drop-down open to allow multiple checking/un-checking toolbar choices at the same time?
                                          Aerilius
                                          I've not read it yet, but I agree. Very reasonable idea!!!
                                            Might be possible to do this by ruby... might
                                            • 5 / 7
