    Shadows' trick?
    17 Posts 6 Posters 1.4k Views 6 Watching
      Does exist a trick for have the up shadows'box but not the upper box from the same point of view?
      (when the rendering tips don't work )
      • P
        Panga
        Hi Pilou,
        I saw a similar post a few weeks ago. The advice given was to draw the shadow with faces, give them the colour of normal shadows, and hide the edges of theses faces. Hope I'm enough clear.
        J'ai vu un post similaire sur ce problème il y a quelques temps. Le conseil donné était de dessiner des faces à l'emplacement de l'ombre. Tu leur donnes la même couleur que les autres ombres du modèle et tu caches les arrêtes autour des faces créées.
        Cheers.
        • EdsonE
          Edson
          i did not quite understand your doubt but did you know you can set a group not to cast shadows? (bottom of the shadows dialogue box)
          http://www.mahfuz.arq.br
          • GaieusG
            Pilou,
            Please, rephrase the question, please. I have read it several times but still unable to understand it and I haven't been wiser from either Panga's or Edson's anwers.
            • do you want to see the shadows or not
            • do you want to see that object or not
            • do you want straight SU output or some rendering (as you referred to)?
              @Gaieus
              • do you want to see the shadows or not : I want see all shadows (even the shadow's beam
                • do you want to see that object or not : I want see the walls, I don't want see the beam
                • do you want straight SU output or some rendering (as you referred to)? both : Su and rendering 😄
              @ Panga: Yes but ...some painful 😉
              The render tips with a Section plan + camera out this cut will be terrific but seems Podium or Twilight don't make it or I miss something 😢
              • AnssiA
                Anssi
                Hi Pilou
                Is this what you are trying to do?
                Anssi
                pilou_box.skp
                • GaieusG
                  Yeah, the reason why asked is probebly(???) in Anssi's example.
                  (I have not opened it just trying to play a game - he probably made it with a totally - 100% - transparent png image file).
                  Anyway, png transparency (its shadow, more exactly) is not transparent only in SU (or at least, most modern rendering engines would render it transparent).
                  So while you can take advantage of a SU "bug" (?) - say a limited feature -, when it comes to real lighting, it may become different.
                    @Anssi
                    Yes Exactly! Works fine in Su ☀
                    How do you make this? (Enable Cast Shadows, Receive Shadows), Special color, Special texture?
                    (If it's not a magician's secret) 😄
                    Ah yes I edit the texture so a transparent texture as Gaieus said 😄
                    Works not in rendering 😮
                    • E
                      Ecuadorian
                      Ok, I'm cheating here... 😛
                      cheat-box.skp
                      -Miguel Lescano
                      • AnssiA
                        Anssi
                        Pilou,
                        Gaieus was right, of course. I was waiting for you to discover the trick yourself...
                        Turn on Hidden geometry so you see the beam is there. So as Gaieus said, I painted the beam faces with a 100% transparent PNG texture and hid the lines. You can see the texture in the In Model materials.
                        How to render this depends on the capabilities of your render application. I would guess that it is not possible with most of them to create an invisible material that casts shadows. In 3D Studio Max, maybe?
                        Anssi
                        • E
                          Ecuadorian
                          Invisible on one side and visible on the other, but shadow-casting? Give LightUp a try.
                          -Miguel Lescano
                            I have seen something like this in the past in 3Dmax yes
                            A bi-facet material don't exist in Su?
                              @Ecuadorian : You redraw shadow?
                              Shadow casting will be given by the internal face visible ?
                              • E
                                Ecuadorian
                                -Miguel Lescano
                                • E
                                  Ecuadorian
                                  Pretty much the same trick. 😄
                                  -Miguel Lescano
                                    @Ecuadorian 👍 💚 (I didn't thought to make a zoom all 😮
                                    Remember my old one (my skp is somewhere on the net) Refound 😄
                                    http://forums.polyloop.net/imagehosting/1964630920edf1bb.jpg
                                    http://forums.polyloop.net/imagehosting/1964630980e9ff79.jpg
                                    reality.skp
                                    • P
                                      Panga
                                      Nice trick Pilou !! I like it. 😄
