    Shadows' trick?
    17 Posts 6 Posters 1.4k Views 6 Watching
    • GaieusG
      Pilou,
      Please, rephrase the question, please. I have read it several times but still unable to understand it and I haven't been wiser from either Panga's or Edson's anwers.
      • do you want to see the shadows or not
      • do you want to see that object or not
      • do you want straight SU output or some rendering (as you referred to)?
        @Gaieus
        • do you want to see the shadows or not : I want see all shadows (even the shadow's beam
          • do you want to see that object or not : I want see the walls, I don't want see the beam
          • do you want straight SU output or some rendering (as you referred to)? both : Su and rendering ๐Ÿ˜„
        The advice given was to draw the shadow with faces
        @ Panga: Yes but ...some painful ๐Ÿ˜‰
        The render tips with a Section plan + camera out this cut will be terrific but seems Podium or Twilight don't make it or I miss something ๐Ÿ˜ข
        • AnssiA
          Anssi
          Hi Pilou
          Is this what you are trying to do?
          Anssi
          pilou_box.skp
          • GaieusG
            Yeah, the reason why asked is probebly(???) in Anssi's example.
            (I have not opened it just trying to play a game - he probably made it with a totally - 100% - transparent png image file).
            Anyway, png transparency (its shadow, more exactly) is not transparent only in SU (or at least, most modern rendering engines would render it transparent).
            So while you can take advantage of a SU "bug" (?) - say a limited feature -, when it comes to real lighting, it may become different.
              @Anssi
              Yes Exactly! Works fine in Su โ˜€
              How do you make this? (Enable Cast Shadows, Receive Shadows), Special color, Special texture?
              (If it's not a magician's secret) ๐Ÿ˜„
              Ah yes I edit the texture so a transparent texture as Gaieus said ๐Ÿ˜„
              Works not in rendering ๐Ÿ˜ฎ
              • E
                Ecuadorian
                Ok, I'm cheating here... ๐Ÿ˜›
                cheat-box.skp
                -Miguel Lescano
                • AnssiA
                  Anssi
                  Pilou,
                  Gaieus was right, of course. I was waiting for you to discover the trick yourself...
                  Turn on Hidden geometry so you see the beam is there. So as Gaieus said, I painted the beam faces with a 100% transparent PNG texture and hid the lines. You can see the texture in the In Model materials.
                  How to render this depends on the capabilities of your render application. I would guess that it is not possible with most of them to create an invisible material that casts shadows. In 3D Studio Max, maybe?
                  Anssi
                  • E
                    Ecuadorian
                    Invisible on one side and visible on the other, but shadow-casting? Give LightUp a try.
                    -Miguel Lescano
                      I have seen something like this in the past in 3Dmax yes
                      A bi-facet material don't exist in Su?
                        @Ecuadorian : You redraw shadow?
                        Shadow casting will be given by the internal face visible ?
                        • E
                          Ecuadorian
                          ๐Ÿ˜„
                          -Miguel Lescano
                          • E
                            Ecuadorian
                            Pretty much the same trick. ๐Ÿ˜„
                            -Miguel Lescano
                              @Ecuadorian ๐Ÿ‘ ๐Ÿ’š (I didn't thought to make a zoom all ๐Ÿ˜ฎ
                              Remember my old one (my skp is somewhere on the net) Refound ๐Ÿ˜„
                              http://forums.polyloop.net/imagehosting/1964630920edf1bb.jpg
                              http://forums.polyloop.net/imagehosting/1964630980e9ff79.jpg
                              reality.skp
                              • P
                                Panga
                                Nice trick Pilou !! I like it. ๐Ÿ˜„
