    Product Ideas for SketchUp
    26 Posts 16 Posters 12.7k Views 16 Watching
      Jernej Vidmar
      Hi guys,
      I have also added the request for Ruby 1.9.0 or later. Make sure to vote for it πŸ˜„
      As it might be lost among all suggestions, you can always find it using the search at the top of the page. Keyword: ruby 1.9.0.
      Cheers,
      Jernej
      PS: I have some more suggestions, but I can not post them anymore. I always get "Error parsing response"... Does anyone have similar problems?
        I had similar problem. To me it worked again after I just typed "test", then when I suggested other similar ideas I type in my real request again.
        Good suggestions btw - I'll make sure to vote for it.
        • T
          tfdesign
          I know it's a very basic suggestion, but I've suggested that the VCB window should be longer in size (!). Perhaps there's a way of doing this, but I have never figured it out?
          Tom
          • T
            tfdesign
            @troyhome said:
            just the basics: multiprocessor support
            I'm surprised that this isn't already supported considering that SU is one of the few CAD systems that has actually been built in Apple's Cocoa. Cheetah3D is another Cocoa app, and this automatically makes use of any multiprocessors- especially when rendering. Because of Cocoa, shouldn't SU also automatically be 64-bit too? Maybe I'm just having fanboy disillusions? 😲 πŸ˜’ πŸ˜†
              remus
              From what the developers have said its actually quite hard to thread the major elements in SU, so that is most likely why there isnt multi processor support yet.
                Aerilius
                Intel plans already to combine hundreds of atom chips (or even smaller chips) to spare energy. So I think multi core support is something that should be solved by operating systems and not by every single application. It is insane when every little programmer has to struggle with this.
                I can imagine that virtualization could supply a solution. With VirtualBox I can simulate a 32 core system. I have not tried if it is possible to simulate less cores than I actually have.
                Does someone know more about this?
                The Sketchup developers said that they will optimize the communication between processes in the graphics card and processes on the cpu (because they are closely linked).
                  remus
                  Its really not as easy as you make out. For an app to be multi threaded there needs to be definite separate processes that can run at the same time without having to 'talk' to each other. Although operating systems can make multi threading easier they can certainly not eliminate the need for a program to be written in a multi threaded manner.
                  • aadbuildA
                    aadbuild
                    My suggestion is much simpler. have 1 extra drop down box inside the entity info box. I think it should be some type of record button that lets you choose wher you want the entity info results placed for later use (spead sheet or note pad etc etc).
                    Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
                    https://www.plusspec.com
                    • B
                      bjanzen
                      It's now closed. Thanks for posting this, Gai, and thanks for the feedback, all.
                      b
                      • GaieusG
                        Hope you guys have had good ideas but even more hope that you pick mine to develop next.
                        πŸ˜‰
                        (Topic unstuck now)
                          Pick mine! Pick Mine! πŸ˜„
                          • K
                            Kent L
                            It now says that all voting and suggestions are closed. Wow. That didn't last long. Oh well.....
                              remus
                              Seems strange to close the voting as well, would have thought it would makes sense to leave it open to try and get a better idea of what people want.
                                Aerilius
                                It is open again!
                                Still some of the most popular (and important!) ideas could be posted again πŸ˜„ , but have a look in the SketchUp forum where John Bacus was so nice to give some understandable thoughts from Google's perspective. πŸ‘
                                • GaieusG
                                  And don't forget that he was bringing those back that were th top ten ideas. Some of them enthusiastically wished herebut others are not.
                                  Th user base is definitely much wider than SCF.
                                  • 2 / 2
