    Edges to faces
    15 Posts 6 Posters 1.5k Views 6 Watching
      To get the Utilities open Window > Preferences > Extensions and load Utilities...
      • numbthumbN
        numbthumb
        And you can also use the weld plugin http://www.cad-addict.com/2008/08/sketchup-plugins-weld.html on those segmented lines.
        Comfortably numb...
        • E
          Ecuadorian
          Welcome, Rafa! πŸ˜„
          -Miguel Lescano
            Rafa
            πŸ˜„ Thanks for the wellcome Ecuadorian. And for the responses Massimo, Numbthumb and Tig.
            I'll be more active here, and I'll try to make less stipid questions each time πŸ˜†.
            Edited. Damn, I thouight having a long experience in using all kinds of aplications would be always an advantage. "Draw a line" was not the logical step in my mind. My brain thinks in terms of Modify > Edges > Merge. 🀣
            • massimoM
              massimo Moderator
              How can I join colinear segments into one?
              Rafa, a little trick for you: draw a little line starting from the joint point of the two segments and then erase that little line. At the end you will have a single line from the two segments.
              • numbthumbN
                numbthumb
                YouΒ΄re most welcome, mate.
                And by "all kind of applications" you mean...?
                Comfortably numb...
                  There's also 'repair_broken_lines' by Carlo Roosen... 5yrs old !
                  http://www.crai.archi.fr/RubyLibraryDepot/Ruby/EM/repair_broken_lines.rb
                    Rafa
                    Some feedback.
                    The first Ruby (Weld) aplyed before extruding its interesting but it leaves the segments (as seen with "view hidden lines" on)
                    http://www.otake.com.mx/Foros/Skp/Skp-01-2Weld2.jpg
                    And the fix broken lines seems to work great in this case.
                    http://www.otake.com.mx/Foros/Skp/Skp-01-3RepairBrokenLines.jpg
                    πŸ‘
                    Massimo, the option of drawing a line is still resisting me πŸ’š I'll keep practicing, but I have my first favorite ruby now. πŸ˜„
                    @Numbthumb. By all Kind of aplications (just an expression) im refering to vector based 2d, photo editing, video editing, audio and midi, multimedia authoring, worksheets, web authoring, some 3D. I remember a Dos batch program to make text based windows with options. πŸ’š
                    • GaieusG
                      And please, don't forget to mention Kerkythea namely as you are one of the top regulars on the Kerky forums (whom I learnt a lot from as a mainly lurker - so thanks like this, afterwards, too).
                      So welcome to SCF (although I know you've been a member for a while) and SketchUp itself. πŸ‘
                      Don't be bothered and embarrassed with "stupid" questions - apart from spamming and foul language on each other, everything is allowed in this department (why else do you think we founded it?)
                      πŸ˜‰
                      BTW have a look at Cleanup.rb - another useful plugin to get rid of unwanted geometry.
                        Rafa
                        Thanks for the wellcome Gaieus!.
                        Regarding Kt, you'll se something here, as soon as I have something worth to show, you can bet on that πŸ’š
                        I'll check the rb πŸ‘
