    [Plugin] Control points ver. 1.6.
    115 Posts 42 Posters 62.2k Views 42 Watching
    • E Offline
      Ecuadorian
      Wow, thank you!
      -Miguel Lescano
        Seems a cool one! 😎
          Just saw the video - very nice!
          Does it remember the control vertices across sessions?
            d12dozr
            Wow! Organic modeling just got easier Thanks, Krill!
            Is there a way to set each node's position on the curve manually, instead of just being evenly spaced?
            http://goo.gl/f7ooYh
              pav_3j
              now this is very cool!
              thanks ever-so much!
              yay another toy to play with...
              pav
              Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
                Daniel S
                Thank you Kirill!!!
                Looks amazing!!
                Daniel S
                  kirill2008
                  Unfortunately no 😕
                  I knew it would be one of the first questions 😄 , but it's not implemented yet. Actually I don't know yet how to make it... Maybe to launch a kind of entity scanner each time when new file loads. It will scan entities to link c-points to curve vertices again. But it will slow opening of huge models...
                    kirill2008
                    That's a cool idea 👍 I'll try to implement it. Current version does not allow manual node positionig.
                    • boofredlayB Offline
                      boofredlay
                      Wow, great stuff.
                      In your notes above you mention SU6. It seems to work fine in SU7.1 as well.
                      • mitcorbM Offline
                        mitcorb
                        Looks interesting, Kirill.
                        Will this technique do away with bezier curves?
                        What would be the difference in this and polylines?
                        EDIT!!! never mind my stupid questions. I had a good long look at the demo video.
                        Excellent work.
                        mitcorb
                          c.plassais
                          Excellent!!!
                            boofredlay
                            It might be nice also to have the undo function work for the whole action rather than each individual step in the script. For example I added 6 control points around a 24 segment circle and it took 50 undo clicks to get back to the creation of the circle, when all I did was run the script once. Make sense?
                            Not sure how to do this however, just a thought.
                            This one is going to be very useful for me indeed.
                            Thanks 👍
                              That's my concern for a plugin I'm working on as well... was curios to hear if there was any other way.
                              • olisheaO Offline
                                olishea
                                this is amazing
                                thank you
                                oli
                                • EarthMoverE Offline
                                  EarthMover
                                  FANTASTICO!!!! Awesome Krill! I think an add control point tool would be a great improvement. Also maybe a simple option to add control points only to existing vertices. This would be great for a subdivided or tesselated mesh, but I think it would require an implementation of soft selection to make a further advancement towards organic modeling.
                                  Thanks again Krill.
                                  EDIT - DUH! I looked right past the option to add to "each vertex". Nevermind.
                                  I do vote for a Krill Toolbar though!!!
                                  Content Creator at Skapeup
                                  • utilerU Offline
                                    utiler
                                    Ditto, EarthMover!!! Toolbar for sure!!!!!
                                    Will somebody stop this guy............... 😮
                                    Just Curious...
                                      dedmin
                                      Да здравствует дружба между народами
                                      • wind-borneW Offline
                                        wind-borne
                                        Very interesting plugin.
                                        i am having a strange problem, plugin only shows up on initial opening drawing. If I open a new one without closing Sketchup completely, no plugin.
                                        I've tried copy from initial( where it works) and paste to new with real odd results also. The plugin then shows up but misbehaves. If I draw a new object, new construction points are put on the pasted object(even though I have deleted it) instead of new object which was selected.
                                        "To read between the lines was easier than to follow the text."OSX 10.11.6
                                        %(#BF80BF)[SU 8 pro
                                          kirill2008
                                          As I can see on attached picture the whole face is selected, but current version of the script (ver. 1.1.) actually processes only curves. So try select only boundary curve without face itself (you may deselect face by pressing shift and single-clicking on face). Make sure that only boundary is selected. Of course script processing does not depend on opened file (old or new). It depends on what entity is the first one selected: if it occures that curve edge is the 1-st item of selected entities collection, then everything works, if the 1-st item is face, then the command does not appear within context menu.
                                          So I'll try to make the script more tolerant to the selection in future versions 😄 .
                                          Speaking of copy-paste behaviour, I'll try to find out why it processes so strange (don't know why yet).
                                            wind-borne
                                            kirill,
                                            Thanks for your response, the problem is that the plugin only appears in the first file of a session, be it opening Sketchup with an old file or a new one. If I open an old or new after the initial startup, plugin is simply not there, curves or curves/faces selected doesn't make any difference( works both ways in first file opened).
                                            The strange behavior is that the plugin follows the copy/paste and works on the original object (even though I have deleted it after pasting) in the new file but not on anything newly drawn.
                                            Actually by thinking out loud I can see now how to do what I need to, just a cumbersome path.
                                            The plugin, itself, has a nice feel. 😄
                                            %(#BF80BF)[SU 8 pro
                                            • 6 / 6
