    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.6m Views 202 Watching
      cyan.archnet
      will definitely give this a try!, A BIG THANK YOU!! for this awesome plugin!!
      • boofredlayB Offline
        boofredlay
        Can't get Daniels icons to show. If I choose them from Default Parameters and ok it, nothing happens. If I open again, the tick in the box is gone.
        It seems there is a problem with that, but only on Mac.
        I am checking this issue.
        I just installed the update and I don't even have the option to choose an icon set in the Default Parameters. I am on a PC with XP.
        DP.jpgAlso, I noticed that when I deleted the old LIBFREDO6_Dir_32 and TOS_Dir_13 folders my TOS toolbar disappeared. It reappeared after restoring those folders.
        Any ideas?
        Thanks.
        • EarthMoverE Offline
          EarthMover
          I've had a chance to really play with the refreshed version....WOW!! You have really thought of everything! I find myself using these drawing tools for so much more than just on a curved surface. They are great to use on coplanar surfaces as well!
          Between Joint Push Pull, Round Edges, Tools on Surface and Bezier Tools, you've single handedly propelled SU into a league of it's own. You make other apps feel down right tedious. THANK YOU AGAIN!!
          Content Creator at Skapeup
          • fredo6F Offline
            The options for alternate icons (and icons shown in the toolbar) are in the Default Parameter of ToolsOnSurface, not of LibFredo6.
            Also, do not forget to install LibFredo6 3.4
              boofredlay
              And I think this is the second time I asked you about this, sorry 😳
              It is working fine.
              I did have LibFredo 3.4 installed when I removed the older directories. I restarted SU and the toolbar went away. However, somehow (assuredly due to operator error) when I remove it now and restart SU everything is fine.
              Sorry for the bother and thanks again for the plugin.
                Daniel S
                Fredo... Is not working the explicit selection for the offset on surface? (Select first Edges and Faces in the model, then start the tool).
                Most of the things are possible with the implicit selection but now that I want to offset some edges it becomes impossible.
                Daniel S
                • fredo6F Offline
                  Daniel,
                  Thanks for signaling this bug (which was introduced with 1.5a).
                  I made a fix and updated the main post with version 1.5d. It also includes the Spanish translation by Gaonirico.
                    Daniel S
                    Great!!! Thank you for the updated version!!!
                    Daniel S
                    • fredo6F Offline
                      New maintenance release 1.5e.
                      I fixed bugs in 1.5d on the generation of Circles and Polygons when no face.
                      I also restablish the post-edition functionality which mysteriously disappeared in v1.5 (or maybe in earlier versions).
                      see main post for the new zip file
                      http://forums.sketchucation.com/viewtopic.php?f=180&t=11212#p76625
                        Daniel S
                        Today I saw something strange...
                        try to make a triangle with initial point in the construction point...
                        polygononsurf.skp
                        Daniel S
                        • fredo6F Offline
                          Daniel,
                          You are an incredible tester. There was 1 chance out 10 million that this situation occurs!! I mean a triangle with 8 sides!
                          I published a fix in version 1.5f
                          See main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=11212&p=76625#p76625
                            arklandesign
                            With all the great reviews of this ruby script I couldn't wait to try this one out... tried and tried to download this into my plugins and sadly all I'm get is an error saying..
                            Error Loading File ZLoader__OnSurface.rb
                            No such file to load -- LibFredo6.rb
                            Ive tried to wade through this thread but am confused .....The version I tried was 1.5c and then i tried 1.5e.... still not working
                            Can anyone point me in the right direction... what is the secret to getting this to work...???
                              remus
                              Have you installed libfred06? http://forums.sketchucation.com/viewtopic.php?f=180&t=17947#p144178
                              ToS needs it to work, i think.
                                arklandesign
                                Thank you Remus for the prompt reply...
                                So, just to make sure i need to install the following
                                b]LibFredo6_ES.zip[/b]
                                (3.33 KB) Downloaded 116 times
                                Right ???
                                Ill try that.... Fingers crossed :O)
                                whoooh.... there is more to this than meets the eye.... Ok, i'll try to do this... but don't be surprised if I return with some questions...
                                Thanks again Remus :O)
                                  remus
                                  Yep, that should do it, and I think the extra complication is worth it for fredo's plugins.
                                  • W Offline
                                    watkins
                                    Dear Fredo6,
                                    I note that when using your Tools on Surface plugin one has a toolbar which is permanently displayed and then an 'on screen' toolbar that appears when one selects a tool from the permanently displayed toolbar. Is this how it is supposed to work? If so, would it not be better to have a single permanently visible icon, perhaps labelled TOS, which when clicked brought up the 'on screen' toolbar?
                                    Kind regards,
                                    Bob
                                    • fredo6F Offline
                                      @watkins said:
                                      Dear Fredo6,
                                      Bob,
                                      In TOS 1.5, I introduced a Generic Icon (the first one in the toolbar) that keep memory of last TOS tool launched.
                                      If you go to the Default Setting dialog box of ToolsOnSurface, you can hide all other icons and keep this one.
                                      PS: you may want to keep one or two other icons for the functions you need frequently.
                                      • W Offline
                                        watkins
                                        Dear Fredo6,
                                        Many thanks for the explanation, and a most excellent plugin.
                                        Thank you again for your generosity.
                                        Kind regards,
                                        Bob
                                        • fredo6F Offline
                                          Documentation in Frenchnow available, thanks to Jean-Francoand Christophe Plassais.
                                          See main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=11212#p76625
                                          • plot-parisP Offline
                                            plot-paris
                                            hi Fredo,
                                            in the last couple of releases Daniel S' fancy icons are not implemented anymore. but only the old ones... do you know why that is?
                                            [Edit] ops.. never mind, just found them in the installation folder 😳
                                            thanks again for the great plugin []
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 31
                                            • 32
                                            • 18 / 32
