    Unit plugin not work in SU 7.1 ?
    17 Posts 6 Posters 2.4k Views 6 Watching
    • H Offline
      huyvuvn
      when I update Su 7 to 7.1 , this plugin not work , any help ???
      thanks
      happiness on the way, not in the destination.
      • Chris FullmerC Offline
        I saw someone else mention this. I do not know if anyone has looked into it.
        • CadFatherC Offline
          CadFather
          I sent a pm to Matthiew but he has no time at the moment, he will look into it (eventually)
          the problem is probably minor - perhaps someone else can fix it. i don't think Matt would object..
          • H Offline
            huyvuvn
            thanks all πŸ˜„ sothat I'm waiting for the new verison of unit plugin 😞
              Jim
              Could you copy and paste this in the Ruby Console, and show the result?
              Sketchup.active_model.options.map{|o| o.name}
              It should look similar to this, but may be in your language:
              ["PageOptions", "SlideshowOptions", "NamedOptions", "UnitsOptions", "PrintOptions"]
              • kenK Offline
                ken
                Yep, that what I get.
                Ken
                  Jim
                  Thanks Ken, I was hoping to see if a foreign language version used translated names for these.
                  Maybe I should have just said that to begin with. πŸ˜„
                  • TIGT Online
                    I fell foul of something similar... When you call options you must do it by 'name' not 'index' and similarly for their values ? ❓
                      CadFather
                      anyone out there willing to take this on?
                        Jim
                        I added translation using the langhandler.rb that comes with Sketchup. I sent a copy to Matt, but he didn't respond. I guess it would be OK if I posted it.
                        But I am not 100% sure that was the problem - I made some assumptions.
                        toggle_units.rb
                        rename to toggle_units.strings
                        • kenK Offline
                          ken
                          Jim
                          Works great on my computer.
                          Ken
                            CadFather
                            mm..this is what i get:
                            Error Loading File toggle_units.rb
                            cannot convert nil into String
                              CadFather
                              anyone with the same problem?
                                Jim
                                You might need to rename the toggle_units.txt to toggle_units.strings and then move it to the Sketchup/Resources/your langauage/folder
                                  CadFather
                                  yes, already done yesterday - same error.. 😞
                                    Jim
                                    Will you try to load it from the Ruby Console and post the error?
                                    load 'toggle_units.rb'
                                      CadFather
                                      got it Jim, it was something to do with the path to the icons - the ruby console is great but not when you forget its existence, Thanks! πŸ˜„
