    Unit plugin not work in SU 7.1 ?
    17 Posts 6 Posters 2.6k Views 6 Watching
    • H
      huyvuvn
      thanks all πŸ˜„ sothat I'm waiting for the new verison of unit plugin 😞
      happiness on the way, not in the destination.
        Jim
        Could you copy and paste this in the Ruby Console, and show the result?
        Sketchup.active_model.options.map{|o| o.name}
        It should look similar to this, but may be in your language:
        ["PageOptions", "SlideshowOptions", "NamedOptions", "UnitsOptions", "PrintOptions"]
        • kenK
          ken
          Yep, that what I get.
          Ken
            Jim
            Thanks Ken, I was hoping to see if a foreign language version used translated names for these.
            Maybe I should have just said that to begin with. πŸ˜„
              I fell foul of something similar... When you call options you must do it by 'name' not 'index' and similarly for their values ? ❓
              • CadFatherC
                CadFather
                anyone out there willing to take this on?
                  Jim
                  I added translation using the langhandler.rb that comes with Sketchup. I sent a copy to Matt, but he didn't respond. I guess it would be OK if I posted it.
                  But I am not 100% sure that was the problem - I made some assumptions.
                  toggle_units.rb
                  rename to toggle_units.strings
                  • kenK
                    ken
                    Jim
                    Works great on my computer.
                    Ken
                    • CadFatherC
                      CadFather
                      mm..this is what i get:
                      Error Loading File toggle_units.rb
                      cannot convert nil into String
                      • CadFatherC
                        CadFather
                        anyone with the same problem?
                          Jim
                          You might need to rename the toggle_units.txt to toggle_units.strings and then move it to the Sketchup/Resources/your langauage/folder
                          • CadFatherC
                            CadFather
                            yes, already done yesterday - same error.. 😞
                              Jim
                              Will you try to load it from the Ruby Console and post the error?
                              load 'toggle_units.rb'
                              • CadFatherC
                                CadFather
                                got it Jim, it was something to do with the path to the icons - the ruby console is great but not when you forget its existence, Thanks! πŸ˜„
