πŸ€‘ 30% Off | Artisan 2 on sale until April 30th Buy Now
Unit plugin not work in SU 7.1 ?
17 Posts 6 Posters 1.9k Views
  • H Offline
    huyvuvn
    when I update Su 7 to 7.1 , this plugin not work , any help ???
    thanks
    happiness on the way, not in the destination.
      I saw someone else mention this. I do not know if anyone has looked into it.
        CadFather
        I sent a pm to Matthiew but he has no time at the moment, he will look into it (eventually)
        the problem is probably minor - perhaps someone else can fix it. i don't think Matt would object..
        • H Offline
          huyvuvn
          thanks all πŸ˜„ sothat I'm waiting for the new verison of unit plugin 😞
            Jim
            Could you copy and paste this in the Ruby Console, and show the result?
            Sketchup.active_model.options.map{|o| o.name}
            It should look similar to this, but may be in your language:
            ["PageOptions", "SlideshowOptions", "NamedOptions", "UnitsOptions", "PrintOptions"]
              ken
              Yep, that what I get.
              Sketchup.active_model.options.map{|o| o.name }
              Ken
                Jim
                Thanks Ken, I was hoping to see if a foreign language version used translated names for these.
                Maybe I should have just said that to begin with. πŸ˜„
                  I fell foul of something similar... When you call options you must do it by 'name' not 'index' and similarly for their values ? ❓
                    CadFather
                    anyone out there willing to take this on?
                      Jim
                      I added translation using the langhandler.rb that comes with Sketchup. I sent a copy to Matt, but he didn't respond. I guess it would be OK if I posted it.
                      But I am not 100% sure that was the problem - I made some assumptions.
                      toggle_units.rb
                      rename to toggle_units.strings
                        ken
                        Jim
                        Works great on my computer.
                        Ken
                          CadFather
                          mm..this is what i get:
                          Error Loading File toggle_units.rb
                          cannot convert nil into String
                            CadFather
                            anyone with the same problem?
                              Jim
                              You might need to rename the toggle_units.txt to toggle_units.strings and then move it to the Sketchup/Resources/your langauage/folder
                                CadFather
                                yes, already done yesterday - same error.. 😞
                                  Jim
                                  Will you try to load it from the Ruby Console and post the error?
                                  load 'toggle_units.rb'
                                    CadFather
                                    got it Jim, it was something to do with the path to the icons - the ruby console is great but not when you forget its existence, Thanks! πŸ˜„
