    The VUE thread
    extensions
    122 Posts 29 Posters 21.9k Views 29 Watching
    • Chris FullmerC Offline
      Do you already own 3dsmax in the company? You could get the Vue xstream that acts as a stand alone and a plugin to 3ds max. Its more expensive though.
      The thing that Vue gives beyond 3ds max alone, is incredible vegetation and ecosystems. So if you are wanting to do landscapes, I would say that Vue would be a better route. I am also trying to get my firm to invest in it for me 😄
        JHuman
        Yes, thats what I've been telling them for a while, but they always seem to wait to long then no really realizes the learning curve on any program, especially a 3D Modeling / Rendering program.
        Im just trying to get proof that people have used it the way we want to, thats the only way they will buy it 😕
        We do own 3DStudio MAX, about 50 licenses, and none of them get used cuz no one knows it well enough to do anything with it, I think the learning curve on VUE would be less than MAX, and I hear VUE works much better with Sketchup. Thanks Chris for your reply!
        • Doweth!
          JHuman
          Another question for you all.
          How do you best model in SU to import into VUE. I think it would be good practice to name my components. It looks like it breaks every piece into a single component though. Any thoughts would be helpful though, thanks!
          • Doweth!
            jpadams127
            I have another workflow question. What is the best way to get acurate topographic information into vue as a native terrain. I can bring the information in as a 3ds from sketchup, but I would like to have it as a native terrain so that I can manipulate it in Vue. Is this possible? I found a ruby script that seems to export a point cloud file from contours in sketchup, but is there a python script to get the point cloud file into Vue? Thanks in advance.
              archigrafix
              Does anyone know how to achieve a fresnel effect with a transparent or reflective material?
              Agir comme un homme de pensée, et penser comme un homme d'action...
              • F Offline
                FoXar
                Hmmm, after reading trough this topic I'm getting the feeling to start learning
                Vue too, when I get some time on my hands I'll sure boot up this nice piece of software
                to give it a shot!
                Grats,
                FoXy ^^
                  red_shift
                  I am using Vue Infinite 7.5 and Sketchup. Using the Camera2Vue ruby script I am able to overlay a sketchy image from Sketchup with a rendered image from Vue. How do I match date/time/location/north direction in Vue with that of Sketchup?
                  • marked001M Offline
                    marked001
                    silly question maybe.... but finally just installed Vue 7.5 Infinite.... but not seeing an skp import option?? looking at vue's site..it says 32 bit only? (on vista64)
                    http://www.revision21vis.com
                    instagram: revi21on
                      d12dozr
                      I had to export OBJ, then import to Vue. I also have Infinite on my 64-bit machine and it works.
                      http://goo.gl/f7ooYh
                      • soloS Offline
                        You are correct, there is no .skp import for 64 bit, no problems really as the importer sucks and it does not support SU 7 anyway.
                        I still stick to .3ds as it works perfectly for my needs, if you model correctly and map your textures as you want them making sure not to have two materials assigned to a face (back and front) then once you have imported your model just double click to get into options window, select weld, then split and your model will be organised per your materials and will be easy to work with.
                          m48
                          • soloS Offline
                            Great post m48, I never thought about trying .kmz, and now with the new improved Collada exporters I guess the SU to Vue export will have another option.
                            Just one question, how does the material/mesh coversion look in the navigation pane?, is it organised, do components and groups keep their structure?
                              It's the same for put a SU textured model in Blender 😉 (trick known for a time) ☀
                                m48
                                Hi...yeah it look pretty good for my, perfect copy of the SU model.
                                all you have to do., is unzip all the files in the same folder. and when you open the .dae file whit VUE, automatically organised all.
                                Maintain a perfect structure and textures.
                                  m48
                                  Hi!!
                                  i been asking my self, if there is some kind of component spray, or tree-vegetation spray for VUE 7, because it
                                  is a little annoying putting it one at a time.
                                  • soloS Offline
                                    There are several ways, most common being the 'paint ecosystem' option, then there is object duplicating and randomising, another way is the add object/vegetation to texture option.
                                    What version do you have?
                                      m48
                                      i have the, vue 7 xstream 64bits, i´m very newb whit vue, only a couple weeks whit it.-
                                      only doit this..so far, all the model whit sketchup, only the texture of the mountain whit VUE.
                                      i need a most realistic nature.
                                      tks.
                                      and sorry my English. 😳
                                      http://img86.imageshack.us/img86/3150/67856402.jpg
                                      http://img86.imageshack.us/img86/67856402.jpg/1/w640.png
                                      • E Offline
                                        Ecuadorian
                                        Sorry for hacking the thread. I'm considering buying the RenderUp module for Vue 7 Pioneer so I could render some hi-res HDR backgrounds for use in other render programs.
                                        However, I just received an e-mail from e-on saying that version 8 of Vue-everything is coming in November, and...
                                        If you already own a module for Vue 7, you will be able to upgrade to the corresponding module for Vue 8 with a 50% discount on the full price.
                                        So I guess this month is a bad time to enter the Vue world and I better wait until November before buying any modules, what do you think?
                                        BTW, this single thread here seems to have more action than the whole "Vue - General" section of the Cornucopia forum 👍
                                        -Miguel Lescano
                                          marked001
                                          here is one of my first scenes i'm working on in vue.. working on some test images for an upcoming game project.... all of the 'built' pieces are from sketchup (boats downloaded)...
                                          http://img4.imageshack.us/img4/14/dock101909.png
                                          instagram: revi21on
                                          • soloS Offline
                                            Nice scene Jason, only issue is the gritty render, what settings are you using?
                                            Miguel, for architectural renders Vue 8 has nothing new to offer, I have not upgraded (there is an early upgrade available) I'm getting a little despondent with E-on, looks like they are more concerned with the Poser integration and fantasy hobbyist users than seriously looking at what they can do for the commercial user (remind you of anyone?)The render engine is slow and adding all the new features that I care less about just slows it down further.
                                            • 2 / 7
