    The VUE thread
    extensions
    122 Posts 29 Posters 32.8k Views 29 Watching
      JHuman
      So I am using Pioneer right now to try a few things out. If I buy one of the add on packs (Vue 7 Fantasy, or one of the other "T-Packs"), am I then able to import SU models and work with them inside of VUE? Also, if buying one of these packs, will it remove the VUE Logo from the renderings? Thanks!
      • Doweth!
        JHuman
        Another question, has anyone used Terragen? Looks similar for the end results, but dont know if it works with SU and what its workflow is like.
        • Doweth!
        • soloS Offline
          I am not familiar with the t packs or any module packs, I use Infinite so that I can upgrade as needed and be on the commercial maintenance. Try and ask on the Cornucopia or E-on forums, you are certain to get a clear answer there as any wrong info may cost you unnecessarily.
          I use Terragen 2 for projects that need a higher accuracy terrain, the work-flow is a little clumsy IMO, but the results are sweet once you get the hang of it.
            JHuman
            Thanks Pete! I will check on there. It talks somewhat about it here and there but no one has ever given me a clear answer. I gotta know before I spent a grand on it. But it would be nice, I have several projects right now that it would be great for!
            • Doweth!
              jpadams127
              Solo,
              I wanted to get some of your advice and expertise on an issue that I’m having. I’m working on some birds eye renderings for a community development. My workflow includes base and topographic information from CAD, modeling in SU, then rendering in Vue. I was wondering how you deal with the edges of your models when there is no ocean or mountains to carry or block your view to the horizon (see attachment I quickly put together). Do you have any techniques to extrapolate land up to the horizon, or creating some sort of terrain in the background that ties in with the terrain of the actual model. (Placing terrains in back of the model is difficult because the topo model has variable edges. I was thinking about involving aerial photos somehow however I feel this might not be the most realistic looking solution. Let me know what you think. Thanks!Quick example
              • soloS Offline
                Play with your fog settings so that the horizon is fogged out or remove/cut ground and save as .png with alpha embedded if you want to mess around in PS.
                Adjust your render window to fit better, or crop in post edit.
                There are so many other things one can do, but I'd need specifics of project and maybe even details as to whats beyond, maybe try using a Google earth image to continue the terrain.
                I noticed some of the homes have sunk into the terrain.
                • EarthMoverE Offline
                  EarthMover
                  Pete, do you know of any Vue python scripts that will convert SU faceme components into Vue alpha plane "face camera" components?
                  Content Creator at Skapeup
                  • soloS Offline
                    No need for a script, The image used for a SU face-me is normally .png, so in Vue create a new alpha plane, navigate to image, select fit and check 'billboard'...viola it's done and now you can even adjust the texture without it losing it's transparency.
                      JHuman
                      I am trying to convince the company I work for to go for VUE, but I need some other imput to back up my claim. They are under the impression that everything can be done in SU and Max. So I am just curious on everyone elses workflow and software collection. At my business (separate from this job) use several different software packages depending on the job, I am trying to get them to understand this. So if there is a way some of you could list your workflow that would be amazing! Thanks!
                      • Doweth!
                      • Chris FullmerC Offline
                        Do you already own 3dsmax in the company? You could get the Vue xstream that acts as a stand alone and a plugin to 3ds max. Its more expensive though.
                        The thing that Vue gives beyond 3ds max alone, is incredible vegetation and ecosystems. So if you are wanting to do landscapes, I would say that Vue would be a better route. I am also trying to get my firm to invest in it for me 😄
                          JHuman
                          Yes, thats what I've been telling them for a while, but they always seem to wait to long then no really realizes the learning curve on any program, especially a 3D Modeling / Rendering program.
                          Im just trying to get proof that people have used it the way we want to, thats the only way they will buy it 😕
                          We do own 3DStudio MAX, about 50 licenses, and none of them get used cuz no one knows it well enough to do anything with it, I think the learning curve on VUE would be less than MAX, and I hear VUE works much better with Sketchup. Thanks Chris for your reply!
                          • Doweth!
                            JHuman
                            Another question for you all.
                            How do you best model in SU to import into VUE. I think it would be good practice to name my components. It looks like it breaks every piece into a single component though. Any thoughts would be helpful though, thanks!
                            • Doweth!
                              jpadams127
                              I have another workflow question. What is the best way to get acurate topographic information into vue as a native terrain. I can bring the information in as a 3ds from sketchup, but I would like to have it as a native terrain so that I can manipulate it in Vue. Is this possible? I found a ruby script that seems to export a point cloud file from contours in sketchup, but is there a python script to get the point cloud file into Vue? Thanks in advance.
                                archigrafix
                                Does anyone know how to achieve a fresnel effect with a transparent or reflective material?
                                Agir comme un homme de pensée, et penser comme un homme d'action...
                                • F Offline
                                  FoXar
                                  Hmmm, after reading trough this topic I'm getting the feeling to start learning
                                  Vue too, when I get some time on my hands I'll sure boot up this nice piece of software
                                  to give it a shot!
                                  Grats,
                                  FoXy ^^
                                    red_shift
                                    I am using Vue Infinite 7.5 and Sketchup. Using the Camera2Vue ruby script I am able to overlay a sketchy image from Sketchup with a rendered image from Vue. How do I match date/time/location/north direction in Vue with that of Sketchup?
                                    • marked001M Offline
                                      marked001
                                      silly question maybe.... but finally just installed Vue 7.5 Infinite.... but not seeing an skp import option?? looking at vue's site..it says 32 bit only? (on vista64)
                                      http://www.revision21vis.com
                                      instagram: revi21on
                                        d12dozr
                                        I had to export OBJ, then import to Vue. I also have Infinite on my 64-bit machine and it works.
                                        http://goo.gl/f7ooYh
                                        • soloS Offline
                                          You are correct, there is no .skp import for 64 bit, no problems really as the importer sucks and it does not support SU 7 anyway.
                                          I still stick to .3ds as it works perfectly for my needs, if you model correctly and map your textures as you want them making sure not to have two materials assigned to a face (back and front) then once you have imported your model just double click to get into options window, select weld, then split and your model will be organised per your materials and will be easy to work with.
                                            m48
                                            • 5 / 7
