    The VUE thread
    extensions
    122 Posts 29 Posters 22.0k Views 29 Watching
      JHuman
      I am trying to convince the company I work for to go for VUE, but I need some other imput to back up my claim. They are under the impression that everything can be done in SU and Max. So I am just curious on everyone elses workflow and software collection. At my business (separate from this job) use several different software packages depending on the job, I am trying to get them to understand this. So if there is a way some of you could list your workflow that would be amazing! Thanks!
      • Doweth!
      • Chris FullmerC Offline
        Do you already own 3dsmax in the company? You could get the Vue xstream that acts as a stand alone and a plugin to 3ds max. Its more expensive though.
        The thing that Vue gives beyond 3ds max alone, is incredible vegetation and ecosystems. So if you are wanting to do landscapes, I would say that Vue would be a better route. I am also trying to get my firm to invest in it for me 😄
          JHuman
          Yes, thats what I've been telling them for a while, but they always seem to wait to long then no really realizes the learning curve on any program, especially a 3D Modeling / Rendering program.
          Im just trying to get proof that people have used it the way we want to, thats the only way they will buy it 😕
          We do own 3DStudio MAX, about 50 licenses, and none of them get used cuz no one knows it well enough to do anything with it, I think the learning curve on VUE would be less than MAX, and I hear VUE works much better with Sketchup. Thanks Chris for your reply!
          • Doweth!
            JHuman
            Another question for you all.
            How do you best model in SU to import into VUE. I think it would be good practice to name my components. It looks like it breaks every piece into a single component though. Any thoughts would be helpful though, thanks!
            • Doweth!
              jpadams127
              I have another workflow question. What is the best way to get acurate topographic information into vue as a native terrain. I can bring the information in as a 3ds from sketchup, but I would like to have it as a native terrain so that I can manipulate it in Vue. Is this possible? I found a ruby script that seems to export a point cloud file from contours in sketchup, but is there a python script to get the point cloud file into Vue? Thanks in advance.
                archigrafix
                Does anyone know how to achieve a fresnel effect with a transparent or reflective material?
                Agir comme un homme de pensée, et penser comme un homme d'action...
                • F Offline
                  FoXar
                  Hmmm, after reading trough this topic I'm getting the feeling to start learning
                  Vue too, when I get some time on my hands I'll sure boot up this nice piece of software
                  to give it a shot!
                  Grats,
                  FoXy ^^
                    red_shift
                    I am using Vue Infinite 7.5 and Sketchup. Using the Camera2Vue ruby script I am able to overlay a sketchy image from Sketchup with a rendered image from Vue. How do I match date/time/location/north direction in Vue with that of Sketchup?
                    • marked001M Offline
                      marked001
                      silly question maybe.... but finally just installed Vue 7.5 Infinite.... but not seeing an skp import option?? looking at vue's site..it says 32 bit only? (on vista64)
                      http://www.revision21vis.com
                      instagram: revi21on
                        d12dozr
                        I had to export OBJ, then import to Vue. I also have Infinite on my 64-bit machine and it works.
                        http://goo.gl/f7ooYh
                        • soloS Offline
                          You are correct, there is no .skp import for 64 bit, no problems really as the importer sucks and it does not support SU 7 anyway.
                          I still stick to .3ds as it works perfectly for my needs, if you model correctly and map your textures as you want them making sure not to have two materials assigned to a face (back and front) then once you have imported your model just double click to get into options window, select weld, then split and your model will be organised per your materials and will be easy to work with.
                            m48
                            • soloS Offline
                              Great post m48, I never thought about trying .kmz, and now with the new improved Collada exporters I guess the SU to Vue export will have another option.
                              Just one question, how does the material/mesh coversion look in the navigation pane?, is it organised, do components and groups keep their structure?
                                It's the same for put a SU textured model in Blender 😉 (trick known for a time) ☀
                                  m48
                                  Hi...yeah it look pretty good for my, perfect copy of the SU model.
                                  all you have to do., is unzip all the files in the same folder. and when you open the .dae file whit VUE, automatically organised all.
                                  Maintain a perfect structure and textures.
                                    m48
                                    Hi!!
                                    i been asking my self, if there is some kind of component spray, or tree-vegetation spray for VUE 7, because it
                                    is a little annoying putting it one at a time.
                                    • soloS Offline
                                      There are several ways, most common being the 'paint ecosystem' option, then there is object duplicating and randomising, another way is the add object/vegetation to texture option.
                                      What version do you have?
                                        m48
                                        i have the, vue 7 xstream 64bits, i´m very newb whit vue, only a couple weeks whit it.-
                                        only doit this..so far, all the model whit sketchup, only the texture of the mountain whit VUE.
                                        i need a most realistic nature.
                                        tks.
                                        and sorry my English. 😳
                                        http://img86.imageshack.us/img86/3150/67856402.jpg
                                        http://img86.imageshack.us/img86/67856402.jpg/1/w640.png
                                        • E Offline
                                          Ecuadorian
                                          Sorry for hacking the thread. I'm considering buying the RenderUp module for Vue 7 Pioneer so I could render some hi-res HDR backgrounds for use in other render programs.
                                          However, I just received an e-mail from e-on saying that version 8 of Vue-everything is coming in November, and...
                                          If you already own a module for Vue 7, you will be able to upgrade to the corresponding module for Vue 8 with a 50% discount on the full price.
                                          So I guess this month is a bad time to enter the Vue world and I better wait until November before buying any modules, what do you think?
                                          BTW, this single thread here seems to have more action than the whole "Vue - General" section of the Cornucopia forum 👍
                                          -Miguel Lescano
                                            marked001
                                            here is one of my first scenes i'm working on in vue.. working on some test images for an upcoming game project.... all of the 'built' pieces are from sketchup (boats downloaded)...
                                            http://img4.imageshack.us/img4/14/dock101909.png
                                            instagram: revi21on
                                            • 6 / 7
