    SketchUp 7.1?
    151 Posts 68 Posters 38.4k Views 68 Watching
      linea
      I agree Kwist, finally a reason to pay for upgrading from pro 6.
        did some tests with the Speed Test model:
        SU7.0 - no shadows (also system specs)
        SU7.0 shadows
        SU7.1 no shadows (first run)
        SU7.1 shadows
        SU7.1 no shadows (second run - notice speed difference from first run. - strange)
          john.warburton
          Version 7.1 sounds worth the upgrade, and I did try to update my Pro on Vista this morning. But the update failed. I'll try again when I get back to my office this evening and post details of the error if it re-occurs, but has anyone else had problems with the upgrade?
          Life's a reach, and then you gybe.
            Did you try an automatic update from SU or a straight download of the exe file from the SU site first?
              john.warburton
              I used the automatic update link, but this just downloaded the EXE any way. I used Run as Administrator on the downloaded file.
                JuanV.Soler
                very nice update ¡
                in both,
                SketchUp and LayOut
                did not even think about the possibility of this gift.
                so, many thanks to whom corresponds
                  Hm. I don't know what the issue can be - true that I am on an XP (hopefully someone using Vista can chime in).
                  If it fails again, can you report it in the Bug Reports subforum? I believe "Googlers" will be monitoring that department more frequently in the near future.
                    remus
                    The download may have corrupted, so it might be worth downloading it again just in case.
                      Starling75
                      Great, it spins around SU7. Support of larger models is very helpfull and it seems that zooming was improved as well.
                      Switching on camera parallel projection I can zoom into small details almost indefinitely..
                      Omission of Dwg/Dxf import in free version ... well SU 6 will fix that....and I will probably upgrade to PRO 8.. 9 later ( depends on 2D tools improvements in LayOut..etc)
                      http://www.starlingarch.cz
                        steelers05
                        very good news to wake up to. It is a step in the right direction and hopefully it is a sign of things to come. Lets see how SU likes some xfrog trees now.
                          Well, take it easy with those xfrogs 😄
                          • EdsonE Offline
                            Edson
                            @chris fullmer said:
                            But there is a UI reset button.
                            is this what you are referring to?
                            http://www.mahfuz.arq.br
                              steelers05
                              Ok how do I go about updating this...I tried the "check for updates" option within SU and it say that I already have the lates version, but I am still running version 6. Then I went to the website and cant find anything about a free update. It is free to go from 6 to 7.1 right?
                              • soloS Offline
                                6 pro to 7 pro?
                                  steelers05
                                  yeah pro
                                  • StinkieS Offline
                                    Stinkie
                                    Not free then. 7.1's a free upgrade - but 7 wasn't.
                                      john.warburton
                                      SU Free users who want to retain DXF/DWG capabilities after the next major upgrade should probably just make sure that they keep a copy of version 6. A bit of a pain to load into 6, save a SU file, then open that in 8 (or 7.1) I know, but cheaper than upgrading to Pro.
                                        sepo
                                        You can download dxf/dwg plugin from the Google site.
                                          steelers05
                                          thanks
                                          • Chris FullmerC Offline
                                            Yes, I think so. But I realized only after posting that it only resets the components window, materials, entity info, etc. It does not touch the toolbars from what Google has said. I have not used it actually. But I'm afraid it will not help with toolbars at all. Not even to reset them 😞
                                            • 5 / 8
