    SketchUp 7.1?
    151 Posts 68 Posters 59.9k Views 68 Watching
      john.warburton
      Version 7.1 sounds worth the upgrade, and I did try to update my Pro on Vista this morning. But the update failed. I'll try again when I get back to my office this evening and post details of the error if it re-occurs, but has anyone else had problems with the upgrade?
      Life's a reach, and then you gybe.
      • GaieusG
        Did you try an automatic update from SU or a straight download of the exe file from the SU site first?
          john.warburton
          I used the automatic update link, but this just downloaded the EXE any way. I used Run as Administrator on the downloaded file.
            JuanV.Soler
            very nice update ¡
            in both,
            SketchUp and LayOut
            did not even think about the possibility of this gift.
            so, many thanks to whom corresponds
            • GaieusG
              Hm. I don't know what the issue can be - true that I am on an XP (hopefully someone using Vista can chime in).
              If it fails again, can you report it in the Bug Reports subforum? I believe "Googlers" will be monitoring that department more frequently in the near future.
                remus
                The download may have corrupted, so it might be worth downloading it again just in case.
                  Starling75
                  Great, it spins around SU7. Support of larger models is very helpfull and it seems that zooming was improved as well.
                  Switching on camera parallel projection I can zoom into small details almost indefinitely..
                  Omission of Dwg/Dxf import in free version ... well SU 6 will fix that....and I will probably upgrade to PRO 8.. 9 later ( depends on 2D tools improvements in LayOut..etc)
                  http://www.starlingarch.cz
                    steelers05
                    very good news to wake up to. It is a step in the right direction and hopefully it is a sign of things to come. Lets see how SU likes some xfrog trees now.
                    • GaieusG
                      Well, take it easy with those xfrogs 😄
                      • EdsonE
                        Edson
                        @chris fullmer said:
                        But there is a UI reset button.
                        is this what you are referring to?
                        http://www.mahfuz.arq.br
                          steelers05
                          Ok how do I go about updating this...I tried the "check for updates" option within SU and it say that I already have the lates version, but I am still running version 6. Then I went to the website and cant find anything about a free update. It is free to go from 6 to 7.1 right?
                          • soloS
                            6 pro to 7 pro?
                              steelers05
                              yeah pro
                              • StinkieS
                                Stinkie
                                Not free then. 7.1's a free upgrade - but 7 wasn't.
                                  john.warburton
                                  SU Free users who want to retain DXF/DWG capabilities after the next major upgrade should probably just make sure that they keep a copy of version 6. A bit of a pain to load into 6, save a SU file, then open that in 8 (or 7.1) I know, but cheaper than upgrading to Pro.
                                    sepo
                                    You can download dxf/dwg plugin from the Google site.
                                      steelers05
                                      thanks
                                      • Chris FullmerC
                                        Yes, I think so. But I realized only after posting that it only resets the components window, materials, entity info, etc. It does not touch the toolbars from what Google has said. I have not used it actually. But I'm afraid it will not help with toolbars at all. Not even to reset them 😞
                                        • AnssiA
                                          Anssi
                                          I was quite happy to notice that SU orbiting got more speedy even with my old Pentium IV machines with graphics cards way below the spec recommended today.
                                          Anssi
                                            JuanV.Soler
                                            I dont know if this new locking feature has been mentioned yet or not,
                                            I find it great ¡
                                            again, thanks
                                            • 4 / 8
