Product Ideas for SketchUp
Until October - feel free to share your ideas:
http://productideas.appspot.com/#16/e=2191e -
Support multiple processors
Stupid setup, I posted an idea that was specific and I was told to vote for one similar, yet the options were nothing close to my suggestion.
Same thing happened to me
but there was an option to post anyway. -
There's a tab to see all New Ideas. Your idea should have appeared there.
Is this what you were looking for? -
Dedicated import/export to Poser. Not through the .obj/.3ds file, but one with full hierarchy, bones, body parts, textures, etc.
Pleeeeeease!
Solo,
when it asks you to vote for a similar idea, you can still choose to vote for yours. At least that worked for me.
It's all good, I have a thread someplace here on this forum that will probably larger acknowledgement and participation.
just the basics: multiprocessor support and an interface that doesn't freak out (as in tool bars that retain their location!)
that'll do. -
Why not enable us pro users to drag and drop the files SU can import? OR Make Sketchup import the things it's able to import when we choose open with sketchup? Then the users like me who always start with an existing file (me: dxf) don't have to launch SU and import 50 times a day. We could set SU as the default for those files and double click.
Not sure if asking for multiprocessor support is much point. Instead, ask for what you expect the results to be when you ask for multiprocessor support - faster speed. Let them decide how to implement it. Hard to make assumption to what can be done.
Hi guys,
I have also added the request for Ruby 1.9.0 or later. Make sure to vote for it
As it might be lost among all suggestions, you can always find it using the search at the top of the page. Keyword: ruby 1.9.0.Cheers,
JernejPS: I have some more suggestions, but I can not post them anymore. I always get "Error parsing response"... Does anyone have similar problems?
I had similar problem. To me it worked again after I just typed "test", then when I suggested other similar ideas I type in my real request again.
Good suggestions btw - I'll make sure to vote for it.
I know it's a very basic suggestion, but I've suggested that the VCB window should be longer in size (!). Perhaps there's a way of doing this, but I have never figured it out?
Tom
I'm surprised that this isn't already supported considering that SU is one of the few CAD systems that has actually been built in Apple's Cocoa. Cheetah3D is another Cocoa app, and this automatically makes use of any multiprocessors- especially when rendering. Because of Cocoa, shouldn't SU also automatically be 64-bit too? Maybe I'm just having fanboy disillusions?
From what the developers have said its actually quite hard to thread the major elements in SU, so that is most likely why there isnt multi processor support yet.
Intel plans already to combine hundreds of atom chips (or even smaller chips) to spare energy. So I think multi core support is something that should be solved by operating systems and not by every single application. It is insane when every little programmer has to struggle with this.
I can imagine that virtualization could supply a solution. With VirtualBox I can simulate a 32 core system. I have not tried if it is possible to simulate less cores than I actually have.Does someone know more about this?
The Sketchup developers said that they will optimize the communication between processes in the graphics card and processes on the cpu (because they are closely linked).
Its really not as easy as you make out. For an app to be multi threaded there needs to be definite separate processes that can run at the same time without having to 'talk' to each other. Although operating systems can make multi threading easier they can certainly not eliminate the need for a program to be written in a multi threaded manner.
My suggestion is much simpler. have 1 extra drop down box inside the entity info box. I think it should be some type of record button that lets you choose wher you want the entity info results placed for later use (spead sheet or note pad etc etc).
It's now closed. Thanks for posting this, Gai, and thanks for the feedback, all.
b
