    SketchUp 7.1?
    151 Posts 68 Posters 54.8k Views 68 Watching
      Khai
      ok moving round a large model and monitoring both cores I am seeing distrubtion on both cores over 50% on each (more in the 75%-85% range on both at once!) it looks promising.....
      confirmed. just saw 85% on both cores at once from Sketchup.exe.
      (to be clear, on a normal SU 7 or non threaded app, I'll see 50% tops on both from Windows doing the sharing)
      edit it is uneven tho.... maybe I'm wrong shrug
      • soloS Offline
        Personally I doubt SU uses more than the primary core, however I have internet explorer open, SU 7.1 and rendering a heavy scene with Twilight and my resources look like the primary core is at full speed (I have turbo on in i7 setup) yet other 7 threads all seem to have jumped into full swing as soon as I hit render, hmm, so I dunno.
        940 i7, 12gb ddr3, 64bit
          kwistenbiebel
          Good news. A faster sketchup!
          Exactly what I need. Will be trying it out at the office today.
          This could be the reason to finally upgrade to 7.....
          @solo: Yes, that looks like multicore hasn't been implemented yet. But seeing current speed improvement, we could still expect a hugh performance jump when Google decides to support it. Exciting times ahead.
          • honoluludesktopH Offline
            honoluludesktop
            Well it looks like Google was listening to its user base, as well as making SU into whatever their vision for the product is. Whenever I see another pretty face, I always think about SU's user base, and all the wonderful people here who add so much to the program.
            As for DXF in SU v8.0+, $500 a seat is a lot to pay for a translator so unless Google changes their mind, I better learn to benefit from layout, dynamic components, and programming in ruby.
              BTM
              The Collada exporter works well; with the KMZ > ZIP > folder method, I noticed textures wouldn't always work properly. Now they do, and it seems to separate into objects by material, like kerkythea seems to do with it's exporter.
              One issue I noticed with the new exporter, at least when I import into Blender, is that the size of the model is gigantic, and has to be scaled considerably ( a minor nuisance). 😒
                Aerilius
                I myself don't believe in multi core, but this is what happens when I rotate and stop rotating my model 3 times.
                multi core? or is this normal on windows xp?
                From reading between the lines, I know for some months that the SU team was working on a new rendering engine. They are so proud of it, I can not believe they would keep multi core still secret.
                • X Offline
                  xrok1
                  i hope i never have to pick my toolbars off the floor again! 😲 any news if THAT issue has been fixed. 😐
                  • Chris FullmerC Offline
                    That has not been fixed. But there is a UI reset button. I tihnk it mostly helps if you lose a toolbar on a 2nd monitor that is no longer plugged in though... So probably no help for the real toolbar issue.
                      DIEGO-RODRIGUEZ
                      • X Offline
                        xrok1
                        • E Offline
                          Ecuadorian
                          My toolbars seem perfectly stable now; they stick exactly where I place them. I'm on Windows XP SP2.
                          -Miguel Lescano
                            kwistenbiebel
                            We'll be upgrading our licenses from v.6 to v.7 now.
                            Thank you Google!
                            A faster SU (could still improve a lot though), much better Layout, UI reset, etc.... Very good!
                            Now let's hope GSU team can continue on the same pace for next release.
                            I have the feeling they are on the right track now.
                              linea
                              I agree Kwist, finally a reason to pay for upgrading from pro 6.
                                did some tests with the Speed Test model:
                                SU7.0 - no shadows (also system specs)
                                SU7.0 shadows
                                SU7.1 no shadows (first run)
                                SU7.1 shadows
                                SU7.1 no shadows (second run - notice speed difference from first run. - strange)
                                  john.warburton
                                  Version 7.1 sounds worth the upgrade, and I did try to update my Pro on Vista this morning. But the update failed. I'll try again when I get back to my office this evening and post details of the error if it re-occurs, but has anyone else had problems with the upgrade?
                                  Life's a reach, and then you gybe.
                                    Did you try an automatic update from SU or a straight download of the exe file from the SU site first?
                                      john.warburton
                                      I used the automatic update link, but this just downloaded the EXE any way. I used Run as Administrator on the downloaded file.
                                        JuanV.Soler
                                        very nice update ¡
                                        in both,
                                        SketchUp and LayOut
                                        did not even think about the possibility of this gift.
                                        so, many thanks to whom corresponds
                                          Hm. I don't know what the issue can be - true that I am on an XP (hopefully someone using Vista can chime in).
                                          If it fails again, can you report it in the Bug Reports subforum? I believe "Googlers" will be monitoring that department more frequently in the near future.
                                            remus
                                            The download may have corrupted, so it might be worth downloading it again just in case.
                                            • 3 / 8
