    SketchUp 7.1?
    151 Posts 68 Posters 57.1k Views 68 Watching
    • soloS
      Personally I doubt SU uses more than the primary core, however I have internet explorer open, SU 7.1 and rendering a heavy scene with Twilight and my resources look like the primary core is at full speed (I have turbo on in i7 setup) yet other 7 threads all seem to have jumped into full swing as soon as I hit render, hmm, so I dunno.
      940 i7, 12gb ddr3, 64bit
      • K
        kwistenbiebel
        Good news. A faster sketchup!
        Exactly what I need. Will be trying it out at the office today.
        This could be the reason to finally upgrade to 7.....
        @solo: Yes, that looks like multicore hasn't been implemented yet. But seeing current speed improvement, we could still expect a hugh performance jump when Google decides to support it. Exciting times ahead.
        • honoluludesktopH
          honoluludesktop
          Well it looks like Google was listening to its user base, as well as making SU into whatever their vision for the product is. Whenever I see another pretty face, I always think about SU's user base, and all the wonderful people here who add so much to the program.
          As for DXF in SU v8.0+, $500 a seat is a lot to pay for a translator so unless Google changes their mind, I better learn to benefit from layout, dynamic components, and programming in ruby.
          • B
            BTM
            The Collada exporter works well; with the KMZ > ZIP > folder method, I noticed textures wouldn't always work properly. Now they do, and it seems to separate into objects by material, like kerkythea seems to do with it's exporter.
            One issue I noticed with the new exporter, at least when I import into Blender, is that the size of the model is gigantic, and has to be scaled considerably ( a minor nuisance). 😒
              Aerilius
              I myself don't believe in multi core, but this is what happens when I rotate and stop rotating my model 3 times.
              multi core? or is this normal on windows xp?
              From reading between the lines, I know for some months that the SU team was working on a new rendering engine. They are so proud of it, I can not believe they would keep multi core still secret.
              • X
                xrok1
                i hope i never have to pick my toolbars off the floor again! 😲 any news if THAT issue has been fixed. 😐
                • Chris FullmerC
                  That has not been fixed. But there is a UI reset button. I tihnk it mostly helps if you lose a toolbar on a 2nd monitor that is no longer plugged in though... So probably no help for the real toolbar issue.
                    DIEGO-RODRIGUEZ
                    • X
                      xrok1
                      • E
                        Ecuadorian
                        My toolbars seem perfectly stable now; they stick exactly where I place them. I'm on Windows XP SP2.
                        -Miguel Lescano
                        • K
                          kwistenbiebel
                          We'll be upgrading our licenses from v.6 to v.7 now.
                          Thank you Google!
                          A faster SU (could still improve a lot though), much better Layout, UI reset, etc.... Very good!
                          Now let's hope GSU team can continue on the same pace for next release.
                          I have the feeling they are on the right track now.
                          • L
                            linea
                            I agree Kwist, finally a reason to pay for upgrading from pro 6.
                              did some tests with the Speed Test model:
                              SU7.0 - no shadows (also system specs)
                              SU7.0 shadows
                              SU7.1 no shadows (first run)
                              SU7.1 shadows
                              SU7.1 no shadows (second run - notice speed difference from first run. - strange)
                                john.warburton
                                Version 7.1 sounds worth the upgrade, and I did try to update my Pro on Vista this morning. But the update failed. I'll try again when I get back to my office this evening and post details of the error if it re-occurs, but has anyone else had problems with the upgrade?
                                Life's a reach, and then you gybe.
                                • GaieusG
                                  Did you try an automatic update from SU or a straight download of the exe file from the SU site first?
                                    john.warburton
                                    I used the automatic update link, but this just downloaded the EXE any way. I used Run as Administrator on the downloaded file.
                                      JuanV.Soler
                                      very nice update ¡
                                      in both,
                                      SketchUp and LayOut
                                      did not even think about the possibility of this gift.
                                      so, many thanks to whom corresponds
                                      • GaieusG
                                        Hm. I don't know what the issue can be - true that I am on an XP (hopefully someone using Vista can chime in).
                                        If it fails again, can you report it in the Bug Reports subforum? I believe "Googlers" will be monitoring that department more frequently in the near future.
                                          remus
                                          The download may have corrupted, so it might be worth downloading it again just in case.
                                            Starling75
                                            Great, it spins around SU7. Support of larger models is very helpfull and it seems that zooming was improved as well.
                                            Switching on camera parallel projection I can zoom into small details almost indefinitely..
                                            Omission of Dwg/Dxf import in free version ... well SU 6 will fix that....and I will probably upgrade to PRO 8.. 9 later ( depends on 2D tools improvements in LayOut..etc)
                                            http://www.starlingarch.cz
                                            • 3 / 8
