    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.6m Views 202 Watching
    • takesh hT Offline
      takesh h
      @dan said:
      I replaced the icons in "IMAGES_Standard" subfolder with the icons set of choice and all went ok.
      Yes the trick did the job, thanks Dan. 👍
        dylan
        Thanks Dan, perfect!
        I was trying to replace them in images DanielS.
        http://dmdarchitecture.co.uk/
        • olisheaO Offline
          olishea
          I love this tool, I use it all the time.
          Endless thanks 😍 😍 😍
          oli
          • fredo6F Offline
            @dan said:
            A wish, though: can you make the additional TOS palette to remember its position on screen from a SU session to another?
            You can specify the default position in the SeTtings dialog box of LibFredo6 (so in the Windows > LibFredo6 Settings menu).
            • fredo6F Offline
              Can't get Daniels icons to show. If I choose them from Default Parameters and ok it, nothing happens. If I open again, the tick in the box is gone.
              It seems there is a problem with that, but only on Mac.
              I am checking this issue.
              • MALAISEM Offline
                MALAISE
                Merci Fredo, I watched the video, that gives us new horizons.... 👍
                MALAISE
                  Dan
                  Thanks a lot, Fredo!
                  I completely forgot I can use it to change the default parameters... 😳
                  This is one of the most complete plugins I see.
                  Thanks again!
                    lorca
                    That did the trick:)------> Thanks.
                    • fredo6F Offline
                      Dan and Dylan (and any others having the problem of non-persistence of the choice of Icons)
                      I have a few questions:
                      1. does it happen on Mac only?
                      2. Are all other parameters shown in the Button palettes saved across Sketchup sessions (i.e. nb of segments, options, etc...) ?
                      3. Could someone send me by PM the file ToolsOnSurface.def in the subfolder DEFPARAM_Dir.
                        gaonirico
                        Hi Fredo. Grandiose plugins that have created. But I have a problem, after that installed the new version of ToolsOnSurface 1.5. In SketchUp the option to translate the tools with LibFredo6 appears blank, as also the option to translate ToolsOnSurface. The remainder of the tools to translate function very well, as those of GhostComponent or RoundCorner. In spite of the inconvinient of can translate all tools function perfect they...Oh, I am sorry if not very clear for my poor speak english. 😳
                        • fredo6F Offline
                          @gaonirico said:
                          :sketchstatic: Hi Fredo. Grandiose plugins that have created. But I have a problem, after that installed the new version of ToolsOnSurface 1.5. In SketchUp the option to translate the tools with LibFredo6 appears blank, as also the option to translate ToolsOnSurface.
                          I noticed the problem which seems to be only in SU6 and only the very first time you open the translation dialog box. I am going to investigate.
                          In between, if you slightly resize the dialog box or close and re-open it, you'll get the content. This is not specific to ToolsOnSurface.
                          Are you going to translate into Spanish? Any language...., thank you in advance
                            gaonirico
                            Thanks for your answer. The problem proved to be that I must erase the ToolsOnSurface 1.2 TOS_Dir_13 folder. Now it works well. When I am finishes make the corresponding translation to the Spanish will give you the corresponding LANG file.
                              cyan.archnet
                              will definitely give this a try!, A BIG THANK YOU!! for this awesome plugin!!
                              • boofredlayB Offline
                                boofredlay
                                I just installed the update and I don't even have the option to choose an icon set in the Default Parameters. I am on a PC with XP.
                                DP.jpgAlso, I noticed that when I deleted the old LIBFREDO6_Dir_32 and TOS_Dir_13 folders my TOS toolbar disappeared. It reappeared after restoring those folders.
                                Any ideas?
                                Thanks.
                                • EarthMoverE Offline
                                  EarthMover
                                  I've had a chance to really play with the refreshed version....WOW!! You have really thought of everything! I find myself using these drawing tools for so much more than just on a curved surface. They are great to use on coplanar surfaces as well!
                                  Between Joint Push Pull, Round Edges, Tools on Surface and Bezier Tools, you've single handedly propelled SU into a league of it's own. You make other apps feel down right tedious. THANK YOU AGAIN!!
                                  Content Creator at Skapeup
                                  • fredo6F Offline
                                    The options for alternate icons (and icons shown in the toolbar) are in the Default Parameter of ToolsOnSurface, not of LibFredo6.
                                    Also, do not forget to install LibFredo6 3.4
                                      boofredlay
                                      And I think this is the second time I asked you about this, sorry 😳
                                      It is working fine.
                                      I did have LibFredo 3.4 installed when I removed the older directories. I restarted SU and the toolbar went away. However, somehow (assuredly due to operator error) when I remove it now and restart SU everything is fine.
                                      Sorry for the bother and thanks again for the plugin.
                                        Daniel S
                                        Fredo... Is not working the explicit selection for the offset on surface? (Select first Edges and Faces in the model, then start the tool).
                                        Most of the things are possible with the implicit selection but now that I want to offset some edges it becomes impossible.
                                        Daniel S
                                        • fredo6F Offline
                                          Daniel,
                                          Thanks for signaling this bug (which was introduced with 1.5a).
                                          I made a fix and updated the main post with version 1.5d. It also includes the Spanish translation by Gaonirico.
                                            Daniel S
                                            Great!!! Thank you for the updated version!!!
                                            Daniel S
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 31
                                            • 32
                                            • 19 / 32
