    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.4m Views 342 Watching
      ccad
      A wonderful plugin... What else... 😉
        RDailey
        Fredo,
        I can't seem to download your Fredoscale plugin in its' suppporting files. All I get where the plugin should be is:
        You do not have the required permissions to view the files attached to this post.
        Is there anywhere else I might be able to go to snag this plugin and its' supporting files.
        R Dailey
        • Jean-FrancoJ Offline
          Jean-Franco
          Dear R Dailey,
          to see and download any files you must be a register member of this forum first.
          Jean-Franco
            Marla
            Thank you very much Fredo for your plugin.
            You're really a fantastic person ! 😄
            ¬ See Further, Never Give In. Whatever The Number Or The Task. ¬
              kenkan2
              i really want this plugin!! But i can't download the attachment....."You are not authorised to download this attachment"....WHY!!??
              • fredo6F Offline
                I guess you need to register and sign in to the forum.
                  kenkan2
                  i have already registered and sign in....otherwise i can't reply.....
                  • fredo6F Offline
                    Then it may be a problem with the forum itself, where unfortunately I cannot help.
                      G DODDS
                      where can I find a link to thecurrent FredoScale zip? (please!)
                      • chonC Offline
                        chon
                        At the end of the first Fredo6's post of this thread i suppose... (2.0g version) 😉
                          muse
                          I just wanted to show my respect to "Fredo" like every one. because his job makes using SU more Fun and handy.
                          Thanks Fredo for this 😄
                          Cordially
                            bulbucila
                            Thank you1, this is great.
                            • X Offline
                              xrok1
                              not that this toolset isn't great enough already... but a divider in the scale tool like the stretch tool one would be the icing! 😍
                              • fredo6F Offline
                                Interesting idea, but of course, only when you scale by the Midle plane. I'll think of it.
                                • F Offline
                                  Foun10Head-X
                                  Thank you so much.
                                  • H Offline
                                    Hopit
                                    As a newbee I have been searching for this plugin.
                                    My first impression was that it had been folded into LibFredo6, but it didn't appear once I had loaded LibFredo6.
                                    My next flash was to search the Extensions Index, but no mention of FredoScale.
                                    However, I have found it! (At the beginning of this thread.)
                                    Marvellous!
                                    • jwlyon1J Offline
                                      jwlyon1
                                      I've been trying the twist and free bend tools from this plugin, but they don't seem to be working quite right. In this example from the visual index, it shows the tools subdividing the geometry as needed for a smooth bend or twist.
                                      http://forums.sketchucation.com/download/file.php?id=27666
                                      But when I try it, I get no subdividing! What am I doing wrong? What are the correct settings to make this work? I've tried reading the documentation, but I haven't found an answer.
                                      Thanks! Awesome plugin by the way -- the scale and taper tools are super duper useful!!
                                      Macbook Pro/ iMac
                                      OSX 10.7.2 Sketchup 8
                                      rogue-z is here!
                                      • jeff hammondJ Offline
                                        there are a couple of ways to get it.. one is to hit F4 to activate the slicing (and since you're on a mac, your f keys are probably set to other things like volume,expose,etc.. you'll have to push the 'fn' key along with F4 in the same manner as using the shift key with 3 to get a #...)
                                        another thing to do is to go Tools/Fredo6 Collection/FredoScale/Default Parameters.. click 'slicing active by default' then save your changes..
                                        and it's a little weird on mac in that you may have to click the box, then unclick it, then click it again.. you want the whole line to be highlighted in yellow with the box clicked before saving.. like this..
                                        also, once you have the tool activated, you can push the tab key and a little box will pop up... in there, you can change the number of slices you'd like to use (or with the bend tool, use a negative number for auto division) as well as decide if you want the resulting shape to be smoothed, keep edges, etc..
                                        • jwlyon1J Offline
                                          jwlyon1
                                          Okay! It works from right-clicking too, thanks!! The clicking-unclicking-clicking again was the key!
                                          Macbook Pro/ iMac
                                          rogue-z is here!
                                            DIEGO-RODRIGUEZ
                                            Hi fredo, I used your plugins fredoscale, and scale / move the component simultaneously.
                                            Is this normal?
                                            [flash=425,344:31uc4nee]http://www.youtube.com/v/6mxSL5170dE[/flash:31uc4nee]
                                            fredoscale.rar
                                            • 56
                                            • 57
                                            • 7 / 57
