    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.5m Views 345 Watching
      Marla
      Thank you very much Fredo for your plugin.
      You're really a fantastic person ! 😄
      ¬ See Further, Never Give In. Whatever The Number Or The Task. ¬
      • K
        kenkan2
        i really want this plugin!! But i can't download the attachment....."You are not authorised to download this attachment"....WHY!!??
        • fredo6F
          I guess you need to register and sign in to the forum.
          • K
            kenkan2
            i have already registered and sign in....otherwise i can't reply.....
            • fredo6F
              Then it may be a problem with the forum itself, where unfortunately I cannot help.
              • G
                G DODDS
                where can I find a link to thecurrent FredoScale zip? (please!)
                • chonC
                  chon
                  At the end of the first Fredo6's post of this thread i suppose... (2.0g version) 😉
                  SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win11-64Bits
                    muse
                    I just wanted to show my respect to "Fredo" like every one. because his job makes using SU more Fun and handy.
                    Thanks Fredo for this 😄
                    Cordially
                    • B
                      bulbucila
                      Thank you1, this is great.
                      • X
                        xrok1
                        not that this toolset isn't great enough already... but a divider in the scale tool like the stretch tool one would be the icing! 😍
                        • fredo6F
                          Interesting idea, but of course, only when you scale by the Midle plane. I'll think of it.
                          • F
                            Foun10Head-X
                            Thank you so much.
                            • H
                              Hopit
                              As a newbee I have been searching for this plugin.
                              My first impression was that it had been folded into LibFredo6, but it didn't appear once I had loaded LibFredo6.
                              My next flash was to search the Extensions Index, but no mention of FredoScale.
                              However, I have found it! (At the beginning of this thread.)
                              Marvellous!
                              • jwlyon1J
                                jwlyon1
                                I've been trying the twist and free bend tools from this plugin, but they don't seem to be working quite right. In this example from the visual index, it shows the tools subdividing the geometry as needed for a smooth bend or twist.
                                http://forums.sketchucation.com/download/file.php?id=27666
                                But when I try it, I get no subdividing! What am I doing wrong? What are the correct settings to make this work? I've tried reading the documentation, but I haven't found an answer.
                                Thanks! Awesome plugin by the way -- the scale and taper tools are super duper useful!!
                                Macbook Pro/ iMac
                                OSX 10.7.2 Sketchup 8
                                rogue-z is here!
                                • jeff hammondJ
                                  there are a couple of ways to get it.. one is to hit F4 to activate the slicing (and since you're on a mac, your f keys are probably set to other things like volume,expose,etc.. you'll have to push the 'fn' key along with F4 in the same manner as using the shift key with 3 to get a #...)
                                  another thing to do is to go Tools/Fredo6 Collection/FredoScale/Default Parameters.. click 'slicing active by default' then save your changes..
                                  and it's a little weird on mac in that you may have to click the box, then unclick it, then click it again.. you want the whole line to be highlighted in yellow with the box clicked before saving.. like this..
                                  also, once you have the tool activated, you can push the tab key and a little box will pop up... in there, you can change the number of slices you'd like to use (or with the bend tool, use a negative number for auto division) as well as decide if you want the resulting shape to be smoothed, keep edges, etc..
                                  • jwlyon1J
                                    jwlyon1
                                    Okay! It works from right-clicking too, thanks!! The clicking-unclicking-clicking again was the key!
                                    Macbook Pro/ iMac
                                    rogue-z is here!
                                      DIEGO-RODRIGUEZ
                                      Hi fredo, I used your plugins fredoscale, and scale / move the component simultaneously.
                                      Is this normal?
                                      [flash=425,344:31uc4nee]http://www.youtube.com/v/6mxSL5170dE[/flash:31uc4nee]
                                      fredoscale.rar
                                      • jeff hammondJ
                                        Is this normal?
                                        elcorto,
                                        you can toggle how the stretching is done.. i use the option key (mac) so i assume you would use the ctrl key on pc..
                                        try clicking on one of the handles then press ctrl..
                                          DIEGO-RODRIGUEZ
                                          Thanks for responding.
                                          Squeezing the Ctrl key, something similar happens.
                                          [flash=425,344:2j62a2lq]http://www.youtube.com/v/7aCFeHoQSS4[/flash:2j62a2lq]
                                          • jeff hammondJ
                                            [EDIT -- OH WAIT 😄.. your second video shows everything i've describe in this post so ignore it.. so that's not what you wanted it to do? what exactly are you trying to accomplish? the stretch tool may be the wrong one to achieve what you want]
                                            try this --
                                            --select the stretching tool
                                            --hover the mouse arrow over one of the handles
                                            --wait for the tool tip to pop up (in your case, it will probably say 'green_ uniform from opposite point'
                                            --press the ctrl key (and let go of it -- you don't have to hold it down during the operation.. it's only a toggle switch)
                                            the tool tip should switch to 'green_ uniform from center' at which point one edge of your door will stay locked in place while you stretch.
                                            [* i'm assuming it's the ctrl key on PC.. if that's not doing it, try another key like option, tab, cmmd, alt etc..]
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 58
                                            • 59
                                            • 17 / 59
