    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.5m Views 345 Watching
      mpowell1234567890
      I cannot get it to work, every time I try to use it, It causes a bugsplat and Sketchup terminates. Is there a way to fix it?
      • jwlyon1J
        jwlyon1
        Wow. I've been using an older version for a month or so, but this one is amazing. Amazing...
        Macbook Pro/ iMac
        OSX 10.7.2 Sketchup 8
        rogue-z is here!
        • fredo6F
          You need to be more accurate on how this happens.
          Which tool? Which situation?
            dondanev
              MrPlanet
              ๐Ÿ˜ฎ I think i've been using theone with just taper and FreeScale, but this is AMAZING! Thanks a lot, Fredo6, really helps in aircraft modelling ๐Ÿ˜„
              I reject your reality and substitute my own.
              • B
                bianhai
                amazing. Amazing... ๐Ÿ‘
                • fredo6F
                  Thanks.
                  If anyone of the bbs community wishes to give a try for the chinese translation....
                  • szaniniS
                    szanini
                    Thank you, thank you, thank you!!! and again thank you...
                    • C
                      ccad
                      A wonderful plugin... What else... ๐Ÿ˜‰
                        RDailey
                        Fredo,
                        I can't seem to download your Fredoscale plugin in its' suppporting files. All I get where the plugin should be is:
                        You do not have the required permissions to view the files attached to this post.
                        Is there anywhere else I might be able to go to snag this plugin and its' supporting files.
                        R Dailey
                        • Jean-FrancoJ
                          Jean-Franco
                          Dear R Dailey,
                          to see and download any files you must be a register member of this forum first.
                          Jean-Franco
                            Marla
                            Thank you very much Fredo for your plugin.
                            You're really a fantastic person ! ๐Ÿ˜„
                            ยฌ See Further, Never Give In. Whatever The Number Or The Task. ยฌ
                            • K
                              kenkan2
                              i really want this plugin!! But i can't download the attachment....."You are not authorised to download this attachment"....WHY!!??
                              • fredo6F
                                I guess you need to register and sign in to the forum.
                                • K
                                  kenkan2
                                  i have already registered and sign in....otherwise i can't reply.....
                                  • fredo6F
                                    Then it may be a problem with the forum itself, where unfortunately I cannot help.
                                    • G
                                      G DODDS
                                      where can I find a link to thecurrent FredoScale zip? (please!)
                                      • chonC
                                        chon
                                        At the end of the first Fredo6's post of this thread i suppose... (2.0g version) ๐Ÿ˜‰
                                        SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win11-64Bits
                                          muse
                                          I just wanted to show my respect to "Fredo" like every one. because his job makes using SU more Fun and handy.
                                          Thanks Fredo for this ๐Ÿ˜„
                                          Cordially
                                          • B
                                            bulbucila
                                            Thank you1, this is great.
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 58
                                            • 59
                                            • 17 / 59
