    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.5m Views 345 Watching
    • fredo6F
      @bianhai said:
      amazing. Amazing... ๐Ÿ‘
      Thanks.
      If anyone of the bbs community wishes to give a try for the chinese translation....
      • szaniniS
        szanini
        Thank you, thank you, thank you!!! and again thank you...
        • C
          ccad
          A wonderful plugin... What else... ๐Ÿ˜‰
            RDailey
            Fredo,
            I can't seem to download your Fredoscale plugin in its' suppporting files. All I get where the plugin should be is:
            You do not have the required permissions to view the files attached to this post.
            Is there anywhere else I might be able to go to snag this plugin and its' supporting files.
            R Dailey
            • Jean-FrancoJ
              Jean-Franco
              Dear R Dailey,
              to see and download any files you must be a register member of this forum first.
              Jean-Franco
                Marla
                Thank you very much Fredo for your plugin.
                You're really a fantastic person ! ๐Ÿ˜„
                ยฌ See Further, Never Give In. Whatever The Number Or The Task. ยฌ
                • K
                  kenkan2
                  i really want this plugin!! But i can't download the attachment....."You are not authorised to download this attachment"....WHY!!??
                  • fredo6F
                    I guess you need to register and sign in to the forum.
                    • K
                      kenkan2
                      i have already registered and sign in....otherwise i can't reply.....
                      • fredo6F
                        Then it may be a problem with the forum itself, where unfortunately I cannot help.
                        • G
                          G DODDS
                          where can I find a link to thecurrent FredoScale zip? (please!)
                          • chonC
                            chon
                            At the end of the first Fredo6's post of this thread i suppose... (2.0g version) ๐Ÿ˜‰
                            SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win11-64Bits
                              muse
                              I just wanted to show my respect to "Fredo" like every one. because his job makes using SU more Fun and handy.
                              Thanks Fredo for this ๐Ÿ˜„
                              Cordially
                              • B
                                bulbucila
                                Thank you1, this is great.
                                • X
                                  xrok1
                                  not that this toolset isn't great enough already... but a divider in the scale tool like the stretch tool one would be the icing! ๐Ÿ˜
                                  โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                                  • fredo6F
                                    Interesting idea, but of course, only when you scale by the Midle plane. I'll think of it.
                                    • F
                                      Foun10Head-X
                                      Thank you so much.
                                      • H
                                        Hopit
                                        As a newbee I have been searching for this plugin.
                                        My first impression was that it had been folded into LibFredo6, but it didn't appear once I had loaded LibFredo6.
                                        My next flash was to search the Extensions Index, but no mention of FredoScale.
                                        However, I have found it! (At the beginning of this thread.)
                                        Marvellous!
                                        • jwlyon1J
                                          jwlyon1
                                          I've been trying the twist and free bend tools from this plugin, but they don't seem to be working quite right. In this example from the visual index, it shows the tools subdividing the geometry as needed for a smooth bend or twist.
                                          http://forums.sketchucation.com/download/file.php?id=27666
                                          But when I try it, I get no subdividing! What am I doing wrong? What are the correct settings to make this work? I've tried reading the documentation, but I haven't found an answer.
                                          Thanks! Awesome plugin by the way -- the scale and taper tools are super duper useful!!
                                          Macbook Pro/ iMac
                                          OSX 10.7.2 Sketchup 8
                                          rogue-z is here!
                                          • jeff hammondJ
                                            there are a couple of ways to get it.. one is to hit F4 to activate the slicing (and since you're on a mac, your f keys are probably set to other things like volume,expose,etc.. you'll have to push the 'fn' key along with F4 in the same manner as using the shift key with 3 to get a #...)
                                            another thing to do is to go Tools/Fredo6 Collection/FredoScale/Default Parameters.. click 'slicing active by default' then save your changes..
                                            and it's a little weird on mac in that you may have to click the box, then unclick it, then click it again.. you want the whole line to be highlighted in yellow with the box clicked before saving.. like this..
                                            also, once you have the tool activated, you can push the tab key and a little box will pop up... in there, you can change the number of slices you'd like to use (or with the bend tool, use a negative number for auto division) as well as decide if you want the resulting shape to be smoothed, keep edges, etc..
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 58
                                            • 59
                                            • 17 / 59
