    [Locked] 2D Toolset - Use Newer Version Link
    56 Posts 20 Posters 93.7k Views 20 Watching
      Edson
      You are Mac ? I'll investigate... I doesn't like the status_text ??? Seems that if first part is in () the second after the ',' confuses it ! BUT not on a PC - I'll ensure the update avoids that possibility...
      I am working on v2.0 which is quite different, so that might avoid the problem - perhaps needs a day or two...
      Please hang in there... πŸ˜„
        anglaret
        Tig
        I would be more precise
        In Layout tools/arc/pie; is a brillant and simple tool that draw doors from above
        I would be very very grateful for that tool in SU
        Marc
        • EdsonE
          Edson
          @tig said:
          Edson
          yes, tig, i am on mac. thanks for looking into this. this promises to be one more of your greatly useful plugins.
          http://www.mahfuz.arq.br
            @anglaret said:
            Tig
            Marc
            I intend that they'll be something like that in v2... ➑
            • honoluludesktopH
              honoluludesktop
              TIG, Out of curosity, how much time did it take you do do the plugin? Did you have templates to work from? As a retired amature programmer (pre OOPS), I find this kind of coding compact. Maybe I could learn something about ruby if you documented a little:-), or maybe I am just a old dog that can't:-( Good work.
                I took a few hours to get the first code out - look at the early exchanges with Jim -I based it on several pre-existing ideas... it then grew 'like topsy'... So far it's taken a couple of days to get where we are, on and off - I was away this weekend 'resting' and had T some better ideas for v2 that will be out soonest...
                πŸ’­
                • FletchF
                  Fletch
                  TIG,
                  I have wished for these tools since like the first day of using SketchUp!
                  Now SU can be an illustration tool too (I use it for this sometimes, logo design, etc.)
                  But now also I can trace these freaky CAD plans that look like they are flat but they are not, etc.
                  THANKS A MILLION... you are a legend in your own time.
                  Fletch
                  • utilerU
                    utiler
                    Hi TIG, downloaded the latest 2Dtoolset and having a play....
                    I noticed a few things that you may wish to review:
                    1. 2D Polyline doesn't acknowledge when it is on an axis. [change to green or red and tooltip to say "On Green axis"]
                    2. 2D Arc doesn't reference axises at all.
                    3. 2D circle doesn't acknowledge when it is on an axis either. [as per 2D polyline]
                    Wishlist
                    1. Arc to recognize tangents
                    2. Can 2D rectangle produce a closed entity?
                    Well done, mate, this is a great addition to GSU!!!
                    Just Curious...
                      Wishlist
                      Your items are already on the list for v2, as is wish 1. Wish 2 - we could make it a modifier key - e.g. raw rectangle is lines, with alt key it's a loop...
                      • utilerU
                        utiler
                        Or Ctrl key for the loop; not sure what is the 'norm' for use of shift/Alt/Ctrl keys when it comes to GSU....
                        I just find the physical location of Ctrl is easier to get used to than Atl; even considering Alt implies alternative...
                        Anyway, glad it is on the radar. πŸ‘
                        Just Curious...
                          I said Alt because it's an 'Alt'ernative to the normal that you'd toggle between [?] and I was thinking of using Ctrl for some other things like toggling between real_lines and Construction_guide_lines or for Arcs with Alt = Alternatives to reverse A-rc_direction and then Ctrl = make by_Center rather than 3_point ? Also Ctrl with Circle is to tooggle between 3_point and center+radius whilst Alt toggles between Radius or Diameter ?
                          • BepB
                            Bep
                            Hi Tig
                            Maybe this code wil be helpfull: http://old.blog.edu.cn/user2/autool/archives/2006/1604892.shtml
                            Greetings, Bep
                            "History is written by the winners"
                              Thanks for the ideas...
                              πŸ’­
                                Jim
                                I had the same thought about 2D radius - extracting the 2D radius/chamfer ; extend/trim lines from k-tools was on my shortlist of things to do. But it would fit in well in your 2D Tools.
                                Also, I am modifying my automatic centerpoints plugin so it will work with the circles and arcs created with this (or any other) ruby tools. As long as you continue to use add_circle, add_arc, or add_ngon (etc) jf_autocenterpoint should work.
                                  sjschloeder
                                  Hi TIG : I got an error message perhaps you can help me with. I downloaded the 2d Toolset to the downloads folder (Win 7 with SU8), then extracted everything directly to Google>Sketchup8>Plugins. When I restarted SU I got this:
                                  Error Loading File 2D#.rb
                                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/2DlineTool.rb:33: syntax error, unexpected ',', expecting kEND
                                  Sketchup::set_status_text ("Length"), SB_VCB_LABEL
                                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/2DlineTool.rb:71: syntax error, unexpected ',', expecting kEND
                                  ..."2D Line: Select Second End"), SB_PROMPT
                                  ^Error Loading File 2DarcTool.rb
                                  ^Error Loading File 2DcircleTool.rb
                                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/2DcircleTool.rb:37: syntax error, unexpected ',', expecting kEND
                                  Sketchup::set_status_text ("Radius"), SB_VCB_LABEL
                                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/2DcircleTool.rb:83: syntax error, unexpected ',', expecting kEND
                                  ...ircle: Select Point on Side"), SB_PROMPT
                                  ^Error Loading File 2DfacemakerTool.rb
                                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/2DfacemakerTool.rb:53: syntax error, unexpected ',', expecting kEND
                                  ...inside a Loop to Add a Face"), SB_PROMPT
                                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/2DfacemakerTool.rb:61: syntax error, unexpected ',', expecting kEND
                                  ^Error Loading File 2DhatchingTool.rb
                                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/2DhatchingTool.rb:74: syntax error, unexpected ',', expecting kEND
                                  ... Loop to Add a Hatched Face"), SB_PROMPT
                                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/2DhatchingTool.rb:88: syntax error, unexpected ',', expecting kEND
                                  ^Error Loading File 2DlineTool.rb
                                  ^Error Loading File 2DpolylinecurveTool.rb
                                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/2DpolylinecurveTool.rb:39: syntax error, unexpected ',', expecting kEND
                                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/2DpolylinecurveTool.rb:87: syntax error, unexpected ',', expecting kEND
                                  ...ne Curve: Select Next Point"), SB_PROMPT
                                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/2DpolylinecurveTool.rb:121: syntax error, unexpected ',', expecting kEND
                                  ^Error Loading File 2DpolylineTool.rb
                                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/2DpolylineTool.rb:39: syntax error, unexpected ',', expecting kEND
                                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/2DpolylineTool.rb:87: syntax error, unexpected ',', expecting kEND
                                  ... Polyine: Select Next Point"), SB_PROMPT
                                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/2DpolylineTool.rb:121: syntax error, unexpected ',', expecting kEND
                                  ...Polyline: Select Next Point"), SB_PROMPT
                                  I see you said something about "The 2D#.rb needs to load before the others to make the sub-menu and toolbar..." but I don't know how to force that, if that is the problem. My plugin folder looks like this now:
                                  Thanks for any help.
                                    This is the know 'problem' with v8 that is very intolerant of un-parenthesized arguments that used to work fine in v7... πŸ˜’
                                    I thought I had them all trapped - I revisited the code...
                                    β˜€ πŸ’­
                                    I've just realized that this is a very old version here's the latest set [v5]... http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
                                    Please download these and retry - I'll 'block' the older version...
                                    • O
                                      osage
                                      Hello Tig. I'm a little confused about the difference between these two threads, as they both are related to a 2d Toolset.
                                      404 Not Found
                                      (forums.sketchucation.com)
                                      and this thread.
                                      Is this 2d Toolset different than the set in the first thread? Or is it simply the latest version. I downloaded the set in the first thread. If I download the set in this thread, will it update the first one? Or am I simply confused...which wouldn't be the first time.
                                      confusingly
                                      fitZ
                                        The OTHER thread is where you can download the latest toolset - from the first post.
                                        This old thread is just hanging around !
                                        A new thread was made when there was a major seed change in the toolset ~2 years ago...
                                        I have previously edited the first post in this thread [ http://forums.sketchucation.com/viewtopic.php?p=180259#p180259 ] to link you to the latest version...
                                        One clue is in the titles... this one says 20090829 and the other one says 20111201 - making it far newer!
                                        Use the OTHER ONE ! πŸ˜’
                                        • B
                                          betod
                                          tig how are you and thanks for your help !! do you know how to make wiring in 2d and 3d in sketchup , you know like in autocad the doted line??
                                            Please post in the active thread http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
                                            I've now locked this topic to force people to use the correct one...
                                            The LineStyle tool allows you to make dotted/dashed lines of different thicknesses and color etc in 3d as well as 2d. However for considerable styled line work why not use Layout available with Pro which adds many of the functions of 2d CAD drafting to linked SKP views etc...
                                            • 3 / 3
