    [Plugin] SectionCutFace
    569 Posts 171 Posters 541.1k Views 170 Watching
    • massimoM
      massimo Moderator
      Sorry TIG, I got this error with the 2.3 version with a simple box model
      Error: #<NoMethodError: undefined methodset_visibility' for nil:NilClass>
      C:/Programmi/Google/Google SketchUp 6/Plugins/SectionCutFace.rb:383:in face' C:/Programmi/Google/Google SketchUp 6/Plugins/SectionCutFace.rb:451 C:/Programmi/Google/Google SketchUp 6/Plugins/SectionCutFace.rb:451:in call'`
      and i don't understand how the plug works with the scene/page transition. Draw a cube, add two scenes, in second scene make a section and add "section cut face". Is the below result the expected one?
      Thanks.
      Massimo.
      scene 1
      scene 2
        Here's v2.4
        404 Not Found
        (forums.sketchucation.com)
        Trapped layer visibility setting error if no pages/scenes set...
          Thanks.
          Massimo.
          Do you have any 'Pages' [Scenes] ?
          EDIT: see next message for fixing update...
          • massimoM
            massimo Moderator
            No error now, thanks. Real time plugins... ๐Ÿ˜„ But about the result?
            • massimoM
              massimo Moderator
              This is the situation after the cut with no scenes added, but if i add a scene before the cut no error occurs.
              EDIT: TIG answered with the 2.4 version before my reply ๐Ÿ˜„
                dimario
                this is just a fab plugin.
                thank you a lot. very helpful!!! saves a lot of time...
                kind regards...
                • GaieusG
                  Works really cool, thanks, TIG! ๐Ÿ‘
                  (And now... If only the section cut face would also move when I make a section animation/transition between two scenes! But sigh... I know, I know...) ๐Ÿ˜‰
                  • massimoM
                    massimo Moderator
                    That's exactly the result I was looking for, Gaieus. ๐Ÿ˜„
                    • GaieusG
                      ๐Ÿ˜ฎ
                      I didn't even expect it to be possible at all!
                      Fingers crossed however (and now all the exporter scripters for external renderers should start thinking about how to export these animated section cuts! ๐Ÿ˜„ )
                        I have a half-baked version that keeps bug-splatting ! It adds observers between the section-plane and the faced-group and remakes/moves them together... Don't expect it to be safe for public consumption soon... ๐Ÿ˜ž
                        • bmikeB
                          bmike
                          just downloaded. this should help with my longhand way of doing this!
                            anderskouv
                            I've only been using SU for half a year and I love it. But at the same time leaving autodesk for sketchup, I left pc for mac and I allso love that. Just one tiny little problem "sectioncutface"!!! Everyone gets saved by Tig, but what about me and my resentance to ever using pc again. Is there anything simular to OS x?! Help ๐Ÿ˜’ http://forums.sketchucation.com/posting.php?mode=reply&f=323&t=20564#
                              anderskouv
                              I posted a message one hour ago, but I have learned that the sectioncutface.rb does work with mac. Needed to make the folder Plugin in my libary. Thanks for the solution to a big problem.
                                Most scripts work on a MAC as well as a PC.
                                It's relatively easy to spot the platform and make minor internal adjustments to suit...
                                • L
                                  lazychild
                                  hum.. I have just installed this plugin.
                                  It does the cut but how do I render my section with V-ray after?
                                  Vray still seem to catch whats 'un-cut' and rendered my entire model.
                                  Thanks in advance.
                                    Thanks in advance.
                                    This tool only adds a filled in section-cut group - to do it so it's cut for Vray etc you need to copy the skp and then physically cut the model in two [using Zorro] and throw away the unwanted half - there's a detailed thread about this already - http://forums.sketchucation.com/viewtopic.php?p=184604#p184604
                                    • L
                                      lazychild
                                      Thanks in advance.
                                      Thank you very much!
                                      Just what i needed ๐Ÿ˜„
                                      • brookefoxB
                                        brookefox
                                        Thanks only. Pity the poor saps like me making building sections by hand, albeit an SUF hand...
                                        (Duh... must try the native 'creating grouped section slices' sometime.)
                                        The fortunate ones stumble on, perhaps to eventually find a real hand up.
                                        ~ Brooke
                                          ahornet
                                          thanks bro
                                          this is really good
                                            shoeb_cars
                                            this plugin was much much awaited TIG
                                            gracias amigo ๐Ÿ‘
                                            • 28
                                            • 29
                                            • 2 / 29
