    [Plugin] Blend ver 1.12.
    80 Posts 35 Posters 69.6k Views 35 Watching
    • W Offline
      watkins
      Dear Kirill,
      This is beginning to look like a very useful plugin. Thank you for all your hard work, and your generosity.
      Kind regards,
      Bob
      • MALAISEM Offline
        MALAISE
        Hi Kirill
        Thanks you for the job you've done on this second plugin. It's opening a new world of shapes.. 👍 👍
        MALAISE 😄
        • W Offline
          watkins
          Dear Kirill,
          I have just been trying out your plugin and note the following:
          • that the 'undo' doesn't work with your plugin, i.e., I cannot revert back to the drawing before your plugin is used, and
          • your plugin creates lines (steps) which are outside the group which contains the surface. One has to hide the group and then delete the lines. Is this how the plugin is meant to work?
          Looking good.
          Regards,
          Bob
            accabrera
            Great Plugin!!!
            Big Thank you
            • JClementsJ Offline
              JClements
              Krill, nice work. If you can get two objects to follow and blend along a third, curve (path) as was suggested above, then we've got a nice, easy-to-use taper tool.
              I am hoping you can do it.
              Thanks, John
                kirill2008
                Hi, Bob.
                Thank's a lot for your feedback, it really helps to improve the script. 👍
                @watkins said:
                Dear Kirill,
                Well, actually 'undo' works, but yes it sometimes (big steps count value and/or big segments count of initial curves) cannot revert back drawing.
                Animation shows '<Ctrl>+z' combination pressed effect.
                Now (ver 1.3) all steps of Blend command joined to the single command and can be undone as one single action.
                Yes, they are supposed to be separated. But now (ver 1.3) I decided to put curves to another separate group.
                Well, the final destination is an interactive blended object, that consists of 2 initial curves/faces and maybe a path. Interacting with initial curves and/or path has to affect the whole object. Sounds like a kind of challenge for me...
                • mitcorbM Offline
                  mitcorb
                  Very interesting tool, kirill:
                  Seems to have qualities of Skin.rb and Simple Loft.rb but on steroids.
                  Excellent work!
                  mitcorb
                    kirill2008
                    Little bonus video:
                    [flash=480,385:2yb89gf7]http://www.youtube.com/p/910E7CBB59CD05F8&amp;hl=ru&amp;fs=1" type="application/x-shockwave-flash" width="480" height="385" allowscriptaccess="always" allowfullscreen="true"[/flash:2yb89gf7]
                    Ver. 1.4 is able to process more or less complex geometry.
                      Daniel S
                      This plugins looks great!
                      What about blend colors too?
                      Here an example that creates intermediate faces and colors from two existing ones (2 steps).
                      Of course this is not sketchup, is only a simulation.
                      Daniel S
                        cosycat
                        Great script, i've been waiting for something like this for ages. Couple of odd bugs with circles (v1.4)
                        1. seems to miss out a segment when doing a blend
                        2. if you create the second circle with a move copy, you often get something like this
                        • kenK Offline
                          ken
                          Note sure if it me or note. But I tried V3 and was pleased with the results, however, V4 does not seem to display the same results. Note, I dont' have V3 any more, as I copied over the script, so this is from memory.
                          I particular like how if blended a square to a circle, now every time the output has folds or is not a straight blend from the square to the circle.
                          Ken
                          • mitcorbM Offline
                            mitcorb
                            yeah, I had a gap between the originating curve and the next intervening step toward the destination curve. Easily knitted together with line tool, and so forth, but just mentioning.
                            • utilerU Offline
                              utiler
                              This is a nice plugin, mate! I'm going to play!!!!
                              Just Curious...
                                tomot
                                Nice plugin! but still needs some tweaking.
                                I find it first works with a new fresh startup screen. but then the more experimenting I do with Blend the more inconsistant the results become, finally the Bend of the left Y's in the picture did not take place at all.
                                Error; #<NoMethodError; undefined method `vertices' for nil;NilClass>
                                C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/sublend.rb;45;in `blend'
                                C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/sublend.rb;174
                                C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/sublend.rb;153;in `call'
                                please don't give up!
                                [my plugins](http://thingsvirtual.blogspot.ca/)
                                tomot
                                  kirill2008
                                  Color blending demo video (for Daniel S 😉 😞
                                  [flash=425,344:1ki2zgl4]http://www.youtube.com/v/CqqRssCqONk&hl=ru&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:1ki2zgl4]
                                  cosycat, please try ver. 1.5. I tried to solve the problem of missing mesh pieces.
                                  tomot, I'll try to find out, what's the problem with rotated Y's...
                                  And speaking about the 3'd curve (the path): looks like, it demands a kind of major refactoring 😕 It is more complex task than I thought and it will take a little time...
                                    tomot
                                    I don't want you to misunderstand. This is not only related to the "y" shape. Other shapes have produced the same inconsistent results in SU 7.
                                    another example:
                                    make 2 identical closed shapes, scale one larger, apply bend, same code error occurs
                                    cheers.
                                    tomot
                                      kirill2008
                                      another example:
                                      Looks like it is SU7 issue... SU6 processes correctly:
                                      [flash=425,344:1p1mvbbo]http://www.youtube.com/v/1D8WUYsS9hw&hl=ru&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:1p1mvbbo]
                                      When processing faces it is necessary to select them by single click (not a fence).
                                      • majidM Offline
                                        majid
                                        woooow...it would be a dreamy plugin if no bugs!!..I gave it a try , but it seems that previous versions were better on freehand lines, while the last version doesn't works fine... also on closed line doesn;t works at all (su 6)..seeing forward to see the improvements mate btw thanks thanx thanx! 👍
                                          This is a useful plugin. Well, for me it was until I installed the latest version (1.5). Now I get what you see in the attached screen shot. Unfortunately I installed over the previous version. Keep working at it. I'm sure you'll get it all working.
                                          Thank you.
                                            Daniel S
                                            Thank you for adding color blending 😍 😍 😍
                                            I have problems with this new version too (I use SU7).
                                            Sometimes work with results like the ones Dave R post above.
                                            In other cases the plugin dosen´t do anything and prints this in the ruby console:
                                            Error: #<NoMethodError: undefined method back_material' for #<Sketchup::Edge:0x67b7f70>> C:/Archivos de programa/Google/Google SketchUp 7/Plugins/sublend.rb:68:in blend'
                                            C:/Archivos de programa/Google/Google SketchUp 7/Plugins/sublend.rb:270
                                            C:/Archivos de programa/Google/Google SketchUp 7/Plugins/sublend.rb:248:in `call'
                                            Daniel S
                                            • 1 / 4
