    [Plugin] ComponentReporter+.rb
    44 Posts 11 Posters 30.3k Views 11 Watching
      Here's v1.3
      Much as v1.2 but...
      The error message if the report was already made and left open in Excel so it can't be written to with a new report is now disabled pending a proper implementation.
      If the script fails it is likely the cause is this - close the report and re-run.PayPalButton
        Here's v1.4
        Main Changes:
        Report always located with Model.
        Miner goes whole depth of nesting.
        Commas in names etc trapped into ';'.
        3rd report of 'parentage' added.
        If any report is already open error now trapped.PayPalButton
          Here's v1.5
          Areas now report in current units, NOT always sq in.
          Note: if you always work in say mm but want areas in say sq m then edit the script around lines ~155-165 - there are guidance notes there on how to fix it easily...PayPalButton
          • Didier BurD
            Didier Bur
            Little typo line 189 "intances" for "instances".
            Nice script as always 😄
            DB
              Nice script as always :thup:
              Didier
              Thanks for those 'eagle-eyes' of yours.
              Since the typo is only in the text in an error dialog that shouldn't appear much anyway I'll leave it until v1.6...
                santiagom
                The old component reporter seemed to work on osx, the new one gives me this error. The model is saved.
                  Here's v1.6.
                  It sorts out file/folder paths slightly differently, which might avoid the Mac crash. It also corrects the typo in a dialog reported by Didier...PayPalButton
                    santiagom
                    Works ok now TIG
                    Thanks a lot
                    • C
                      clausgs
                      @santiagom said:
                      Works ok now TIG
                      Thanks a lot
                      Hi TIG
                      I have start using the component reporter with some of my projects..
                      I use it to drag out the size of each component... so that parts is ok..
                      I like to add some more information to each component so i have tried to add some text in the "NAME" input fild on the "Entity info" window, but that do not show up in the report... can that be fixed???
                      hope you are still working on this great RB...!!!
                      • B
                        Buildermax
                        @tig said:
                        Here's v1.6.
                        Hi, TIG
                        I use this reporter a lot, to quantify timber and steel etc. It’s a great tool but I was wondering if numbers or texts(unit, mm) can be fully separated into different spreadsheet cells, So that I can easily get into the numbers? Also, the approximation mark “~”, Can you make that not get exported as well?
                        Best regards
                        Max
                        Just love SU
                          @buildermax said:
                          @tig said:
                          Here's v1.6.
                          Hi, TIG
                          Best regards
                          Max
                          It's not something I can do soon... To avoid the units in the numbers you could try changing your unit settings in the Model Info to avoid having 123mm > 123 ? To get rid of the ~ ?
                          Here's how to do it yourself... You can strip selected text out of a file using a stream-editor technique, here's an example of code that you'd type/paste into the Ruby Console...
                          [I've just called the file/path 'Temp' and 'Report.csv' for simplicity - yours will be different - you can copy the path/name from the file's properties... BUT note you need to double up any \ to \ [or make every \ a /] - a single \ is a special-code character in Ruby string-land and it WILL fail to work as expected ! !]
                          file1="C;\\Temp\\Report.csv"; file2=File.new("C;\\Temp\\ReportFIXED.csv","w")
                          IO.readlines(file1).each{|line|file2.puts(line.gsub("mm,", ",").gsub("~", ""))}; file2.close
                          You should now have the contents of file1 copied into file2 BUT with the 'mm' or '~' missed out...
                          Note - if it were say '~ 123 mm' just change the gsub details to (" mm,",",") and/or ('~ ',"")...
                          The reason I choose ("mm,",",") is that I only want to change 'mm' at the end of a field and the separator is a comma
                          Alternatively, if you are a bit frightened of experimenting with coding then you can simply edit the .csv file using 'open-with' NotePad.exe [it's simply a text file with lines of Comma Separated Variables [CSV] that's readable in Excel etc] and then do a 'Find+Replace' on 'mm,' >>> ',' [Replace all] and '~' >>> '' [Replace all] etc and save it...
                          Let me know how you get on...
                          • B
                            Buildermax
                            Hi, TIG
                            Thanks for your time and advice but I am not very confident to deal with programming stuff. I prefer to edit the data in excel like the way you suggest, while waiting for the next version. I hope it could be more interactive and controllable.
                            By the way, to delete tilde ~ (along with some other symbols) by Find and Replace function of MS Excel, a ~ must be added in the selection field first, making it ~~, ~*, and etc.
                            Regards
                            Just love SU
                              @buildermax said:
                              Hi, TIG
                              Regards
                              I wasn't suggesting you used Find+Replace in Excel itself. If you double-click the file icon it will open in Excel, BUT if you open the file using the right-click context-menu 'Open with...', and select NotePad.exe and use the easier Find+Replace there, then save, the file is changed and when you open it in Excel they'll be no 'mm' or '~'. A 'csv' file is NOT a special Excel format, it's written in simple text with commas separated variables ("CSV"), it can most easily be edited with a text editor... However, Excel IS the default program to open csv files when you double-click since they are a special way of getting data out of one application into Excel without the hassle of binary encoding the fields (.tsv is similar = 'tab-separated-variables') !!! I thought you might be a bit wary of coding ! 😄 However, why not try it on a copy of the file... you'll be proud you did it 😛 - stand up and be a man ! 😉
                              • W
                                Walter S. Arnold
                                Bump of an old thread, but I want give thanks for this plugin; it really came in handy today.
                                • C
                                  clayc54
                                  im using component reporter and im getting some strange behaviour.
                                  i open a new file, drag in a component. do a report. it shows the component. i then add another component with nested components within. do another report. all good.
                                  when i delete the first component and then do a report, all reports show the deletion except the component+report.csv. its appearing to have a memory.
                                  has anyone else experienced this?
                                    There is a newer '..++' version that might avoid this ?
                                    • C
                                      clayc54
                                      thanks for the reply.
                                      is the ++ version you are talking about v1.6?
                                      i think that is the version i am using.
                                      i just downloaded it from one of your forum posts.
                                        No the '++' version is only at v1.1 here it is...ComponentReporter++.rb
                                        but v1.6 is the latest in the '+' version...
                                        • C
                                          clayc54
                                          thanks for your help
                                          i tried the ++ version and it does the same thing.
                                          if i put components in the drawing and then run a report it shows those components in all the CSVs. i then delete all the components in the drawing and add different components. save the file. when i now run the report, component+report.csv adds the new components to the deleted ones, it doesnt delete the components that arent in the drawing anymore. however both parentage and instances CSVs show the correct components.
                                          can anyone else test this scenario on their systems so i can be sure its not something quirky to my system?
                                          also wondering, what is the difference between + and ++ for componentreporter.
                                          just wanted to say that, other than that small hickup, this is an amazing plugin for me as im trying to draw garden designs for community groups. i have all my irrigation components tracked by this plugin. cheers
                                          • pyrolunaP
                                            pyroluna
                                            Hey TIG
                                            thanks for the great plugin
                                            however I discoverd a little bug
                                            if I have an ö in the folder name, the plugin tells me that the file I want to write to is in use.
                                            This is true for the + version and the ++ version
                                            Pyro
                                            • 1 / 3
