    Remove single item/component from a group
    8 Posts 7 Posters 24.8k Views 7 Watching
      Marty
      Is there a way to extract a single component from a group without exploding the group? I have a complex assembly with valves and piping. I have multiple copies of it as well. So I would prefer not to disturb what I already have.
      Thanks,
      Marty
      • Chris FullmerC Offline
        Sure, you can ctrl-c copy and ctrl-v paste. There is also a paste in place, which might be what you're looking for. Find it in the edit menu.
          dylan
          You should also be able to use Outliner.
          Windows/Outliner
          http://dmdarchitecture.co.uk/
          • TIGT Online
            In addition... edit the group/component and select what's to be extracted, now if you use ctrl+X [=cut] it will be removed from it's original parent group/component and placed onto the clip-board. You can then exit the group/component edit session and then in the model or another group/component edit session paste it [ctrl+V] back in, choosing where it's to go... OR if you simply want it taken out of the group/component BUT left in the same place, then you can cut it out and then come out of the group/component edit session and then use 'paste-in-place' with it in the model or inside another group/component edit session. I use 'paste-in-place' so much I have it as a shortcut - [shift+ctrl+V] ...
              dylan
              Paste in Place is an absolute must.
              I too use it all the time now.
              Not sure how I used to do things without it!
              • E Offline
                Einstein
                Sorry for bringing up an 8-year old thread but what does "edit session" mean? (what TIG said)
                  The "edit session" refers to when the group or component is open for editing. Exiting means closing the group or component which can be done by clicking in space away from the group/component or by using the Esc key to back out. Or you can open a different group or component for editing. You can also open components and groups for editing in the Outliner and of course exit out of edit mode there as well.
                    You can also use the Outliner! πŸ˜‰
                    Here a moving a Group named "Cylindre" to an element of a general Group named "Ensemble"!
                    And then use the cool free Real Time SimLab Composer Lite Vf (maxi 1920 * 1080)
                    (texture with the free cool onlineSumoPaint ! β˜€
                    https://s6.postimg.org/6ne7tnpn5/sumo3.jpg
