    How Can I Show the "Wireframe" and "Face" Style same time ?
    7 Posts 5 Posters 954 Views 5 Watching
      ranlai
      Just like the picture show ~~ ๐Ÿ˜’
      I have try more time, but I still don'y how to do that โ“ โ“
      • Jean-FrancoJ Offline
        Jean-Franco
        I'm not sure if I understand your problem correctly.
        If you want to do the same as in your picture, you have to use sections planes. First activate it.
        View > Toolbars > Sections
        Jean-Franco
          ranlai
          Thanks Jean ๐Ÿ˜„ ,
          ummm..
          May be like the follow picture~
            Charlie__V
            Not sure I understand your goal either........but maybe enable X-ray and set transparency to "nicer".
            Best,
            C
            X-Ray w/textures
              BTM
              I THINK he wants to have the section plane get rid of only the faces. That's impossible, unless you use a little trick. Here's how: make 2 identical groups. In one, hide all faces. In the group group that doesn't have the faces hidden, add the section cut. It should do this.
                meister
                I made it using zorro and filter tools.Zorro tool.jpgSelect to fireframe.jpgSelect to filter faces.jpgFiltered faces.jpgHide faces.jpgFinal result.jpg
                  ranlai
                  THANK ALL GUY ๐Ÿ˜„ ๐Ÿ˜„
                  I have see Mike CLICK CLICK the mouse key when the wireframe will show on~
                  The time range in video at 02:40-02:55
                  http://www.youtube.com/watch?v=kvtZWQrimV0
