    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 1.8m Views 329 Watching
    • SwissmountainS Offline
      Swissmountain
      Thanks for the Plugin, nice work! 👍
      Cogito ergo dum-di-dum
      • simon le bonS Offline
        simon le bon
        Bonjour Chris,
        What a plugin! I enjoy the originality of the approach, I am surprise by it great power, and I applaud to it accomplishment 👍 👍
        I had made some studies with it and here are some of the results
        ShapeBender Basics Studies:
        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/BasicStudies_640.jpg
        Basic Studies SlideShow(Adobe PhotoExpress)
        ShapeBender_Wrap Test
        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/WrapTest_640.jpg
        Wrap Test SlideShow >>or the album (Picasa Album/Slideshow)
        (I noticed some difficulties, but I'll tell you later)
        simon
          does it possible to have the result with the same number of groups than the start?
          see this post 😉
            Coronel
            @darkphysics said:
            @chris fullmer said:
            The problem is with the compspray.rb
            Update it from here:
            http://forums.sketchucation.com/viewtopic.php?f=180&t=11746
            Didier had a bug in it that was breaking the progressbar, but he fixed it nicely. So just update that, then it should work.
            Let me know if that does not help.
            It didn't work with new compspray, but I removed it and it worked!
            It's working fine again after compspray removing too on Mac
            • Chris FullmerC Offline
              Oh good, glad its working Coronel. There is a new version of component spary that you can download and safely install. Didier fixed it up so it doesn't conflict with anything.
                rem_s
                I try to use the shape bender but nothing happen. When I open the ruby console I saw an error message :
                Error: #<NoMethodError: undefined method /' for nil:NilClass> C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_shape_bender/clf_shape_bender.rb:671:in draw'
                  Do you have an old version of Component Spray installed?
                    rem_s
                    Yes but it still not work
                      Thom asked if you had an old version installed, because the old version causes my script to break. Try updating to the new component spray hee:
                      Funny thing is, compspray causes ANY script that uses the progressbar to break (including MakeFaces!). But seems like people only notice it on my script 😞
                      Anyhow, update it and see if that helps.
                      • charly2008C Offline
                        charly2008
                        Hi Chris,
                        i had the same problem. I installed the compo spray version you mentioned above. But the problem was not solved. i had to remove the compo spray from the plugins folder, than shape bender worked fine.
                        Karlheinz
                          That really shouldn't be the case though. The new compo spray no longer intereferes with the other scripts. So if you installed the new compo spray correctly, it will fix the issue.
                          I don't want people to think that there is a problem with compo spray, because it works well.
                          • H Offline
                            hasan
                            Chris,
                            I am really impressed by what you achieved. This is a master transformation
                            I played a little bit with it, and I think you got the essentials. The rest is just about adjustments in UI and options. And indeed to extend it to embedded components.
                            Well done!
                              Did you ever get it working Hasan?
                                tomot
                                Wow! great tool. It looks like it would not be to hard to change the code to create orientated text for a Catenary curve? Which is not possible in the present version. 😢
                                [my plugins](http://thingsvirtual.blogspot.ca/)
                                tomot
                                  Hi Tomot, sure it can do a catenary curve. You just have to be able to draw one on your own, which I suppose is the hard part. This script will bend a shape to match any supplied line/curve. So if you can draw the catenary curve, it will certainly bend to match it.
                                    tomot
                                    yes I know, but as my pic shows I would like the text oriented so that I don't have to read it upside down
                                    tomot
                                      tomot
                                      I just discovered that the first implementation of Shape bender will influence a second implementation, in the same file. however I can combine one with cutting and pasting from another file.
                                      tomot
                                        Hey, thats it! That is something that has come up but I could never quite put a finger on what was going on. There has always been a bug where often the 2nd time you bend a shape, it does not work as expected. I think I am carrying overy information between shape bender uses.
                                        As for your text, just turn it upside before you bend the bottom one. That will doe the trick.
                                          JesperWille
                                          Consider this: - I (shamefully!) haven't kept up on plugins for a while, and this is pretty much the first new one I've tried in, well, a year or more... now ask me if my mind is in anyway blown.
                                          Excellent piece of software there, Chris, and thank you a thousand times for sharing it!
                                          I am currently running it with the latest 7.1 beta, I'll be sure to let you know if anything comes up - so far, flawless.
                                          Thanks again mate!
                                          Jesper W.
                                          http://www.jesperwille.com
                                          • EarthMoverE Offline
                                            EarthMover
                                            It's great isn't it jesper!? I just wanted to say thanks again as well to Chris. I use this tool on every project and I'm really thankful to have it in my repertoire! It's been a real blessing!
                                            Content Creator at Skapeup
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 63
                                            • 64
                                            • 25 / 64
