    [Plugin] extrudeEdgesByEdges.rb
    190 Posts 76 Posters 225.2k Views 76 Watching
    • MALAISEM Offline
      MALAISE
      Hi All
      I have encountered some strange behaviour of TIG' last Plugin. Have you notice that Experimental SketchyPhysic 3X may block ExtrudeEdges ?
      Using SketchyPhysic 2 , no problem at all .... please let's share your comments
      MALAISE ๐Ÿ˜„
      La Connaissance n'a de valeur que partagรฉe
        Don't see where the clash could be [yet] ?
          chango70
          @tig said:
          @aceshigh said:
          TIG, very nice plugin... can you improve it to add the option for another rail "edge", thus effectively transforming it into a SWEEP 2 RAILS plugin??
          It's on the list...
          Drool...
          • kerabeK Offline
            kerabe
            Wow, what a great plugin! Just downloaded it and have been playing around with it and I have had no real problems at all. Had to do some minor clean-up work but nothing unusual. Love it. ๐Ÿ˜„
            The CH124: If it isn't leaking, you're out of oil...
              Version 1.4 is now out... http://forums.sketchucation.com/viewtopic.php?p=166780#p166780
              1.4 20090707 Triangulation improved [as my recent triangulate.rb]. Rare intersect glitch fixed.
                Trivial problem ๐Ÿ˜„
                if the groups are on the full screen result is out of the screen an no possibity to see it before to reply all the box dialog!
                So will be cool that an automatic resize exist before process ๐Ÿ˜‰
                Sure I can zoom out but... ๐Ÿ˜‰
                  mpowell1234567890
                  Help, I cannot get it to work..
                  Plugin seen not to work..
                  Is there a way to fix it?
                  @tig said:
                  EDIT:
                  1.1 20090625
                  Speed improvements - face making time ~halved,
                  typename >> kind_of?, triangulation glitch trapped
                  and orientation improved.
                  1.2 20090625
                  Orientation speed optimised.
                  Glitch on groups erase fixed.
                  1.3 20090626
                  Edges not facing in convoluted shapes trapped.
                  1.4 20090707
                  Triangulation improved. Rare intersect glitch fixed.
                  This is extrudeEdgesByEdges.rb - it does what its name implies...
                  [attachment=2:t7jruxbl]<!-- ia2 -->ExtrudeEdgesByEdgesExample.png<!-- ia2 -->[/attachment:t7jruxbl]
                  [attachment=3:t7jruxbl]<!-- ia3 -->ExtrudeEdgesByEdgesEsamples.skp<!-- ia3 -->[/attachment:t7jruxbl]
                  [attachment=1:t7jruxbl]<!-- ia1 -->extrudeEdgesByEdges.rb<!-- ia1 -->[/attachment:t7jruxbl]
                    [attachment=0:1yi83ajh]<!-- ia0 -->Plugin error.JPG<!-- ia0 -->[/attachment:1yi83ajh]
                    On the face of it, it looks like you aren't making a set of edges and grouping them as the 'profile', and also a set of edges and grouping them as the 'path'... Do this, then select the two groups and run the tool... The error message is telling you you haven't selected two groups...
                    If you have other problems then please expand in your explanation...
                      Here's v1.5 - It now Zooms to show the new group [at Pilou's request]
                      • bazB Offline
                        baz
                        This is an astounding plugin, I've already found myself using it on lots of 'ordinary' tasks where usually I would have had to stuff around for ages with followme, copypaste, etc.
                        Thank you very much Tig.
                        Baz
                          THX! Very reactive! ๐Ÿ˜Ž ๐Ÿ‘
                          Edit ๐Ÿ˜„
                          Seems there is something wrong in the "Zoom" ๐Ÿ˜‰
                          That don't work ๐Ÿ˜ฎ
                          zoom out must be made before the first dialog box "Orient faces"
                          Without that zoom don't work even at the end ๐Ÿ˜„
                          (I have of course the 1.5)
                          zoom.skp
                            Here's v1.6 http://forums.sketchucation.com/viewtopic.php?p=166780#p166780
                            It fixes a glitch with large mesh group results not zooming properly so that you can see them all...
                            The way it works is that it selects the group, 'zooms selected' and then removes group from selection - fine for modest sized meshes BUT if the group is too large SUp hasn't found the selection to 'zoom to' before the selection is cleared... so I've put the 'remove from selection' part after the first dialog so it has time !
                            • JClementsJ Offline
                              JClements
                              TIG:
                              Is the result you wanted when erasing coplanar edges?
                              John
                              P.S.
                              JSClements is a temp login until I can get JClements restored.
                              Is this the result you wanted when deleting coplanar edges.skp
                                cyan.archnet
                                really SUPERB plugin, THANKS A LOT!
                                  Perfect zoom this time ๐Ÿ‘
                                    Here's v1.7 http://forums.sketchucation.com/viewtopic.php?p=166780#p166780
                                    Some rare coplanar edge erasure errors have now been trapped...
                                      TIG:
                                      John
                                      P.S.
                                      Obviously not ! ๐Ÿ˜
                                      I will check on why this might be happening... I thought such things had all got trapped... watch out for an update !!!
                                        Seems you will be quiet only when your true sweep 2 rails will be born ๐Ÿ˜„
                                        Because the "stay parallel orientation" of curves is sometimes annoying for real forms ๐Ÿ˜‰
                                          Pilou, patience ! ๐ŸŽ‰
                                            ๐Ÿ˜„
                                            It's soon holiday so September will be Christmas surprise ๐Ÿ’š
                                            • 4 / 10
