    Haste makes waste
    31 Posts 9 Posters 3.5k Views 9 Watching
    • david57D Offline
      david57
      • david57D Offline
        david57
        • david57D Offline
          david57
          This take forever to render and its unfinished.
            Sir
            what renderer are you using? and on what settings? its a very simple scene it shoudln't take too long
            • david57D Offline
              david57
              Using Kerkythea and rendering this last one with BiPT.
              Others Kerkythea and rendered using MLT.
                Sir
                ill wait for a kerky expert to pop by then, but does each tree have a separate leaf?
                  Connor
                  If this is an outdoor scene lit only by the sun you should try the Progressive Path Tracing setting. See if that speeds things up.
                  It also looks like a healthy amount of geometry with the modelled roof tiles and trees. That is probably contributing to the speed.
                  • david57D Offline
                    david57
                    Yes, PPT, using that now. I have to remove also lots of twigs, stems not seen and unnecessary geometry. Will also try reducing translucency on all trees. I tryed pseudo translucency and doesn't look right.
                    • david57D Offline
                      david57
                      Palm tree and small plant from Gooogle Warehouse.
                      • david57D Offline
                        david57
                        To Mat B: Yes, All trees are using the same leaf.
                        Here's a front view with the palm. PPT render. I need bushes. Dont like the plant and will check warehouse to see what else they have, there.
                        • david57D Offline
                          david57
                          Couldn't find one but I tried one called Cycas Palm from: http://blender-archi.tuxfamily.org/Greenhouse#European_Oak
                          Something went wrong and plant looks like it growing something.
                          • david57D Offline
                            david57
                            Palm next to the rocks also from Google warehouse.
                            • david57D Offline
                              david57
                              Trying out the light green one to the left and also from google warehouse.
                              • david57D Offline
                                david57
                                Not satisfied, i still feel that i need to do more work on it.
                                • david57D Offline
                                  david57
                                  I over did it.
                                  • david57D Offline
                                    david57
                                    Made a hedge with a free software named Bantam3DGrass.
                                    • 2 / 2
