    [Plugin] New Piping System Plugin
    60 Posts 25 Posters 50.2k Views 25 Watching
    • B
      bhealy27
      I can't find the files this Plugin installed on my Mac. Either they are in some strange location or I don't know what the name of the files are. How do I uninstall these if I don't want it cluttering up my system?
      I've looked in Library>Application Support>Google Sketchup 7>Sketchup>Plugins in both the Macintosh HD and User Directories without luck.
      • BurkhardB
        Burkhard
        called 3dskeng and has its own two button toolbar
        http://www.ia-plus.de
        • H
          Howard leslie
          Sebastian / Josef,
          Great plug-in.
          Excellent user interface - very fast to use.
          A few suggestions / ideas / requests:
          1. Ability to specify number of segments for circles (pipe profiles) (to help keep file sizes down).
          2. Ability to have pipe sections, pipe junctions etc as COMPONENTS - or all geometry as COMPONENTS
          3. Ability to NAME these Components (if user requires it).
          4. Ability to automatically generate Centrelines for all geometry eg each pipe section - very useful for snapping / lining up / offsetting other geometry to. This centreline to go on its own layer eg "Centreline"
          5. Ability to Specify "Pipes" of Square or Rectangular Cross Section. This plug-in could then be used to model other types of Ducts eg Ventilation Systems / Air-Conditioning Systems.
          6. See the excellent Profile Builder Plug-in. If you have centrelines you will be able to generate total LENGTHS for each Pipe section. From the pipe profile (area) you can then calculate VOLUME of each Pipe Section. Some type of Reporting function that will generate Lengths, Volumes and Totals for each Pipe Section (Named Components). These Reporting out type functions / code already exist in several other Plug-ins eg by TIG, Jim Foltz and others.
            Just a thought...
            Potentially both The Profile Builder and your Piping System Plug-in Compliment each other very well.
            Maybe you should Team Up with Dale Martens who created The Profile Builder plug-in so that you can have the best of both worlds ???
            You could use Dale's Profile Builder so that you can use any profile / cross-section you want to - but they would be modelled in a very simple and intuitive way using your superb drawing engine / user interface ???
            A marriage made in su heaven ??? !!!
            Keep up the good work on this fantastic plug-in.
          Regards
          Howard L'
          • C
            Coronel
            It don't work on Mac
            • B
              bianhai
              Good! 👍
              • JClementsJ
                JClements
                What is the STATUS of this plugin's DEVELOPMENT ?????
                [Edit] I now see that you can change the circle segmentation value when the pipe tool is intiated by typing in the VCB (a.k.a "Measurements" box in the SU taskbar). This is mentioned in the tutor dialog which I had turned off.
                • Bob JamesB
                  Bob James
                  I just downloaded this plugin and it works fine on my MacPro.
                  In addition to Profile Builder I often use the "Convert Arcs, Circles, Curves and Lines to Cylinders" plugin. It has the advantage of being able to define a material, opt to make a the whole thing a group or make each tube a group, in addition to defining the diameter and precision. A neat plugin.
                  This "New Piping System Plugin" would be nice if it had some standard library of fittings.
                  Took about 2 minutes and then rendered with IDXRenditioner
                  • W
                    watkins
                    Dear SHK,
                    Can this plugin be used to plan a domestic central heating system - boiler, radiators, control valves, pumps etc?
                    The technology behind this plugin suggests that it could be adapted to wiring schemes too, both domestic and industrial.
                    Regards,
                    Bob
                    • C
                      Coronel
                      2x2 Ghz Power PC G5 with 10.5.7 and SU 7 here.
                      I make several attempts and no luck. I also did a manual installation but no luck. I only got some console message errors depending on the path of the installed components.
                      Could you please write me your components paths? Thanks
                      • Bob JamesB
                        Bob James
                        Coronel,
                        It just clicked on the 3skenglt© for Google Sketchup 7.mpkg file.
                        I could not find out where the mpkg file installed the working files: definitely not in the plugins folder.
                        When you say you "manually" installed it, just what did you manually install??
                        Note this from the SHK website:
                        The installation of 3skeng does not work on my computer. What can I do?
                        We have tested the setup software and the 3skeng software very carefully. Nevertheless it is a new software and we may have not tested all possible configurations. If you are an registered user, please send us an email to support@3skeng.com with a description of the problem as detailed as possible. Clarifying screen shots are highly appreciated. We will help you as soon as possible!
                        • C
                          Coronel
                          Coronel,
                          I looked for the installed files and was trying the plugin moving them to different possible locations where SU could find them. I made a probe with another user account library, in documents folder like some rubys do, in the own SU folder plugin... I was reading the ruby and its needed files and all seems to be in the right place but I still get start up errors.
                          I was reading their forums and made same post there too.
                          Thank you I will try with their support mail.
                          • Bob JamesB
                            Bob James
                            Where are the files/ruby located?
                            • C
                              Coronel
                              localhost/Users/me/Library/Application Support/Google SketchUp 7/SketchUp/plugins/3skenglt (folder)/
                              localhost/Users/me/Library/Application Support/Google SketchUp 7/SketchUp/plugins/3SkengltExtension.rb
                              it requires 'sketchup.rb' and 'extensions.rb', in the same plugins folder.
                                Here we go again.
                                With all due respect, if we let every Joe that can write software launch his/her product at the SCF we are quickly going to lose credibility. This forum benefits from reports and critiques by users, that are motivated to post by the relevant features of the product. Subjective, first hand users of a product only.
                                I can’t imagine the clutter we are going to have here in a year or so if this keeps up.
                                What what what? ❓
                                • BurkhardB
                                  Burkhard
                                  I like it to see what people do for and with SU.
                                  Where is the place I get to know when not here?...and... would you say the same about smustard and their commercial scripts?
                                  This is a platform where people can present their products/scripts/plugins related to SU. It is our decision to talk about and to test it. For me it is a difference with marketing and let people know about something new.
                                  my2cents
                                    hm.. well, I don't see any problem with this post or the likes. I find it interesting to hear about what is available. To me it's the same if the creators make a post or if any user make a post.
                                    This post was nothing more than a simple link - no cheesy sales pitches.
                                    I just don't see the issue...
                                    • Mike LuceyM
                                      Mike Lucey
                                      @watkins said:
                                      Dear All,
                                      What happens when you download the software? Do you get the usual plugins or is there an installer that places software elsewhere? I note that the 'free' offer is only until October 2009. How does that work? Does the installed software time out? I would hate to get used to using it and then find it carries a heavy price tag after October.
                                      Regards,
                                      Bob
                                      Hi Guys,
                                      Maybe I've missed the advise on the price of this PlugIn come Ocober next but I don't think so. I also checked the 'vendors' site carefully and could not see a price anywhere either. I did see 'Use 3skeng Pipe for FREE until October 2009!' and a flashing 'Free' notice. Its a bit confusing to say the least. I am now under the impression that its a free trial ONLY.
                                      I think Bob has asked a reasonable question which deserves and answer. This thread has now become a mini Beta Testing Center for 3skeng! Also there was NO permission sought to announce this 'commercial'. I am now considering putting it into quarantine until this matter / question is answered
                                      satisfactorily. I will now write to 3skeng and clarify the matter.
                                      Mike
                                      • Bob JamesB
                                        Bob James
                                        modelhead,
                                        I don't think I could disagree with you more! I realize you have jillions of posts, but I, for one at least, browse the forum to see what's going on and to see if there are any new plugins that will make my job easier and/or better. My job depends on SketchUp.
                                        When I see something that might be of value to me I try it out. If it shows promise, even if it's not quite finished, I try to find out what doesn't work and/or what I'd like it to do and post my responses.
                                        I don't know how many plugins I have both from Smustard and from the incredibly talented forum posts from Whaat, TIG, thomthom, Foltz, Fredo, Fullmer, Bur, CadFather, Burch, Wilson, etc., etc.
                                        And if folks like SHK want to clue me into some other source for a plugin, I'm all for it. I would never have known about 3skeng's Piping System Plugin if he hadn't posted the URL here.
                                        I really don't see how this is "watering down" our forum.
                                          I agree that mixing up free with "shareware" or "trialware" is confusing and annoying.
                                          Is it that big of a deal. It was in informational link. I've seen before makers of commercial plugin post announcements only for it to be removed - then hours later a user posts a link and everything is fine. To me it makes no difference to what the source is - new software that are relevant for Sketchup use is of interest.
                                          When developers are active on this forum and communicate directly with us I see that as a good thing. Something I don't want to see discouraged.
                                          • Bob JamesB
                                            Bob James
                                            Amen
                                            • 2 / 3
