    [Plugin] New Piping System Plugin
    60 Posts 25 Posters 50.2k Views 25 Watching
      Daniel S
      I just install this one, but is not working here:
      Error: #<FloatDomainError: Infinity>
      (eval):213:in round' (eval):213:in roundToSystemUnits'
      (eval):1546:in getDiameter' (eval):2340:in onMouseMove'
      (eval):213
      Any idea?
      Daniel S
        SHK
        Daniel,
        please make sure, your length snapping under "Model info>units" is using a value bigger then 00000.
        http://www.3skeng.com/support/Error FloatDomainError Infinity.png
        This should solve your problem.
        Regards, Sebastian
        P.S. we could fix a problem at the mail server. All email addresses ending with @3skeng.com are now up and running.
        • C
          craigbic
          Awesome plugin! Very intuitive interface. I can't wait for the conceptual version. Keep up the good work! 😍
          Checkout the Sketchup Graphics Blog at http://sketchupgraphics.com
          • urgenU
            urgen
            ....Many thanks to SHK (Sebastian Kummer?) and talent of Josef Leibinger!...Very useful!... PIPESOAPSKINBUBLE? 😉 😄
            --pupil forever...------
              In the video we can see a modification in "Real time" ,
              a move of a grey pipe with automatic transformation
              That is possible because it's built with library components or it's possible with any pipes built with the plug?
                SHK
                Thank you for your answers, suggestions and positive feedback. Yes, Josef Leibinger is part of our software team and he is dong a great Job.
                We have very interesting functions (flex, editing...) on our roadmap. We are working hard to convert our prototypes into products "ready to publish".
                • BurkhardB
                  Burkhard
                  A short hint. If you have open the tutor and switch to the selection tool, the tutor appears everytime you try to orbit around with the mouse wheel.
                  Greetings to Josef...
                  Burkhard
                  http://www.ia-plus.de
                  • MALAISEM
                    MALAISE
                    This plugin really simplifies pipes drawings. I agree J.LEMIRE about improvements which could be implemented.
                    Gut gemacht Leute, erste Klasse Arbeit.
                    MALAISE 👍
                      SHK
                      Today we published the MAC version. We are very interested, how many of you are working with a MAC...
                      Best regards
                      Sebastian
                        RoboDoc
                        Hello,
                        I installed the Mac plugin and it is working well. Great system. I had a problem, though. When I first installed the plugin, I was happily making 2" round pipe as desired. After a bit, it changed to hexagonal profile pipe and I can't seem to get things back to round. There didn't seem to be any solution in the tutorial. How do you choose between the profile of the various pipes?
                        R
                        • Jean LemireJ
                          Jean Lemire
                          Hi folks.
                          After installing the Mac plugin, SU 7 stop working. SU starts then exit immediately.
                          I had to uninstall all and then reinstall all.
                          I am using OS 10.4.11 (Tiger).
                          Is this pluggin only for OS 10.5 (Leopard) ?
                          I have to wait before trying a new install of this plugin.
                          Just ideas.
                          • JClementsJ
                            JClements
                            A couple more suggestions:
                            1- Choose to put group on a specific, predesignated layer, but keep extruded contents on Layer0.
                            2- Choice of the number segments for circles and arcs.
                            I believe it currently defaults to 60 segments; this is impractical for any models with more than few pipes as it will surely creat files in the megabytes.
                            • JClementsJ
                              JClements
                              Very nice UI!!! I see Josef Leibinger authored the Ruby. Kudos to him as well.
                              Suggestions:
                              1- Allow input of a radiuseither through typing in a value followed by an "R" or input of math such as "1.235/2".
                              2- Option to simultaneously draw centerlines on a user defined layer.
                              3- Elbows and reducer. Reconstitute separate arc segments into true circle.
                              4- T's. If the diameter of both pipes are equal then the diameter endcap of the branching pipe shows through the pipe it is centered on due to "Z-fighting" in SU. An option to hide the edge of the this diameter or to put in it on a hidden layer would remedy this.
                              5- eccentric reducers.
                              6- Option to use pre-selected centerlines? I'm guessing this could be useful if using client supplied CAD drawing; not sure how it would be implement though 😄. Perhaps when edge intersections are detected (like a T) it would query the user to pick a pipe, T, or elbow.
                              5- I agree with Jean Lemire about naming the groups.
                              • B
                                bhealy27
                                I can't find the files this Plugin installed on my Mac. Either they are in some strange location or I don't know what the name of the files are. How do I uninstall these if I don't want it cluttering up my system?
                                I've looked in Library>Application Support>Google Sketchup 7>Sketchup>Plugins in both the Macintosh HD and User Directories without luck.
                                • BurkhardB
                                  Burkhard
                                  called 3dskeng and has its own two button toolbar
                                  • H
                                    Howard leslie
                                    Sebastian / Josef,
                                    Great plug-in.
                                    Excellent user interface - very fast to use.
                                    A few suggestions / ideas / requests:
                                    1. Ability to specify number of segments for circles (pipe profiles) (to help keep file sizes down).
                                    2. Ability to have pipe sections, pipe junctions etc as COMPONENTS - or all geometry as COMPONENTS
                                    3. Ability to NAME these Components (if user requires it).
                                    4. Ability to automatically generate Centrelines for all geometry eg each pipe section - very useful for snapping / lining up / offsetting other geometry to. This centreline to go on its own layer eg "Centreline"
                                    5. Ability to Specify "Pipes" of Square or Rectangular Cross Section. This plug-in could then be used to model other types of Ducts eg Ventilation Systems / Air-Conditioning Systems.
                                    6. See the excellent Profile Builder Plug-in. If you have centrelines you will be able to generate total LENGTHS for each Pipe section. From the pipe profile (area) you can then calculate VOLUME of each Pipe Section. Some type of Reporting function that will generate Lengths, Volumes and Totals for each Pipe Section (Named Components). These Reporting out type functions / code already exist in several other Plug-ins eg by TIG, Jim Foltz and others.
                                      Just a thought...
                                      Potentially both The Profile Builder and your Piping System Plug-in Compliment each other very well.
                                      Maybe you should Team Up with Dale Martens who created The Profile Builder plug-in so that you can have the best of both worlds ???
                                      You could use Dale's Profile Builder so that you can use any profile / cross-section you want to - but they would be modelled in a very simple and intuitive way using your superb drawing engine / user interface ???
                                      A marriage made in su heaven ??? !!!
                                      Keep up the good work on this fantastic plug-in.
                                    Regards
                                    Howard L'
                                    • C
                                      Coronel
                                      It don't work on Mac
                                      • B
                                        bianhai
                                        Good! 👍
                                        • JClementsJ
                                          JClements
                                          What is the STATUS of this plugin's DEVELOPMENT ?????
                                          [Edit] I now see that you can change the circle segmentation value when the pipe tool is intiated by typing in the VCB (a.k.a "Measurements" box in the SU taskbar). This is mentioned in the tutor dialog which I had turned off.
                                          • Bob JamesB
                                            Bob James
                                            I just downloaded this plugin and it works fine on my MacPro.
                                            In addition to Profile Builder I often use the "Convert Arcs, Circles, Curves and Lines to Cylinders" plugin. It has the advantage of being able to define a material, opt to make a the whole thing a group or make each tube a group, in addition to defining the diameter and precision. A neat plugin.
                                            This "New Piping System Plugin" would be nice if it had some standard library of fittings.
                                            Took about 2 minutes and then rendered with IDXRenditioner
                                            • 2 / 3
