    [Plugin] New Piping System Plugin
    60 Posts 25 Posters 47.7k Views 25 Watching
      FAbulous Pipeline maker πŸ‘ β˜€
      • Jean LemireJ Offline
        Jean Lemire
        Hi Red, hi folks.
        If you go to their web site, namely at the download page at:
        http://www.3skeng.com/download.htm
        you will see that the Mac version is coming soon.
        Just ideas.
          Daniel S
          I just install this one, but is not working here:
          Error: #<FloatDomainError: Infinity>
          (eval):213:in round' (eval):213:in roundToSystemUnits'
          (eval):1546:in getDiameter' (eval):2340:in onMouseMove'
          (eval):213
          Any idea?
          Daniel S
            SHK
            Daniel,
            please make sure, your length snapping under "Model info>units" is using a value bigger then 00000.
            http://www.3skeng.com/support/Error FloatDomainError Infinity.png
            This should solve your problem.
            Regards, Sebastian
            P.S. we could fix a problem at the mail server. All email addresses ending with @3skeng.com are now up and running.
              craigbic
              Awesome plugin! Very intuitive interface. I can't wait for the conceptual version. Keep up the good work! 😍
              Checkout the Sketchup Graphics Blog at http://sketchupgraphics.com
              • urgenU Offline
                urgen
                ....Many thanks to SHK (Sebastian Kummer?) and talent of Josef Leibinger!...Very useful!... PIPESOAPSKINBUBLE? πŸ˜‰ πŸ˜„
                --pupil forever...------
                  In the video we can see a modification in "Real time" ,
                  a move of a grey pipe with automatic transformation
                  That is possible because it's built with library components or it's possible with any pipes built with the plug?
                    SHK
                    Thank you for your answers, suggestions and positive feedback. Yes, Josef Leibinger is part of our software team and he is dong a great Job.
                    We have very interesting functions (flex, editing...) on our roadmap. We are working hard to convert our prototypes into products "ready to publish".
                    • BurkhardB Offline
                      Burkhard
                      A short hint. If you have open the tutor and switch to the selection tool, the tutor appears everytime you try to orbit around with the mouse wheel.
                      Greetings to Josef...
                      Burkhard
                      http://www.ia-plus.de
                      • MALAISEM Offline
                        MALAISE
                        This plugin really simplifies pipes drawings. I agree J.LEMIRE about improvements which could be implemented.
                        Gut gemacht Leute, erste Klasse Arbeit.
                        MALAISE πŸ‘
                        La Connaissance n'a de valeur que partagΓ©e
                          SHK
                          Today we published the MAC version. We are very interested, how many of you are working with a MAC...
                          Best regards
                          Sebastian
                            RoboDoc
                            Hello,
                            I installed the Mac plugin and it is working well. Great system. I had a problem, though. When I first installed the plugin, I was happily making 2" round pipe as desired. After a bit, it changed to hexagonal profile pipe and I can't seem to get things back to round. There didn't seem to be any solution in the tutorial. How do you choose between the profile of the various pipes?
                            R
                              Jean Lemire
                              Hi folks.
                              After installing the Mac plugin, SU 7 stop working. SU starts then exit immediately.
                              I had to uninstall all and then reinstall all.
                              I am using OS 10.4.11 (Tiger).
                              Is this pluggin only for OS 10.5 (Leopard) ?
                              I have to wait before trying a new install of this plugin.
                              Just ideas.
                              • JClementsJ Offline
                                JClements
                                A couple more suggestions:
                                1- Choose to put group on a specific, predesignated layer, but keep extruded contents on Layer0.
                                2- Choice of the number segments for circles and arcs.
                                I believe it currently defaults to 60 segments; this is impractical for any models with more than few pipes as it will surely creat files in the megabytes.
                                  JClements
                                  Very nice UI!!! I see Josef Leibinger authored the Ruby. Kudos to him as well.
                                  Suggestions:
                                  1- Allow input of a radiuseither through typing in a value followed by an "R" or input of math such as "1.235/2".
                                  2- Option to simultaneously draw centerlines on a user defined layer.
                                  3- Elbows and reducer. Reconstitute separate arc segments into true circle.
                                  4- T's. If the diameter of both pipes are equal then the diameter endcap of the branching pipe shows through the pipe it is centered on due to "Z-fighting" in SU. An option to hide the edge of the this diameter or to put in it on a hidden layer would remedy this.
                                  5- eccentric reducers.
                                  6- Option to use pre-selected centerlines? I'm guessing this could be useful if using client supplied CAD drawing; not sure how it would be implement though πŸ˜„. Perhaps when edge intersections are detected (like a T) it would query the user to pick a pipe, T, or elbow.
                                  5- I agree with Jean Lemire about naming the groups.
                                    bhealy27
                                    I can't find the files this Plugin installed on my Mac. Either they are in some strange location or I don't know what the name of the files are. How do I uninstall these if I don't want it cluttering up my system?
                                    I've looked in Library>Application Support>Google Sketchup 7>Sketchup>Plugins in both the Macintosh HD and User Directories without luck.
                                    • BurkhardB Offline
                                      Burkhard
                                      called 3dskeng and has its own two button toolbar
                                      • H Offline
                                        Howard leslie
                                        Sebastian / Josef,
                                        Great plug-in.
                                        Excellent user interface - very fast to use.
                                        A few suggestions / ideas / requests:
                                        1. Ability to specify number of segments for circles (pipe profiles) (to help keep file sizes down).
                                        2. Ability to have pipe sections, pipe junctions etc as COMPONENTS - or all geometry as COMPONENTS
                                        3. Ability to NAME these Components (if user requires it).
                                        4. Ability to automatically generate Centrelines for all geometry eg each pipe section - very useful for snapping / lining up / offsetting other geometry to. This centreline to go on its own layer eg "Centreline"
                                        5. Ability to Specify "Pipes" of Square or Rectangular Cross Section. This plug-in could then be used to model other types of Ducts eg Ventilation Systems / Air-Conditioning Systems.
                                        6. See the excellent Profile Builder Plug-in. If you have centrelines you will be able to generate total LENGTHS for each Pipe section. From the pipe profile (area) you can then calculate VOLUME of each Pipe Section. Some type of Reporting function that will generate Lengths, Volumes and Totals for each Pipe Section (Named Components). These Reporting out type functions / code already exist in several other Plug-ins eg by TIG, Jim Foltz and others.
                                          Just a thought...
                                          Potentially both The Profile Builder and your Piping System Plug-in Compliment each other very well.
                                          Maybe you should Team Up with Dale Martens who created The Profile Builder plug-in so that you can have the best of both worlds ???
                                          You could use Dale's Profile Builder so that you can use any profile / cross-section you want to - but they would be modelled in a very simple and intuitive way using your superb drawing engine / user interface ???
                                          A marriage made in su heaven ??? !!!
                                          Keep up the good work on this fantastic plug-in.
                                        Regards
                                        Howard L'
                                          Coronel
                                          It don't work on Mac
                                            bianhai
                                            Good! πŸ‘
                                            • 2 / 3
